Question about Xtant 403A Car Audio Amplifier
Amp ran really hot now the red and amber lights are on and no sound
  • aarmstead Jun 25, 2009
    I will try this, the fan is not working, where do I get a new one or have this one checked?
    President:
  • Xtant Master
  • 1,114 Answers
Pull the cover off the amp and check the fan and boards, dust buildup in these amps will cause it to shut down use "dustoff" or similar. do not use a rag. These amps need to be checked every month or so or you will get what just happened to you. If you still have an issue, post a comment and I will help you troubleshoot some more. Hope this helps
Posted on Jun 25, 2009
The red triangular light on my 1800 watt kenwood amp is flashing and i do not know what to do to fix it. no sound is coming out of my subs
i have a smaller kenwood amp but it has the same triangle, i had that problem too, so i ran a ground wire from the battery to the amp, with 12 ga wire, and then i also grounded it with the chassis ground, on the big amps its better to have really good grounds and connections
Sep 12, 2010 | Car Audio & Video
I have a technics su-v660 integrated amplifier.the voltage selector light comes on but the current drive light is intermittent .when the red drive light is on it works perfectly but only for 5 minutes then...
Unplug the power, open the case and try to locate some electrolytic capasitors is series with the audio at the channel with the problem. One of them must be blown.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs".
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
May 09, 2010 | Audio Players & Recorders
I have a technics su-v660 integrated amplifier.the voltage selector light comes on but the current drive light is intermittent .when the red drive light is on it works PERFECTLY but only for 5 minutes then...
Check for dry solder joints especially on the main power output transistor.
A blown power transistor will stop the 'Current Drive' from engaging so if the problem you have is intermittent then it is most likely dry solder joints.
Hope this helps.
Mar 17, 2010 | Audio Players & Recorders
14hp ohv engine getting very hot,briggs
Sounds like a mice in your muffler. Its stuck, stop using it, you'll be damaging the valve on the motor. Remove it and test it. Try to remove thing in, i know some people put it in the fireplace to turn it red and burn things (like mice) inside and open up things...
Aug 02, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Flashing light nothing else
Doesn't sound like a virus. Sounds like a fuse or something else is out. A red light isn't good. If the monitor is ok you get an amber light. I would suggest this monitor is gone. Sorry.
Jul 20, 2009 | Envision EN9410 19" Flat Panel LCD Monitor
What to change the color for the light in my 08 flhx can i
Red to the rear, amber to the front, no colors other than red or amber side lights read within 18" os back end and amber within 18" of front end. Any yhing else could, not will, get you cited or at least give a cop a reason to F*** with you.Now, can you what? :)
Jul 08, 2009 | 2008 Harley Davidson FLHX Street Glide
Just got this amp, and was wondering what subs I should get with this amp
Did some research and it sounds like a wicked lil amp with clean clean sound-its hard to say what subs to tell you to run because everyone has different taste- and without knowing what your setup is going to be theres no real way to actually say-the amp is made to run 3 channels -so focusing on the sub channel only i personally say get a pair of 10s or a good 12-your not throwing a ton of power so you dont have to go balls out on the subs- i personally like MTX subs and xtant is made by MTX so that wouldnt be far from home -good luck with that
May 19, 2009 | Xtant 403A Car Audio Amplifier
Xtant 403A Car Audio Amplifier Logo
114 people viewed this question
Top Xtant Car Audio & Video Experts
hoyzee1
Tom Chichester
FastHarley
FastHarley
Are you a Xtant Car Audio and Video Expert? Answer questions, earn points and help others
