Question about Nokia N73 Cellular Phone
Slow open application - Nokia N73 Cellular Phone
  • 436 Answers
If you feel that your phone is slower than before please remove some data from your phone memory.
Posted on Sep 13, 2009
Screen cascades slowly when opening programs or files
two possibles
needs more memory
but before that run this disk optimizer utility to make sure files are in best order
Jun 13, 2012 | Computers & Internet
Slow to open
Is this slow when start up the computer or slow when you open an application?
If slow when start up the computer, the reason is your computer has too much start up programs and services. All these software, services is required to open as start up of the computer, that reduce speed of log on/ start up process. You can speed up by try these steps:
1. Start - Run: type: msconfig and hit enter.
2. The System Configuration Window will appear. Click on Selective Startup. Then go to Start up tab, untick the process that you think it not importance for start up such as Acrobat Reader...ect. 3. Then hit apply and restart your computer. You can disable all of start up services.
If slow when you try to open an application, then the reason is your computer busy work with some other higher piority process. If you think that you need this application open quicker, you can go to Task Manger and End the task you don't want it run or the task that took a lot of CPU resources.
Hope this will hellp
Thanks for reading.
Jul 20, 2011 | Computers & Internet
My e 63 is getting slow and stuck for last few days after when i installed an application while using net & xplore was open in background please help me now its very slow and take too much time to...
The application is either too big to be easily supported with your phone and its probably taking too much space on your phone,look for a simpler version of the application that you installed in your phone....
I would suggest for you to delete that apllication and free your phone memory....
Dec 17, 2010 | Nokia E63 Cell Phone
Internet 8 is very slow. I can open outlook e
When an application gives problems the best thing to do is UNINSTALL and then reinstall the application.
Be sure to do a DISK CLEANUP and then a complete virus scan thereafter.
Mar 14, 2010 | Microsoft Internet Explorer 8
My blackberry has become very slow all of a sudden.
Applications on the blackberry do not close when opened, each application you open consumes memory. Also the working memory and the memory to store programs are shared unless you have installed a microSD card. Remove and reinsert your battery, if a hard reset speeds the phone up your problem is open applications. If it does not, your problem is that you are out of space and need to remove some applications or install a larger capacity SD card.
Nov 02, 2009 | AT&T Blackberry Curve 8300 Smartphone
Blackberry Storm the keypad has become very slow to respond.
You don't have a virus. Just make sure that you get the over the air updates whenever available. The latter versions of the phone are much more efficient than the earlier ones. Try closing applications when not in use to speed operation. Press the blackberry button choose switch applications and then close the ones you are not using. You can also delete the default third party software that comes on your phone if you don't need it. For instance, if you never use Verizon navigator, take out a few messengers i.e. aim, yahoo, remove flicker (you can always get this applications back later so no worries).
Jun 30, 2009 | RIM BlackBerry Storm 9530 Smartphone
Lg kg300 speed become very slow
How much extended memory are you using with your handset. The speed issue could be due to higher capacity memory card usage.
And about applications, so let me tell you, applications like Opera Mini are always been slow on LG KG 300.
Apr 05, 2009 | LG KG300 Cellular Phone
I can't remove the real player from my mobile htc -
hey lucky man... u r lucky to find me.. hehe
well i call u lucky man, because my fren use tytn too
here's the problem he has (which i think it occurs to you too)
when you do multitasking (open a lot of application together), it consume the memory of your PDA , so much that it cause low memory, therefore, it became slow, slow, and slower, until it finally get 'hang' condition.
what you must do with this memory consumtion is, check everytime u open and close application, did you close perfectly, or it just closed to background (it is still running, you just don't see it on the display) - u can see if it's still on the list of running application (menu)
second, if there's still low free memory, then i suggest you to erase not useful application or just format, remember to backup ur datas.
thrd, if ur internet (which u said is slow is the problem) still run slow,try it on other pda or device.don't tell me that the internet connection is sucks on all phone but all this time you blame your PDA, hha..
if it only run slow on ur phone, then format it, if still slow, try another browser like opera mini, or any browser which compatible to yours.
Good luck..
Nov 13, 2008 | HTC TyTN Smartphone
Netopia routers2247NWG/slow download speed/
Actually the application may be games or any other software which it setted port is not open/accessable through your router and it will work by default ports and the speed or the performance is very slow- Try to configure proper port forwarding according to the application port settings check those ports are open after configuration
Hothawk
Jul 14, 2008 | Computers & Internet
Nokia N73 Cellular Phone Logo
41 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
