Question about Whirlpool Washing Machines
Our washing machine stopped going into the spin cycle.
Our washing machine stopped spinning and doesn't empty water. The dasher still works. What could be wrong? We have a belt underneath the tub that doesn't seem to be in the right place. Do you have a schematic for a Model LA7680XTN0
Frances Halvorson
We went to the Sears' parts store and ask them about the problem. (They sell Whirlpools) They gave us two probabilities and we're going to try the cheapest on first.
Thanks.
Frances Halvorson
Posted on Jun 26, 2009
My kenmore elite topload washer is leaking underneath washing machine leaving a puddle whats causing this?
depends. first and foremost, I would fill the unit up about halfway with water, with tub being empty of any clothing. Tilt the machine back where you can look underneath it real good. see if you see any leaks with it half full of water. If you don't see any leaks, put the unit back on all fours, and put it into drain/spin. After tub empties of water, tilt unit back again and check for leaks near the drain pump and hose. If you need any further assistance, look for me on 6ya
Nov 27, 2015 | Kenmore Washing Machines
Noisy on spin cycle
It's very difficult to advise on a noisy washing machine because you can't describe noises accurately enough. People often describe the same noises quite differently.
Generally though, if a washing machine is rumbling, and noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on washing machines due to water getting into them if the drum bearing seal fails. To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings have probably gone.
Another drum bearing failure symptom is excessive up and down play in the drum which can be checked for by lifting the drum up and down from the drum lip behind the door seal. A further symptom of drum bearing failure is a brown rust patch underneath the washing machine and down the back of the outer drum, underneath the drum pulley (where the belt goes) There are usually two small holes at the back of the drum bearings where water that has got past the drum bearing seal trickles out, and it's usually stained with grease and rust.
Other causes of a noisy washing machine are coins and other obstructions inside the water pump. This will cause noise when the washing machine is emptying the water. Coins or other obstructions can get trapped between the outer tub and the inner drum. This would produce a lot of noise on spin as they coins get tossed around inside. Usually, spinning the drum by hand will not reproduce the noise in the case of coins as the coins drop to the bottom of the tub when the washing machine isn't spinning.
A light scraping noise when the drum is turned by hand is usually a bra wire trapped between the tub and drum.
A high pitched squealing or harsh noise can be motor bearing wear. This can also be checked for by taking the belt off and running the motor alone.
A knocking noise can be a loose tub weight. This would be worse with heavy loads and would not be present on spin with no washing in. This is because the knocking noise is caused when the tub (or outer drum) shakes about on spin. Without washing inside the drum the tub doesn't move. Another symptom of a loose tub weight is grey concrete dust under the washing machine.
It's very tempting to ignore noises while the washing machine is still otherwise working. Some noises can be ignored as they will not develop into serious faults. Other noises, if left, will cause extensive damage and can end up costing considerably more than if tackled early or these days writing the washing machine off. Of course the problem is that you can't tell which of the categories a noise falls into - so ignore them at your own risk.
Jul 28, 2012 | Roper Washing Machines
Washer will not spin at all no code . will drain and tumble back and forth,when it comes time to spin it turns off.
A washing machine is basically a big tub that repeatedly fills with water and then drains, spins to wring clothes dry, and has a device for stirring things up-- either an agitator in the middle of a top-load machine or a rolling drum in the case of a front-loader.
The four cycles that every washer performs are fill, wash, drain, and spin. Though these functions are pretty basic, a number of things can go wrong with them.
There are a number of problems that you can fix quite simply; some issues, however, are better left in the hands of an appliance repairperson.Problems that commonly occur with a clothes washer are discussed in depth below.If your washer doesn't run, be sure it's plugged in and that the receptacle works (the circuit hasn't overloaded). Before working on the washing machine, be sure to unplug it.
To prevent problems, follow good maintenance procedures. Use the right amount of detergent for your washer and your water hardness, make sure the machine is level, and don't overload it for the cycle chosen.
Washing Machine Does Not Fill
If the washer doesn't fill, the water inlet screens may be blocked. Clean or replace them. (Check your owner's manual for the location of the screens; they're often located at one end of the supply hoses, or you may have to remove a panel to access them.) Other reasons for not filling may be that either the timer or temperature selector is broken--both of these are repairs for an appliance repairperson.
Washer Does Not Spin
If your washer doesn't spin, check to see if the clothes have jammed or are unbalanced in the drum before calling a repairperson. Unbalanced clothes will also cause a w
asher to shudder or "walk." If straightening out the load doesn't stop the washer from shaking, look at the feet underneath and be sure they are properly adjusted to keep the washer sitting level on the floor (you just turn them to move them up or down).
Clothes Are Wet After Spin Cycle
If your clothes remain wet after your washer's spin cycle, perform the following diagnostics:
1) Lift the lid during the spin cycle. If the tub is not spinning, you may have a damaged motor coupler. Call a repairperson to replace this part.
2) If the tub is spinning, recheck the load to make sure it is balanced. If you are certain the load is balanced but your clothes are still wet, you may need to call a repairperson to replace a damaged motor pulley, tub bearing, belt, or clutch.
3) You can also follow the troubleshooting steps outlined in "Washing Machine Doesn't Drain." You may have a problem with your drain hose or pump.
Oct 27, 2011 | Washing Machines
My washer, A612S, does everything correctly but SPIN in the spin cycles. Both belts underneath are fine. The motor pulley spin fine when in the spin cycle, but the belt doesn't. When I turn it off...
the brake it the drum directly above the transmission pulley it is not intergrated into the trans.
in my almost 30 years of repairs in that old and very reliable machine i would find where a article of clothing and floated over the inner tub and has wedged itsefl between the inner and outer tub, their is enough clerance between the tub and tub cover where you could get finger into it and run it around the tub and feel if a piece of clothing is caught. if that isnt the problem then the tub bearing is ceased up and would require repalcing it and the tub seal
Jul 18, 2011 | Maytag Washing Machines
Noisy drum bearing also play on drum
Apr 30, 2011 | Washing Machines
My hec washing machine is not spinning and the water wont empty
Try turning the spin basket, something may have jammed itself inside the tub. You can remove the front kick panel and remove the tub to pump hose to clean it out.
If ok, you might have other problems like a broken belt in the back.
Sep 25, 2009 | Washing Machines
Bosch washing machine wont spin or empty
PAV2300 Top Load Washer This washing machine tutorial will show you what to do if the washing machine does not drain or empty the water out this repair was done on a Bosch, Neff and Siemens type appliance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 20, 2009 | Maytag PAV2300 Top Load Washer
GE top load washer does not agitate or spin.
sounds like a bad lid switch how old is it?
Dec 29, 2008 | Washing Machines
Tub doesnt spin after wash or rinse cycle
if it goes thru the wash cycle , is NOT a belt problem , what could be is a sensor switch located underneath where the door closes , its like a latch switch for security when it goes to spin, hope its helpful AJ
May 14, 2008 | Washing Machines
Avanti W797: Tub won't spin or water does not empty.
Had the same problem. The water pump is not working and since it cant drain water it wont spin. A easy fix. There's a magnet located on the water pump thats comes lose. Simply tie it back into place.
Nov 20, 2007 | Avanti Top Load Washer W797
Washing Machines Logo
64 people viewed this question
Dan Webster
Dan Webster
Sal De
