Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Bissell pro heat carpet cleaner clear cover removal
How do i remove the clear plastic cover on my carpet cleaner to clean the dirt out of it? I removed the two screws near the head but I can't get the cover off
  • 39 Answers
Just lift it up probably suction holding it
Posted on Jun 29, 2009
Bissel 1699 Pro Heat Clearview Plus- It dumps entire load of soap in a few minutes and the flow indicator doesn't work even though it is clean.
Posted on Jul 21, 2009
How do I fix the problem on my Bissell model # 7920-5 carpet and floor cleaner the water won't spray out onto the carpet
First check your user's guide for filter cleaning. There are two filters both small that need cleaning after each use. If that didn't clear it up call Bissell Consumer Care at 1-800-237-7691
Jul 01, 2014 | Bissell Vacuums
Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you need and a manual you can view:
Bissell 7901 Belt and Manual
Mar 01, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell pro heat 2 9300-1
remove the tank the 2 red tips are most likely clogged remove them use a paper clip to clear them then run the cleaner tn the rinse cycle with the tips off this should remove all the build up (out side may be messy ) if that doesent work its probably the solenoid
hope this helps
Dec 16, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell pro heat will not extract water from the carpet
Try checking the top section of the machine (where the dial is located to switch it from floor to tool) and there is a little red plastic piece about 1 inch square on the inside of it. This is a lint filter that has a little door on it. Open the door or remove the entire thing to clean it out. It is probably completely blocked with hair, etc.. which is why you have no suction. Replace it after you clean it out and hopefully your problem will be solved!
Sep 06, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
The bissell proheat is leaving too much water on the carpet
Sounds as though the machine needs a good clean before using again. Remove all the dirt, grease and hair from the transparent areas by removing the covers and then reassembling. Also this can be caused by running the cleaner too fast across the carpet.
Aug 26, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Removing cover for the powerbrush
there are two screws on the front of the clear plastic end. take off those two and your set.. Be carefull when you pul it back...
Apr 06, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Which is the best caprpet steam cleaner mid priced?
I would recommend the Hoover brand. The Bissell's are very problematic, they have belts that break and issues with the heating elements. Hoover Steam Cleaners can be repaired and are simple to use. The price range is generally $180 - $300
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Jan 24, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell pro heat 2x multi surface carpet cleaner making spots
maybe there's not enough vacuum or it hasn't been primed enough. I have a proheat that drove me crazy till I started leaving the heat switch on. I get wads of carpet fiber that mat around brush and spit out on the carpet, so I frequently remove them. I'm just wondering if after you empty the water, it may not have built up the suction. Good luck! hope this may be helpful
Jan 13, 2009 | Bissell 1699 ProHeat Clear View Upright...
BISSELL PRO HEAT X2 CLEAN SHOT
Try checking the lint filter. It is located in the top clear plastic section (the one with the dial to switch from floor to tool use) and is on the underside. It is a small (1 inch square) red plastic filter with a little door on it. Open the door and you will probably find it is clogged with hair, carpet fibre., etc.. Clean this out and you will hopefully have suction again.
Nov 19, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissel Proheat Carpet cleaner
My Bissell had the same problem. The hand attachment does not use heated water. So I Found a clog of calcium and dirt in the heater portion of the unit. The heater is in the handle behind the red heater light on the front. Remove the upper portion of the handle. Remove the lower two screws in the lower portion and the parts will split apart. Remove the hoses and remove the heater. (mark where the wires go) The bottom of the heater can be removed with a screwdriver. The tubes leading into the heater is where the clog was but there was a lot of debris inside Make sure to clear it all and the hoses as well. I put it together and it works great.
Nov 23, 2007 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
928 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
