Question about Audiovox Vehicle Parts & Accessories
I need a wiring diagram so i can install the siren in my vehicle
  • kent homan Apr 24, 2012
    if its the cjb100pd? the 2browns are for the speaker,red +blackneg. and the blue and green are for auxillery ,such aslights.
3 Suggested Answers
SOURCE: I just received a CJB100PD
brown wires speaker,red hot,black neg, blue and green each are for tear drop or what ever you use.
Posted on Apr 24, 2012
  • 51518 Answers
SOURCE: need wiring diagram for vehicle
sorry but we need make /model to look up information .but you can google it yourself .
Posted on May 14, 2015
How to install python 594 in a diesel
install like a regular remote start alarm. You will have to tap into the glow plug wire, and change the setting on the brain to "wait to start" for the glow plugs.
If you have not installed a remote start alarm before:
1.install the siren under the hood and run the wire through the fire wall into the cab.
2. Mount antenna at the top center of the windshield then run wire around and down to drivers floor.
3. mount shock sensor with a ziptie to the steering column (as long as the steering column doesn't move/rotate)
4. separate the wires you are going to need, from the ones you won't need.(specific per vehicle):12+, Gnd, Parking lights, IGN, IGN2, ACC, ACC2, Starter, lock, unlock, brake, glow plugs...
5. zip tie and tape off the unused wires.
6. use wire diagram and find then test the vehicle wires.
7. connect RS/Alarm to vehicle, plug in antenna and shock sensor, then attach siren.
8. BEFORE DOING ANYTHING ELSE-GO INTO PROGRAMING AND CHANGE THE SETTING FOR A DIESEL !
9. now you can test the functions of the RS/Alarm,
BE SURE TO KEEP A WINDOW ROLLED DOWN, OR HAVE A SET OF KEYS OUTSIDE THE VEHICLE!
Apr 13, 2014 | 477L Ask RXTX HHU Remote
Diagram police siren
Hi Anonymous, I'm sure if you went to your local dealer they would be happy to print one out for a small fee. Good luck
Apr 06, 2014 | 2000 Harley Davidson FLHTCUI Electra Glide...
How to install the alarm speaker for a viper
from the siren 2 cables come out, one black and the other red, the red one goes to the siren output (brown wire)
Apr 02, 2014 | Remote Start System
On a DEI 514N siren, what do the 2 small wires connect to?
They are for configuring the siren for louder soft chirp or one tone siren.
Dec 28, 2013 | Dei Directed Viper Python 514n Soft Chirp...
The alarm siren on my 1996 opel astra estate does not work . if the alarm is triggerd the hazards do flash so i beleive that the alarm is working . i tried to locate the siren but could not find it . any...
Normally the siren is located under the bonnet bolted to the fire wall or on the side of the engine on the wheel arch. I have only ever seen a siren under bonnet in a place that is not reachable from underneath the vehicle in order to prevent a would be thief from cutting the wires of the siren
Aug 09, 2013 | Vehicle Parts & Accessories
Siren wiring car ALARM SIREN TO TOGGLE SWITCH/WANT TO CONNECT SO I CAN TURN ON / OFF AT A FLIP OF THE SWITCH FOR CAR HORN
The siren has two wires: connect the red wire to a fused battery source. Connect the black wire to one side of a two wire toggle switch. Connect the other wire of the two wire toggle switch to a chassis ground. Now you can control the siren by applying the ground when toggling the switch.
May 24, 2013 | 850 Back Up Alarm - 107 Db Reverse Mount
How do I uninstall an Audivox 6 tone mini siren from my 2004 Honda Accord. I didn't install this item and now it is always arming itself locking me out of the vehicle!
The siren is merely the part of the alarm that gives you an audible alert when you arm, disarm the alarm. It also alerts you to intrusion and tampering. The siren does not arm itself and lock you out.
Locate your valet switch and turn the ignition on, press and hold the valet switch, count to five and release. the unit will be in valet at this point. Locate the model number and report back for the instructions to disable the passive arming.
Aug 12, 2012 | As9903 Mini Six Tone Siren For Car Alarm
Can you provide me with a wiring diagram of a 24v relay that operates a 240v siren?
Hello
If you are in need of wiring diagram for a door security siren, using 24v relay, just inform me. I've the wiring diagram and installation manual to so many models of such devices in a book form, and in PDF format. Inform me is this your need. OK.
Dec 26, 2011 | Toys
I have a Gemel Serpi Star alarm gr40 fitted to a 1991 bmw E36, I need to find a wiring diagram, can anyone help. Thank you
Im trying to fit an E90 siren to my E36. Were you every able to get the siren working? please email me at weber.ryan1@gmail.com either way
Apr 21, 2010 | Anti-theft Alarm System 3 Series E90 E92...
Vehicle Parts & Accessories Logo
519 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
xxxxxx xxx
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
