Question about Brother DCP-7020 All-In-One Laser Printer
Brother DCP-7020 Scanner Lock Problem
We can only print from the computer, no copying, because apparently the scanner is locked. I saw a post similar to mine to which someone suggested flipping a switch "near the scanner bed" but the only switch we can find is the Power source. We've tried powering off/on to reset but no luck.
    President:
  • 2,306 Answers
According to Brother there is no switch for this model, you can just power off and on again. Sounds like it needs to go into the shop.
Posted on Jun 25, 2009
4 wide horizontal blurry lines in printed document
Either sensitive drum of the tonner is damaged or the high temperature fuser roller damaged. Check and replace.
Nov 17, 2015 | Brother DCP-7020 Laser Multifunction...
How to replace paper feeding kit on DCP 7020
Most likely all you need is to clean the rubber feed rollers. Use alcohol.
Oct 24, 2014 | Brother Industries, Ltd DCP-7020 Laser...
Why won't Brother DCP 7020 Scanner connect to computer?
Try opening the Scan function from the computer and pull it from the MFP printer instead of being at the scanner trying to push it to the computer. Your Brother DCP 7020 would have to be on the same network and installed on the computer you are trying to use. Check your usb cable, Ethernet cable or if wireless - check the Wi-Fi connection settings (network name and correct passphrase).
Aug 30, 2014 | Brother Dcp-7020 All-in-one Laser...
Replacing pick up roller
you can safely replace the pickup roller without stabilising the document scanner and the laser scanner.
replacing the pickup roller is a relatively simple job that is easily done by someone who is good with their hands or with a little common sense.
here is a video showing the procedure
and a link to buy the part
Mar 28, 2014 | Brother DCP-7020 All-In-One Laser Printer
I have a black line down the right side of the entire page.
If it is just on copies then you may have a bad scanner, the way to tell is to select reports and print one, if it's clean then the scanner is the problem, if it has the lines too, it could be a worn out fuser assembly.
Aug 25, 2009 | Brother DCP-7020 All-In-One Laser Printer
Brother DCP 1200 printer/copier...won't copy/print
The scan lock is the switch on the left side of the printer above the fan outlet. You flip the switch to lock it before moving the printer. Flip the switch to unlock the printer
Mar 05, 2009 | Brother DCP-1200 Laser Printer
SCANNING WITH A BROTHER DCP 7020
I cant find the machine DCP-7020 but I think this machine is the same with model MFC-7420 if you have the installer CD follow these steps:
For USB Interface Cable Users
For Mac OS® 9.1 to 9.2
& Software
1 Turn off and unplug the MFC from the AC outlet and disconnect it from your Macintosh, if you already connected an interface cable.
2 Turn on your Macintosh.
3 Insert the supplied CD-ROM for Macintosh into your CD-ROM drive.
4 Double-click the Start Here OS 9.1-9.2 icon to install the printer and scanner drivers. If
the language screen appears, select your language.
5 Click MFL-Pro Suite to install.
6 Follow the on-screen instructions, and restart your Macintosh.
7 Connect the USB interface cable to your Macintosh, and then connect it to the MFC.
DO NOT connect the MFC to a USB
port on a keyboard or a nonpowered
USB hub.
8 Plug in the power cord and turn on the MFC.
9 From the Apple menu, open the Chooser.
10 Click the Brother Laser icon.
On the right side of the Chooser, select the
MFC to which you want to print.
Close the Chooser.
The MFL-Pro Suite, Printer driver and Scanner driver have been installed.
To install Presto! PageManager, click the
11 Presto! PageManager icon and follow the on-screen instructions.
Presto! PageManager has been installed and the installation is now complete.
You can easily scan, share and organize photos and documents using Presto!PageManager.
Dec 11, 2008 | Brother DCP 7010 Multifunction Laser...
Brother DCP-7020 All-In-One Laser Printer Logo
767 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
