Question about Sony STR-DE545 Receiver
Have Sony de str545 I cannot put on rear speakers
Have Sony de str545 I cannot put on rear speakers on,even I followed up all instructions,as well when I want to make stup,and I set all speakers ,including rear,when I enter setup(confirm),just pop up on display digital cinema without rear speakers,I tried to reset receiver .seems that this mode with all speakers cannot be selected,some advice
4 Suggested Answers
  • 23 Answers
SOURCE: Sony STR-SE501 makes popping sound/cuts off
just repaired my se 501 poor solder conections on blue rleays by speaker jacks,also blown center speaker seems there are 2 in it one blew and so did cpacitor running now just hooked up one in center speaker sonds great also stay at 8 ohms setting
Posted on Jul 17, 2009
SOURCE: Speakers pop and rear speakers cut out of surround sound
your problem is a bad solder connection of the relay linked to the lautspeaker sockets. I had the same problem and googled for the solution. Since I resoldered the pins everything is fine. That problem is well known and happens to a lot of Sony receivers.
I can send you a link with a detailed how-to-do solution with pictures, however it's written in german language. But you can use some online translators.
Here is the link: http://www.bmw-syndikat.de/bmwsyndikatforum/topic.asp?TOPIC_ID=28280&FORUM_ID=20&CAT_ID=9&Forum_Title=Geplaudere&Topic_Title=Problem+Sony+STR-DE445
Ralf (from Germany)
Posted on Feb 15, 2009
remington870
  • 48 Answers
SOURCE: Getting the best out of my Sony STR DE-475
Yes, it would downgrade.
Simply run an HDMI cable to the LCD from the DVD player. Now, use the digital audio output of the DVD player to run to the receiver. I know the Sony has an optical input which i recommend over the coaxial input as the optical cable doesnt waste any energy as a medium transferring sound since its only light.
Posted on Mar 31, 2009
I have bose speakers connected to a sony receiver and I want to chance the sony receiver to a bose receiver without changing the wires on the speakers. The sony receiver was old and has stopped working. ...
Hi.
Even though you may need to put new plugs on the ends of the wire, you can still use the wires without having to go out and by new.
Places like Radio Shack, Fry's, Ovation, BestBuy, and CompUSA all carry wire plugs that you can install yourself rather easily on the old wires to make them work with the Bose receiver.
Putting plugs on the ends of the wires is really a simple thing to do.
Just follow the instruction that comes on the pack, and you should be fine.
I don't blame you for wanting to utilize the old wire, it can get expensive to replace speaker wires.
The plugs are a cheap way of saving wire, and saves you quite a good deal of money as well.
I hope this helps you out, and good luck !
Jun 07, 2011 | Bose Cinemate Digital Home Theater System...
How do i connect my klh bassbite V subwoofer to my sony receiver model str de335?
http://www.docs.sony.com/release/STRDE335.PDF
I am basing hookup on my Bassbite !! manual. The procedure should be the same as on your Bassbite V
I have given you a link to your Sony Owner manual. It looks like you will connect your sub to the sub output on the rear of your reciever using the rca cable. Woofer out on the Sony to the R/Mono input on your Bassbite. If you have the front and rear speakers hook your rears into the rear speaker outputs then connect your front speakers to the front speaker outputs of your Sony. Your speaker jacks on the Bassbite will not be used for this configuration.
Now, adjust your speaker size setting for "SMALL" or "LARGE" speakers as appropriate for your setup (this is for the front and rear speakers and will not effect your Bassbite). Now set your Sony subwoofer output to "ON" You access this setting through your menu. That should be located on your remote for the Sony. You will want to refer to the manual to find the exact method to access your system menu.
If the link to your manual doesn't work for you then go to http://esupport.sony.com/US/perl/model-documents.pl?mdl=STRDE335 and click on Operating instructions.
Hope this helps. Let me know okay? By the way, if this works for you you should be very pleased with the sound quality :-)
Kindly, DAVID (sean1dave)
Feb 26, 2011 | KLH ASW10-120 Subwoofer
Does the 510 reciever have enough power to drive 2 100watt 8 ohm floor speakers LOUDLY?
no doubt it will do it,even with four of them but your receiver will get hot depending of the length of playing,go to your sound field selection,put it onto ( multi st. ),increase your front and rear speaker level to 10.0 ,in the selections put your front and rear speaker size to large and u enjoy your product,i got four 140w pure acoustics speakers onto the receiver and it plays perfect
Oct 01, 2010 | Sony STRDH510
Sony STR DE845: rear speakers not working, three fronts are OK.
The rear amp is malfunctioning (duh). Take it to a tech for a real diagnosis.
Sep 05, 2009 | Sony STR-DE845 Receiver
How do I fit a Sony XR-C450RDS car stereo to my Ford Focus without the wiring fitting instructions? Could you tell me which wires should go where?
Radio Constant 12V+ Wire: Orange/Light Green
Radio Ignition Switched 12V+ Wire: Yellow/Black
Radio Ground Wire: Black or Black/Light Green
Radio Illumination Dimmer Wire: Light Blue/Red
Radio Antenna Trigger Wire: N/A
Radio Amplifier Trigger Wire: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Light Green
Right Front Speaker Wire (-): Dark Green/Orange
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Wire (+): Tan/Yellow
Left Rear Speaker Wire (-): Gray/Light Blue
Right Rear Speaker Wire (+): Orange/Red
Right Rear Speaker Wire (-): Brown/Pink
Hope this helps.
Aug 31, 2009 | Sony Car Audio & Video
Replacing factory radio
Buy adapter harness from stereo shop simplifies problem and keeps factory harne in tack.
Jun 19, 2009 | 1999 Chevrolet Suburban
Replaced rear factory speakers now have low volume
Factory speakers usually have low resistance ( 2 ohm) When replacing speakers with aftermarket, most aftermarket speakers will be 4 ohm. If you want the same sound you may have to buy some resistors to put on the speakers (across the + and -). By putting a 4 ohm resistor across the connectors will now make the speaker 2 ohms which in effect will raise the volume. Depending in what vehicle you replaced the speakers the resistance will vary.
May 18, 2009 | Sony CDX-GT500 CD Player
Rear speakers do not work
Either the balance is off on the head unit, or the the out puts (in the head unit) for the rear speakers are blown.
May 15, 2009 | 2002 Mazda 626
Ralf (from Germany)
Jan 07, 2009 | Sony STR-DE445 Receiver
I have a honda civic 1992 and i buy a sony car stero i have problem with de wiring like red goes with red black goes with black but de others color from my honda civic are difent can i have an ide
Battery
White/Yellow Stripe
or White/Blue Stripe
Accessory Yellow/Red Stripe Ground Black Illumination Red Dimmer Red/Black Stripe Power Antenna Yellow/White Stripe Left Front Speaker (+) Blue/Green Stripe Left Front Speaker (-) Gray/Black Stripe Right Front Speaker (+) Red/Green Stripe Right Front Speaker (-) Brown/Black Stripe Left Rear Speaker (+) Blue/Yellow Stripe Left Rear Speaker (-) Gray/White Stripe Right Rear Speaker (+) Red/Yellow Stripe Right Rear Speaker (-) Brown/White Stripe
Oct 19, 2008 | Pie Hon03 F/Mm Car Stereo Wiring Harness...
Sony STR-DE545 Receiver Logo
187 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
