Question about Dyson DC25 All Floors Bagless Upright Vacuum
Hose attachment On my dyson dc 25 the hose attachment is very hard to pull off. It seems like something is getting hung up when i try to pull up the hose.
    Sniper:
  • 83 Answers
Your wand is getting stuck in the hose because the hose is twisted - you need to unwind it:
1) Pull the wand up as far as you can, all the way if possible
2) Stretch the hose out and unwind it, use some babypowder on the metal part of the wand and in the future, unwind and stretch the hose out after you use it
3) If you can't get the wand all the way out, remove the canister from the front, push the button where you see the 7 vertical grooves (on the opposite side of the hook that you wind the cable around) - then pull on the hook and pull the hose up and off of the machine - stretch the hose out from the bottom and pull the wand out - now apply baby powder to the metal rod and disconnect and stretch and unwind the hose every time after you used the wand to clean.
Posted on Jul 30, 2009
My Dyson DC25 keeps blowing off the filter that is inside the ball assembly. It then "catches" inside and does not allow the ball to rotate freely. Will a replacement filter solve the problem?
Posted on Nov 23, 2009
Stiff hose on new Dyson Animal upright
You need to call Dyson, but bet this is as designed.
Dec 19, 2016 | Dyson Vacuums
How do you get the extension off then its raised all the way to the top?
Hi there, it's Jack at Dyson.
DC25's instant-release hose and wand are designed to detach quickly and easily when you need them. There are no fiddly clips or buttons to press - when you extend the wand upwards to it's fullest extend and pull it firmly, it should separate from the main body of the vacuum:
If the wand seems jammed, or you continue to have difficulty removing it, our experts are on hand to take some further details and provide assistance. You can reach the Dyson Customer Helpline by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Mar 16, 2015 | Dyson Dc 25 Animal
How to release stuck vacuum hose head on Dyson ball vacuum
Yes thay can do that just put your mind to it
Aug 05, 2014 | Vacuums
My wife just purchased a refurbished Dyson DC25 off Amazon. I noticed that the handle will not lay down very far. At most it seems to recline 40 degrees. It seems like it is hanging on the someth
http://dysonmedic.com/ - Check out these guys - they might be able to help or at least they do have a manual online you can look at
I’m happy to help further over the phone at https://www.6ya.com/expert/charles_6bf94c079488b145
Jul 25, 2014 | Dyson Dc 25 Animal
The telescoping wand on my Dyson DC 25 will not retract back into the hose.
Hi Nina, it's Jack at Dyson.
Difficulty collapsing the wand can mean that the plastic handgrip section hasn't been correctly placed on the machine. When you replace the wand on the machine, make sure the handgrip section clips onto the main body and is down as far as it will go.
It's also a good idea to make sure that the hose isn't twisted, as a twisted hose can create resistance as you try to collapse the wand. Remove the wand again and allow the hose to untwist itself fully before attempting to replace the wand on the machine.
I'm confident these steps should resolve the issue, but if you would like some further guidance after you've given this a try, please give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Mar 20, 2014 | Dyson DC-25 Lifetime Washable & Reusable...
Wand stuck in handle dc 25 dyson vacuum
Hi Connie, it's Jack at Dyson.
If you're having difficulty removing the wand from the machine, this may be because the hose was twisted when the wand was last replaced on the machine after use. This is simple to resolve following the steps shown in the video attached.
I'm confident this will help, but if you'd like any further advice you're welcome to contact our experts directly. You can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US) or 1-877-397-6622 (CA).
Feb 23, 2014 | Dyson Dc 25 Animal Upright Bagless Vacuum...
Cannot release hose from handle DC 25
Try to raise the wand first. Then the hose will follow it as you pull it up.
Jan 28, 2014 | Dyson Dc 25 Animal
Cannot get the hose from the uprightdc25
If you're unable to remove the hose and wand from your DC25, it's likely the hose was twisted when the wand was last replaced on the machine after use - this can prevent the wand from extending correctly. It's easily resolved by following the steps shown in the video attached.
I hope this helps, but if you'd like further advice after you've given this a try, please give the Dyson customer Helpline a call on 0800 298 0298 (UK), 01-475-7109 (IE), 1-866-693-9766 (US), or 1-877-397-6622 (CA).
Jan 28, 2014 | Dyson Dc 25 Animal Upright Bagless Vacuum...
Hose in DYSON too tight and hard to pull out
The problem is not a twisted hose. The hose itself is way too stiff. It pulls the vacuum around instead of expanding to reach. I hate this hose and it's too bad, because the vacuum works well, but trying to use the hose attachment it futile because it just doesn't stretch out unless the vacuum is pinned up against something to keep it from rolling and tipping over.
Nov 24, 2012 | Dyson DC25 Vacuum
Dyson DC25 All Floors Bagless Upright Vacuum Logo
1,168 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
