I upgraded my motherboard, but now when it boot ups nothing happens. the monitor shows a boot menu (gigabyte), and flsh on and off, Is it the motherboard on the reset switch. I took it to Staples and they stated the motherbord is out-of-sync, but the do not have the tech service to fix it
    Guru:
  • 224 Answers
See if you have the operating system installation cd with you then try to repair the boot menu files howeva if that dont work out then install the operating system and that should resolve your problem.
How to Repair the Boot Sector:
If XP won't start it may be due to a damaged boot sector or a missing or corrupt ntldr or ntdetect.com files.
To replace damaged ntldr and ntdetect.com you can copy fresh files from the XP CD using the COPY command. Boot with the XP CD and enter the Recovery Console (as above). At the Command Prompt type the following (where "X" is your CD-Rom drive letter) allowing the files to overwrite the old files
COPY X:\i386\NTLDR C:
COPY X:\i386\NTDETECT.COM C:
To repair a damaged Boot Sector at the command prompt type FIXBOOT and press Enter. Then answer "Y"
Posted on Jun 25, 2009
Cant access bios or boot menu on ga-78lmt-usb3. tried changing keyboard but no luck.
Does the board work? Maybe you tried an unsuccessful BIOS upgrade?
How about explaining exactly what happens when you try hitting F2?
Mar 25, 2014 | Gigabyte Technology gigabyte Ga-78lmt-USB3...
New GA-990AX-UD3 motherboard will not boot
Thomas,
I have had a Gigabyte mobo not boot due to a pushed pin on the 24-pin mobo connector. I fixed and it booted normally. In your case it seems to be the video card. Are you using the DVI or HDMI output. Use the DVI first to setup your card on a monitor not a TV. HDMI is notorious for not working on a new build. Also reseat your video card and be sure non of the pins on the board itself are pushed in, or stuck in the out position it can happen. Also be sure your card is in the top slot or the 16X slot for the first boot. The one closest to the CPU. This may help. -Devin
Oct 25, 2012 | Gigabyte Computers & Internet
The phase 4 led on my gigabyte ep43-ud3l ights up
hi..the mother is need a complete the supply on board pin..then double cheek the memory..thanks..Good Luck...^_^
May 13, 2009 | Intel Motherboard
Can't boot after upgrade bios f6
If you flashed the BIOS and it stopped for whatever reason or you flashed the wrong BIOS version, there is nothing that you can do except to replace the BIOS IC.
  • If the system has a boot block to restore the original BIOS, use it. Refer to your motherboard documentation.
  • If not, you will need to contact the system or motherboard manufacturer for a replacement.
Mar 12, 2009 | Gigabyte 845pe (GA-8PE800PRO-R)...
My pc can't boot
Make sure the battery is facing the correct way.
Dec 25, 2008 | Gigabyte GA-6BX7 Motherboard
Replaced Mobo & Processor Nothing Working
May I know the model of your gigabyte mobo, you just replaced your unit with.
'cause it may not be compatible with the new power suply you have upgraded with.
Thanks
Sep 26, 2008 | Computers & Internet
New Mobo & Processor but nothing happening
You need to have a PSU greater than 450watts. that could be the problem..
Sep 22, 2008 | Computers & Internet
Wont boot
hi,
Ur operating system gone bad(Corrupted), you reinstall the O.S or repair the O.S depending on ur data important
Pl try it
Was this soultion useful? show ur appericiation for it
Mar 21, 2008 | Gigabyte GA-8I945P-G Motherboard
Computer stopped responding ! Nothing appears.
Try replacing the Power Supply next.It sounds like it is on its way out.
Please let me know how this works for you.
Thanks
Dec 18, 2007 | Gigabyte GA-8ID533 Motherboard
76 people viewed this question
k24674
jasbo
jasbo
