Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
I have changed the user name and i forgot it now i want to access my router
  • 53 Answers
The only way to get back in is to reset the router:
To reset the router, locate the reset button (hole) on the rear panel of the unit. With the router powered on, use a paperclip to hold the button down for 10 seconds. Release the button and the router will go through its reboot process. Wait about 30 seconds to access the router. The default IP address is 192.168.0.1. When logging in, the username is admin and leave the password box empty.
Posted on Jun 26, 2009
2 Suggested Answers
worldvet
  • 859 Answers
SOURCE: access
.For 2Wire you use IE or FF and enter this URL or the alternative depending on your service provider:
http://192.168.1.254
http://192.168.0.254
The user name is Admin and the password is usually blank on first use or is "admin" without the quotes. If that doesn't give you access to your router you need to contact your Service Provider who can access your router via the phone line assigned to it and reset the user name and password once they verify you have authority to do this.
Regards,
Worldvet
Posted on Jun 11, 2008
Forgot my wifi password
John,
If you cannot remember the password, then you will have to reset the router. There is a small reset button either on the back or bottom of the router. Using something small (pen, pencil, paperclip, etc), press the
There should be a small You'll need something like a pen or pencil to push it in. Push it, hold it pushed in for about 5 seconds, release. After that, the router should reboot and you can access the router menu by typing 192.168.1.1 in your browser.
The default user name and password depends upon your device type. If you are not sure, look at the data label on the unit. Google [your router name] default user name and password. You should find a result that will provide you with what you need to access the administrator menus.
Unfortunately, when you reset your router you will lose all your programmed information which you will have to reprogram.
Probably not what you want to hear, but you will once again have control of your router.
Mar 18, 2014 | Linksys Computers & Internet
I went to this: http://192.168.1.1/ Still can't change my settings... Many people can access it since there's no password... How can I put a password? Can I reset the whole router itself? I want to...
The easiest thing to do is reset the wireless router by pressing and holding the button on the back of the router for 30 sec. Then hook your computer directly into the router and follow the instructions outlined on the user manual.
Mar 12, 2011 | Computers & Internet
I forgot my password and need help on how to retrieve it or change it.
There is a reset button on the back of the router; just use a paperclip to poke it. Then the default settings will be restored, and the username/password should both be admin
Mar 02, 2011 | Linksys WRT160N Wireless Router
Unable to access setup for my linksys by entering 192.168.1.1, not sure whats wrong
For information on how to change your router's password, click here. All Linksys routers have built-in web-based setup pages that allow the user to customize settings and set up advanced properties.
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or 4 ).
Accessing the Router's Web-Based Setup Page
NOTE: To learn how to reset your device to factory default, click here.
Step 1:
Open a web browser such as Internet Explorer.
3714-015.png Step 2:
Go to the Address bar and enter your router's IP Address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
  • Running the router's setup CD.
  • Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
  • Check the router's IP address.
  • Press the Reset button at the back of the router for 30 seconds.
NOTE: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the username and password will be "admin" after resetting.
Step 3:
A new window will prompt for a User name and Password, type "admin" (this is the default user name and password), then click OK.
4525-003.png NOTE: If the user name and password of the router has been changed, type the router's new user name and password on both fields instead. In case the router login is forgotten, you will to reset the router.
NOTE: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the username and password will be "admin" after resetting. To reconfigure the router, refer to the links below:
  • To configure the router with DSL ISP, click here.
  • To configure the router with Cable ISP, click here.
Nov 13, 2010 | Linksys Wireless-G WRT54G Router
I need to get into my nat settings
All Linksys routers have a built-in web-based setup page that allows the user to customize settings and set up advanced properties.
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or4 ).
NOTE:To access the router's web-based setup page using Mac, click here.
Step 1:
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Windows XP
Windows 7
NOTE:
If the password of the router has been changed, type the router's new password in the Password field instead.
The router's password can be changed by:
i. Running the router's setup CD. Click here to learn how to download firmware.
ii. Changing it on the router's web-based setup page. Click here to learn how to change password on the web-based setup page.
Unable to Access the Router's Web-Based Setup Page
Reset your router for 30 seconds. Try accessing again using the default IP address "192.168.1.1". If you are encountering problems accessing the router's web-based setup page, click here.
Related Articles:
Setting-Up WPA Wireless Security on a Linksys Router
Changing the Wireless Network's Name (SSID) on a Linksys Router
Setting-Up a Router with DSL Internet Service
Downloading at Linksys by Cisco Support Site
Nov 09, 2010 | Linksys Wireless-N WRT150N Router
Linksys no longer appears on my laptop for some reason. how do i restore it. i can't go on line without it?
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 08, 2010 | Linksys WRT160N Wireless Router
How do I find Key# for a new PC. The PC with the actual LInksys Admin Program was on PC that crashed and couldn't be fixed
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 07, 2010 | Linksys Wireless-G WRT54G Router
Forgot user name and password
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 06, 2010 | Linksys Wireless-G WRT54G Router
Forgot password and user name??
If you forgot your user and password of router then press RESET button of router for 10 seconds it is in back side of router. Then all settings defaults. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi . If you want to secure wireless then enable WEP in wireless security enter password there it is your password to connect wifi.Then save settings and restart router. Let me know if you need further assistance. Thanks for using FixYa.
Sep 05, 2010 | Linksys Wireless-G Broadband Router
ROUTER ACCESS ON 192.168.1.1
This happens due to user restrictions on your router make sure the user name and passwords.
If u forgot them u can reset the router by pressing the reset button on router. After some time the router will start and u can access the router with default passwords.
Hope this will be helpfull.
Mar 10, 2009 | Linksys Wireless-G Broadband Router
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
117 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
