Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Ice maker stoped working
I have a GE Profile (TFX25PR). The Icemaker stoped working but the water dispencer still works. I have replaced the dual valve for the water but this did not solve the problem. There is no watter getting to the ice maker. I have tried the stop arm in both positions.
    Problem Solver:
  • 19 Answers
Ice maker Diagnostic Test:
- Remove the ice bucket
-Turn the ice maker off, wait 15 seconds than turn it back on
-Press the ice paddle three times, this will begin diagnostic test.
-PLEASE DO NOT TOUCH ICE MAKER DURING DIAGNOSTICS
-In 3 minutes you should see the rack inside turn 360 degrees
-AND the ice maker bowl should fill with water
-IF either DID NOT work, call 1-800-GE-CARES for ice maker replacement. A service call is approx $80. The $80 will be deducted from the part/labor if you choose to purchase/install parts from the service technician. If not, you will pay for the service call. Good luck.
Posted on Apr 05, 2010
MY ICEMAKER STOPED MAKING ICE ,I GE WATER BUT NO ICE..HEKP.
The ice maker not working: ---
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
Oct 18, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Model TFX25PR ; Does the ice cube maker require any lubrication ?
The type ice makers made for your model and other models require no lubrication and are one of the most used parts of your refrigerator especially if there is a large family and lots of ice used daily. They never seem to stop working while the average refrigerator last 15 to 20 years the average life of an ice maker is only 5 years. Even ice makers that have replaceable parts the repair parts are more expensive in most cases than complete replacement. Below is an example of an average ice maker that Whirlpool and Maytag uses that have the Teflon coating in the ice slots. Your model is for GE,=> Model WR30X10093 Ice Maker and has electronic controls and no replaceable parts. Thanks, Sea Breeze
Jun 05, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
GE model # GSS25JFMCWW has water to the dispencer,but not to the icemaker.
could be a number of thing,s The device that sends water to the ice/mak is different than the door water the ice maker has it,s own brain (circuit) water in/out some built into the frig itself . The ice /mah send siginal to water valve to send water.. to ice maker sorry icall appl man sorry
Mar 18, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Icemaker not working
The ice maker valve is a dual one. with 2 solenoids. One solenoid operates the water and the other the ice maker. So if the water works that don't mean the ice maker supply is ok. The ice maker itself controls the flow of water. So if the water valve is ok then the ice maker is faulty. I have repair photos HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 14, 2010 | Refrigerators
After 2yrs of not using the icemaker, moved
Good day,
Pour water from small paper cup until it near fills the well of the ice maker. With the lever down, close freezer door and wait 2 to 3 hours. If it dumps then the ice maker should be good, if not, replace ice maker.
If dumps O.K. then the dual water valve is bad, and needs replaced.
You should check the fill tube that runs from the back of the machine to see if it is blocked with ice. (requires removing ice maker) but even so, if it is iced, you'll need to clear, but the water valve in the back rear of the machine is leaking and still needs replaced.
Thanks for using FixYa
Dec 20, 2009 | Refrigerators
Ice maker in our GE profile refrigerator is not working
Nov 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE REFRIG
Most likely your water control valve for the icemaker side, you can check the ice maker by filling with water and when freezes and if dumps then the water control valve. Part number WR57X10032
Sea Breeze
Aug 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Icemaker does not make ice after first harvest.
theres whats called a cam inside of the ice maker and that is more than like;ly the problem. you can but your own ice maker from place like first service. good luck.
Jan 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
782 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
