Gaggia Platinum Swing 2-Cup Coffee Maker Logo
A
Anonymous Posted on Jun 04, 2014
Call for assist 5 on my machine help? - Gaggia Platinum Swing 2-Cup Coffee Maker
Why might the thread in the upper eye of machine keep coming out
Be sure to pull at least 4 or 5" if thread tail through the needle eye. It also helps to set the needle at its highest point BEFORE beginning to stitch. To assist, grasp the two thread tails in your left hand while slowly taking the first couple of stitches.
My Cricut Explore Air wont cut
If your Cricut machine is not cutting all the way through your material, or is only scoring the material, choose a machine below for specific troubleshooting tips. Fortunately this issue can usually be resolved with basic troubleshooting.
correct cut settings.
  • Remove the blade housing, then remove the blade and ensure that there are not any bits of paper stuck to the blade or lodged inside the blade housing. Ensure that you replace the blade housing correctly into the machine. Once clean, test your cuts again. If the blade and housing are already free from debris, or cleaning it did not help, proceed to 3.
  • Try an arm buoyancy test: gently press down on the black arms that surround the blade housing and then release them. Do they bounce right back up, or do they stick or rub in any way? If they stick or rub, please contact Customer Care through one of the options below for further assistance. If they bounce right back up when released, proceed to 4.
  • Increase the machine pressure settings and try your cuts again. If this does not change the cut result, proceed to 5.
  • Increase blade depth by turning the dial at the top of the blade housing. If this does not change the cut result, proceed to 6.
  • Perform a Hard Reset on the machine. If this does not help, proceed to 7.
  • Check your machine's firmware version. If the firmware is not up to date, perform a Firmware Update using Cricut Craft Room, a Gypsy device, or Cricut Design Studio.
  • Retry your cuts with a new blade housing.
  • If the machine is still not cutting through materials, or is only scoring the paper, please contact Customer Care through one of the options below for further assistance.
  • Forced Firmware Update on the machine through Cricut Sync.
  • Retry your cuts with a new blade housing. If the issue persists, proceed to 8.
  • Attempt a Format and Restore on the machine through Cricut Sync. Please note that this step should only be taken if all other steps have failed to resolve the issue.
  • If this does not resolve the issue, please contact Customer Care through one of the options below for assistance.
  • new blade. If this does not help, proceed to 5.
  • Adjust/increase the Multi-Cut setting in the Cricut Craft Room cut preview screen and retry your cuts. If this does not change the cut result, proceed to 6.
  • Retry a cut using a new blade housing.
  • If the machine is still only scoring or not cutting through the material, please contact Customer Care through one of the options below for assistance.
  • 0helpful
    Error code 5
    Hello Tom;
    My name is Peter. I am a retired field service appliance technician.
    I would like to help you, but I need the model number of your machine. Open the door. The model number is on a label inside the door.
    Error code 5 is different for each model. Sure? Error code 5 not 5e, 5c.....
    Repost your question with the model number and I will be more than happy to assist you.
    E31 error code on electrolux washing machine
    Good Afternoon Friend,
    I understand that you are receiving an E31 error code on your Electrolux washer, model# EW1000i. In researching the model number you provided, I show that this was manufactured in the UK. For North American washers, I would suggest resetting you appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. You can try this, and if it does not work, I suggest contacting the manufacturer directly, for further assistance. They should be able to tell you what the E31 means, as well as assist in clearing it. Hope this is helpful.
    -Best Regards-
    2helpful
    Bosch washing machine model WFF1401GB/01, 10 years old, motor was replaced 5 years ago (so motor is 5 years old now). Drum has stopped rotating, pump etc all OK. Carbon brushes replaced, drum did work for...
    Check the motor control board for dry joints, poor contact, signs of excessive heat around plugs/pins
    I would try new brushes again or thoroughly inspect whether they are contacting the commutator.
    I hope I have been of help but please do not hesitate to ask if you have any further questions.
    I appreciate your vote if you appreciate my reply.
    When I turn it on it comes up with F1 I cant do any thing with it cause it comes straight up with that . I have only had it for 17mths
    The F1 error usually indicates a serious Washing Machine 'controller' or Logic board malfunctions: your washing machine should still be under warranty or may even be subject to a recall campaign due to a manufacturing flaw. You will need your washing machine details such as model number. serial number, manufacture date and proof of purchase before calling the manufacturer help desk (as your machine is over 12 months old, the reseller will not normally assist but you an always ask them for assistance first).
    To see if you have an intermittent controller issue, completely unplug the AC main plug first for say 5 minutes and replug to see if the error resets itself.
    Hope it helps.
    6helpful
    I am trying to find a code to make the Samsung dvd vr370 region free.. Can you assist?
    1/Turn machine on without disc inside
    2/Press menu button
    3/Enter region code (See below for list)
    4/A highlighted 'region area number' will appear in the upper left corner (some players)
    5/Press 9 to change the region number to multi-regional
    6/Turn machine off
    R1 - 29334
    R2 - 38767 or, 5 7 5 3 8
    R3 - 56732
    R4 - 76884
    R5 - 53814
    R6 - 24462
    I need complete part list for whirpool washing machine models AWO 5763/5;AWM320/3;AWO5963/5 and also where to source for the parts.
    Check the following websites:
    searspartsdirect.com
    pcappliancerepair.com
    appliancepartspros.com
    repairclinic.com
    The first three sites I listed have helpful exploded view parts illustrations to assist you with properly locating and identifying the parts you need.
    Make sure your model number is accurate as these listed are based on the specific number on YOUR machine. NOT the series number on the owner's manual. If this is a Whirlpool washer, the model number will be located on a nameplate located along the wash tub rim under the lid on a TOP LOADER and around the door facing on a FRONT LOADER. If you have questions, please let me know. I hope this helps you.
    1helpful
    F-5 error code on Kenmore elite HE3 45872
    Click on the following link for a full explanation of the "F05" error code:
    http://www.fixya.com/support/r629462-f05_error_code_whirlpool_duet_kenmore
    This is not a difficult repair. The error indicates a failure of the heating circuit. If you are not sure of how to diagnose this yourself, or require additional assistance, please post back and let me know. I hope you find this information helpful.
    Top Gaggia Coffee Makers & Espresso Machines Experts
    Sulejman Sulejmani
    Sulejman Sulejmani
    Mike Cairns
    Mike Cairns
    ZJ Limited
    ZJ Limited
    Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
