Question about Celestron NexStar 8 GPS Telescope
UNIT WILL ACCEPT INPUT DATA FOR ALIGNMENT, BUT WILL NOT SLEW, EITHER AUTOMATICALLY OR USING THE DIRECTION KEYS WHEN IT REQUESTS THEY BE USED. WHATS UP WITH THS THING?
This Problem has not been resolved. Guru Dev is proof that somewhere a village has lost it's idiot. This guy apparently does not speak English. Fixya is a fraud!!! Do charge me for that asinine conversation. Fixya Disconnected from me!!
Posted on Jun 26, 2009
Hard reset u602
At first switch off the device by pressing the Power button for a short while.
After that keep holding on Volume Down and Power keys until Recovery Mode pops up
Then release all keys and navigate to "wipe data/factory reset" by using Volume keys, and press the Power button to accept it.
Now select "yes" by using Volume keys to navigate and press the Power key to confirm it.
At last choose "reboot system now" by using the Power button
May 21, 2018 | Cell Phones
Percon pt 2000 handheld scanner screen is locked up and will not accept any input. We have data on it that we do not want to lose.
remove the batteries, hold the "alpha" and "enter" keys while you reinsert the batteries, but you may lose your data as that is a general reset function
Jul 25, 2012 | Televison & Video
My LX200gps 10 inch microfocuser has quit. Earlier my power button was intermittent, now it works. The handcontroller alllows you to slew, but not focus. I used spray contact cleaner in the power and...
When you plug in an outside power source the internal batteries are disconnected- automatically. First thing I would try is all new cables Sounds like the motor inside the focuser died.
Apr 12, 2011 | Meade LX200GPS Telescope
How to format of nokia 9300i
Welcome to Fixya
This process erases from your Nokia 9300 all of your user data and settings, including your phone book, calendar, email, downloads, recordings, and certain factory installed programs such as Instant Messaging and BlackBerry Connect.
REMEMBER: Create a device data backup or synchronization before formatting.
You can restore device data and settings later. See the Nokia 9300 User Guide for further instructions.
STEP 1 - Format the Nokia 9300 memory
* Remove the battery for 10 seconds
* Replace the battery
* Open the Nokia 9300 to view the inside display
* When you see the screen with "NOKIA" in blue text,
* Press and hold the following four keys until a Format Message is displayed:
CRTL + Shift + F
* Confirm the process by selecting Format
* Formatting will begin
* After formatting is complete the Nokia 9300 will reboot with some basic settings. If prompted, accept the request to reboot
* Follow the instructions on your Nokia 9300 to set the time, date and city and to enter your contact information.
STEP 2 - Download the install-cingular-default-603.SIS to a compatible PC.
STEP 3 - Prepare a Multimedia Memory Card (MMC)1
* Transfer the .sis file from your PC to your device using MMC, data cable, Bluetooth or infrared. For instructions see the Nokia 9300 User Guide.
STEP 4 - Install the file install-cingular-default-603.SIS to your Nokia 93002
Note: This step is required to install Cingular specific settings and programs to your Nokia 9300.
* Insert the Multimeda Memory Card created in Step 2 to your Nokia 9300.
* Replace the battery cover (so the Nokia 9300 can read the MMC)
* Open your device, then open the File Manager:
Press the Desk application key
Scroll to and select Office
Scroll to and open File Manager
* Using the arrow keys, scroll to Memory Card
* Highlight the file install-cingular-default-603.SIS
* Press Open to start the installation process
* Follow and accept all prompts and requests
* Reformatting is now complete
(1) You may choose to install the file above using Nokia PC Suite. Please see the Nokia 9300 User Guide for general instructions to install software using Nokia PC Suite, and follow those instructions instead of Step 4 above.
(2) CAUTION: The .sis file above is ONLY intended for use with a Nokia 9300 with the appropriate software version. DO NOT install this file to a Nokia 9300 with any other software version. DO NOT install this file to any other model device.
Have a good one!
Mar 26, 2011 | Nokia 9300 Handheld
How to format my nokia 9300i
CRTL + Shift + F
Oct 14, 2010 | Nokia 9300i Cellular Phone
Sirs: I'm the party with the "Rate Control" issue I have a new NexStar 8se.
The Rate Control only works for moving the telescope using the arrow keys. It does NOT work while doing an alignment, and GOTOs always slew at the max rate of 9.
For any other issues I would suggest you first RESET the hand controller and see if this corrects the problem and if NOT then reload the latest hand controller and or motor controller firmware, using the Celestron update cable and a computer.
Jan 26, 2010 | Celestron Optics
Celestron nexstar 8 i series alignment trouble
use the rewmote that came with the telescope and go into setup under telescope and push enter when it says calibrate motor
Nov 06, 2008 | Celestron NexStar 11 GPS (660 x 279mm)...
GOTO ERRORS MEADE LX200 10" CLASSIC
Most problems tend to be mechanical. Have you 'trained' the drive and set the backlash values? Those 2 can have dramatic effects on pointing accuracy. Also, if the optical tube is not in alignment with the mount, then nothing will work correctly. To check that, have the telescope in Alt-Az configuration, inside the house, loosen the RA lock, and shine a laser pointer on the corrector plate. as the telescope is rotated about the RA, the reflected spot should be steady. Adjust the DEC to minimize the diameter of the circle that is drawn. What is left, is the out-of-true on the DEC axis. That can be adjusted with the tube cradle alignment bolts.
Oct 17, 2008 | Meade Optics
GoTo Problem
Be sure that the telescope is configured for EQ SOUTH mode to tell it is in the southern hemisphere. Once a star alignment is completed NEVER manually move the telescope. Use only the control panel to slew. Everytime the telescope is move by hand, the motors do not know it has been done, and assume it is still pointing at the old direction. Check the manual for setup.
Here: http://www.celestron.com/c3/images/files/downloads/NexStar_SLT_manual.pdf
Apr 06, 2008 | Celestron NexStar 130 SLT (306 x 130mm)...
Meade DS-2114 ATS LNT
Also had the problem. I found that the LNT did not find north unless the bottom of the Smartfinder is close to parallel with the ground.
Oct 11, 2007 | Meade DS-2114 ATS (325 x 114mm) Telescope
Celestron NexStar 8 GPS Telescope Logo
48 people viewed this question
Top Celestron Optics Experts
Marvin
Marvin
Vernon Taylor
Lawrence Oravetz
Are you a Celestron Optic Expert? Answer questions, earn points and help others
