I need to know how to change the username on my computer which is in my c:/driver... I was able to change the name of the computer under the my computer settings... however whenever I try to save anything to the computer it keeps showing another username which is not mine..ie my name is Joan and when I save something it shows c:/Matt
  • cuddlychick_ Jun 25, 2009
    I'm using vista... I figured out how to change the resistry name.. however whenever I go into my computer and users.. the folder with the old name is still there.. How do I change that
    Scholar:
  • 119 Answers
Assuming it's windows xp, click start,control panel and click user accounts and then select to delete of modify a account.
Posted on Jun 25, 2009
Reamo memory paswerd
Step 1:
The first thing you want to do is check to see if you can get into the computer the easy way. Try signing on as a guest. If there is no "guest" option try typing in: guest then press enter. If this fails, no need to worry, just move on to the next step. If this step fails then just Hit ctrl + alt + del. Under the username put the word "administrator" and put nothing under password. Most likely this will work, since there is a secret administrators account in every computer. If by any chance this does not work: continue to the next step... If you are on the computer already and need a way to access the computer in the future without knowing the password try this: Go to the start menu, then to "control panel", click on "user accounts"... Make another account with your own password to it! This way you can sign in with your own user name and there's no need in knowing the password. The downside to this though is that the computer often displays all usernames once you sign on. Restart the computer and find out, on some computers it doesn't! This last step is a bit drastic, but you can change the password on the computer given that you are already signed on. You don't have to know the password in order to change it.
Feb 15, 2013 | PNY 2GB microSD Memory Card
What is the definition of Username? Is it my Email address?
Sometimes it is, sometimes it isn't. I am assuming you are asking this question in the terms of an operating system because it is in the operating systems section. In the case of OSs, the username is not your email adress, but usually you don't need to type in your username. For websites, it differs. Some use your email as your username, some use a unique username, and some use both.
Jul 18, 2011 | Computers & Internet
I have a nieghbor who has somehow found out my password. How can I change my password so he can't use it anymore.
you can change your wireless encryption password by going to internet explorer
http://192.168.0.1 or http://192.168.1.1
the default login/pass
  • Username = admin
  • Password = password
    • For older devices, password = 1234
if this does not work you will need to reset your router by holding the reset button for 30 seconds or more when you power it on.
  1. Use an Ethernet cable to connect a computer to any one of the four LAN ports of the NETGEAR router.
  2. In a web browser, enter the router's IP address - either http://192.168.0.1 or http://192.168.1.1 by default.
  3. When prompted for a Username and Password, enter the default username and password (admin;password) unless you have already changed it. NETGEAR recommends changing the default password to increase the security of your network.
    For Steps 4-9, refer to Figure A below.
  4. Select Wireless Settings from the Setup menu in the left-hand navigation bar.
  5. Under Wireless Network, enter your desired network name in the Name (SSID) box.
  6. Under Security Options, select WPA-PSK [TKIP] + WPA2-PSK [AES].
  7. Under Security Options (WPA-PSK + WPA2-PSK), enter your desired network password into thePassphrase box.
    • WRITE DOWN or KEEP NOTE of your network name, security option and passphrase - you will require them to connect wireless computers and devices to your network.
  8. Click Apply to save the settings.
Mar 29, 2011 | NetGear MR814 Wireless Router
How to set a security cod for wifi
This is a Quick and easy fix!
  3. When prompted for a Username and Password, enter the default username and password (admin; password) unless you have already changed it. NETGEAR recommends changing the default password to increase the security of your network.
  4. Under Wireless Network, enter your desired network name in the Name (SSID) box.
  5. Under Security Options, select WPA-PSK [TKIP] + WPA2-PSK [AES].
  6. Under Security Options (WPA-PSK + WPA2-PSK), enter your desired network password into the Passphrase box.
  7. Click Apply to save the settings.
Dec 12, 2010 | NetGear WGR614 Wireless Router
I want to set up a secure netgear wireless connection
THIS IS A SUPER QUICK AND EASY FIX!
  1. In a web browser, enter the router's IP address - either http://192.168.0.1 or http://192.168.1.1 by default.
  2. When prompted for a Username and Password, enter the default username and password (admin; password) unless you have already changed it. NETGEAR recommends changing the default password to increase the security of your network.
  3. Under Wireless Network, enter your desired network name in the Name (SSID) box.
  4. Under Security Options, select WPA-PSK [TKIP] + WPA2-PSK [AES].
  5. Under Security Options (WPA-PSK + WPA2-PSK), enter your desired network password into the Passphrase box.
  6. Click Apply to save the settings
Dec 11, 2010 | NetGear WGR614 Wireless Router
Hi, my dads ex girlfreind changed the username on my computer, i still know the password but i can only log in under a user account. to make matters worse someone broke into my shop and tried to open the...
don't worry man just if you know the password and you don't know the user name , then simple way is to change the user name from the control pannel named as user account , click on change and then write the pasword and the account name but it is only poissible when you know the current user name or the 2nd way is format the window, it is the simplest way
Aug 11, 2010 | Dell Dimension 3100 PC Desktop
I am trying to connect another computer to my wireless network but i do not know my netgear code, where do i find this?
Netgear code? Can you be more specific?
Are you referring to the password required to connect to your wireless network called "Netgear"? I assume you're being asked for a password on the 2nd computer when trying to connect to the wireless network called "Netgear".
  3. Select Wireless Settings from the Setup menu in the left-hand navigation bar.
  4. Under Wireless Network, enter your desired network name in the Name (SSID) box. This is currently set to "Netgear" most likely.
Once you've set this password, you can use it to connect to "Netgear" on your second computer.
Jul 25, 2010 | NetGear WGR614 Wireless Router
Domain not available I want to log on to my laptop. How do I change domain
click the box under the username and select XXXXXX(This Computer) "XXXXXX" for your computer name. This should log you in locally to the computer. Important to note: You need to have the same username locally as you do on the network. Most are set up this way, but not always. Good Luck!
NOLA Tech
Feb 02, 2010 | Dell Latitude D610 Laptop Computer -...
I want to know how to secure my linksys router over the internet
  1. go to web address 192.168.1.1
  2. default user name is blank, password is admin
  3. click the password tab, to change your password
  4. To change the SSID, click on the Wireless tab. Look for an input item labeled SSID. It will be near the top. Enter a new name for network. Don’t use something like “My Network”. Use a name that is be hard to guess
  5. In the same screen that you changed the name of your network, you will see options for SSID broadcast. Choose “Disable SSID” to make your network invisible. Now save all your settings and log out.
Jan 03, 2010 | Linksys Wireless-G Broadband Router
Need to move contacts in Palm Desktop to new user name
On your Palm Desktop, under username PalmUser40, select the category view of 'All'.  Then press Control + A to select all contacts. Then press Control + C to copy them all.
Then change the username on the upper right to 'misty'.  Then go to contacts, under category 'All', and then Control + P to paste all contacts.
This will most likely not keep all the category names, but all your contacts will be copied in.
Then hotsync to sync to your Palm TX.
May 19, 2009 | Palm TX Handheld
Computers & Internet Logo
David Payne
David Payne
