LCD Screen not working
We can not darken copies or enlarge. The LCD screen is not working.
All it can do is take regular copies.
  • 1,326 Answers
That depends on what kind of copier you have??? It could be on the control pannel or it could be inside the front cover or it could be a user setting? I don't know with out a make and model.....
Posted on Jun 27, 2009
Lcd screen does not work
Make sure the LCD screen has not been darkened or dimmed.
Jan 27, 2016 | Sewing Machines
My screen words is very small. i am trying to enlarge them.please help
enlarge it through windows control panel in the display section you can enlarge objects on the screen which also increases the word size or change the screen resolution
Nov 17, 2013 | Envision EN-7100e 17" Flat Panel LCD...
How do you enlarge on the HP309A SERIES
  1. Use the following guidelines to determine which setting to choose:
    • Copying an original to letter or A4 paper : Choose Fit to Page , or choose Full Page 91% to prevent unwanted cropping.
    • Copying a legal-size document to letter paper : Choose Legal > Ltr 72% .
    • Copying a photo to full-size paper : Choose Fill Entire Page .
    • Copying to a custom size : Choose Custom 100% , use the Up or Down arrow buttons (c01314741.gif ) to reduce or enlarge the size of the copy, and then press OK .
  2. On the LCD screen, choose Copy from the options (use the arrow buttons) and press OK .
  3. Press the Settings button (the button below the Home button) twice, to access the Copy Settings menu.
  4. Select Size and press OK to access the copy size options.
  5. In the Copy menu, use the arrow buttons to select the appropriate size settings. Press OK to continue.
  6. Press Start Copy Color or Start Copy Black .
Mar 05, 2011 | HP Photosmart Premium C309A All-In-One...
Toshiba satellite p35-s609 screen darken.
It is almost certainly the LCD inverter which is the cause of your issue. It ism ore common for the inverter to develop a fault than a backlight bulb on the LCD (I used to work in a Toshiba repair centre).
Replacing the inverter should be simple, just make sure the unit is powered off with the battery removed so you don't get an electric shock.
Hope this helps,
www.PuterCare.com
Jul 13, 2010 | Toshiba Satellite P35-S609 Notebook
My PS3 screen is too large for my regular TV
Did you ever find a solution for this? Mine has done this and i dont know if the kids hit a setting or what happened.
May 11, 2010 | Sony Playstation 3 (PS3) Console
Darkening the copies
Here's information from the HP manual:
Use the copy features
The HP All-in-One enables you to produce high-quality color and black-and-white copies on a variety of paper types, including transparencies. You can enlarge or reduce the size of an original to fit a specific paper size, adjust the darkness of the copy, and use special features to make high-quality copies of photos, including
borderless copies.
Press Copy repeatedly to display the appropriate menu. The following menus are available:
– Number of copies
– Reduce/Enlarge
– Copy Quality
– Copy Paper Size
– Paper Type
– Lighter/Darker
– Enhancements
– Set New Defaults
2. Press the until the appropriate setting appears.
3. Do one of the following:
– To change more settings, press Copy.
This selects the current setting and displays the next menu.
– To start the copy job, press Start Color or Start Black.
To save the current settings as defaults for future jobs
1. Make any needed changes to the settings in the Copy Menu.
2. Press Copy repeatedly until Set New Defaults appears.
3. Press until Yes appears and then press OK.
This should help you.
Feb 20, 2009 | HP Officejet 5610 All-In-One InkJet...
Reducing/enlarging on Canon MP 160
The only option I see that comes close to this is the "fit to page" option described on page 35 in the manual. Apparently, it detects the size of the original and enlarges it to fit on the paper size selected. Otherwise, I see no options for enlarging or reducing while copying.
May 13, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Lcd darkened windex screen.
hello
try the following:
try first of all to clean the screen using a wet towel because the problem might be that the windex has made a dark layer on the screen ...
if this does not work then if u have a vacum machine that can can get the screen dry by blowing air on it...this might work
if not then you have to send it back to the manufacure
good luck
Apr 21, 2008 | HP Pavilion dv6000z Notebook
Scanned documents are very light
I have found that when scanning b/w documents, its helpful to start with a black and white copy, not a grayscale, pen written, or printed form a printer in grayscale mode copy, but a true black and white on the copier or fax copy. The scanner doesnt read shades of black so well and when scanning multiple page documents, my pixma tends to scan in lightly. I havent found a piece of software to do just this, batch darken what has been scanned (at least not for free). Copying before scanning is the work around. Hope this helps everyone who's had this problem. It also doesnt hurt to darken what your scanning down a notch when copying
Mar 21, 2008 | HP PSC1510 Printer/Scanner/Copier...
52 people viewed this question
k24674
jasbo
jasbo
