Question about Acer Aspire 5500 5570-2609 Laptop
Laptop not chrging even with a good harger.and keeps shuttn down
Hi, my laptop is not charging and its definately not the fault of the charger cos i made sure dere us a flow of electrons in it,i think da problem may have to do with the pin at the charging point. Any suggestions?
  • 66 Answers
You could be correct about it being the pin at the charging point. what you need to do is to phone up the company who make your laptop and tell them the problem. they might then say that the laptop might have to be taken away so that they can change the charging point in your laptop and then it should be fine.
Posted on Jun 25, 2009
96% plugged in, not charging Hi all, my Asus
Laptop battery do have a specific lifespan, specially for older units. Still, you can check that your charger are working properly, using a voltmeter (do check the outer label of the charger for actual voltage output).
You may try to do my Tips on Laptop battery
Good luck
Tedmac
Oct 17, 2013 | ASUS Computers & Internet
I have a compaq presario cq61 and have been having problems with the charger for quite a while but money is an issue so cannot get a new one just yet, the laptop has 2 lights to aknowledge that the...
YOUR PACK IS NO GOOD
IT MUST RUN WITH NO BATTERY
PACK CONNECTED
SINCE IT DONT THEN THE CHARGE IS WEAK TOO.
YOU KNOW PACKS CAN BE
GOOD
BAD
OR WEAK, OR EVEN ON FIRE, (loL)
Mar 01, 2017 | HP Compaq Presario CQ61420us Notebook
Hp pavilion dv-7-1245dx --keep shutting down after a few seconds
If the computer's battery is bad it won't stay on. If the fan is plugged up and over heats quickly, then the computer will shut itself down. I would start with those. Wouldn't be bad to check that your memory chips are in securely as well.
Jan 06, 2011 | HP Pavilion dv6000z Notebook
My daughters Acer wont charge so the battery is dead. The laptop wont even come on when the charger is plugged in but i have an Acer an charged her battery in mine then it charged and it worked in hers. Is...
first try to use your charger into another laptop, if the the another laptop was charged using your charger, it means your battery is the problem, but if it is still not charging it means the problem is your charger. then try your battery to use it into another laptop, as same as the i mention in the charger, if they or both fine, maybe the problem is the batery terminal of your laptop.
Dec 07, 2010 | Acer Aspire 5315 Notebook
How To charge Phone
try on ebay, for a charger for your phone. it is a good possibility that you can buy one for a dime.
Jun 16, 2009 | Lands Phones
Ac Adaptor not working??
as u said that when u plugged in the ac adaptor into the laptop it recognises that the ac adaptor is connected but it does not charge the laptop in this case what u can do is that if have the same charger extra then u can try with the another charger and if the other charger also does the same thing then in this case u need to replace the mmotherboard and if the other charger is working fine in this laptop then definately chage ur aac adaptor.....good luck...
thanks
Jan 25, 2009 | HP Pavilion dv6000z Notebook
Hp power supply failiure
Ive worked on a friends G7000 series laptop, since it had the same symptoms you have with yours.
I tested it on my own(identical) working charger/PSU and still no charging.
After taking the motherboard out, i traced the fault to a short circuit FET (field effect transistor) with the PCB reference of PQ1, located right next to the connector for the DC power jack loom.(short from gate to source) The FET is made by Fairchild Semiconductors and its part number is FDS6675BZ. Being in the UK, i ordered the part from www.farnell.co.uk at a cost of 56pence. After changing this FET(which is there to control power) the laptop is working.
If you are not good with very intricate surface mount soldering, then i suggest you buy the component, take the motherboard out of the laptop(not too hard) and take them both down your local TV repair shop for them to check and change it(tell them the board reference PQ1).. shouldnt cost more than £20 or so been as they dont have to fault find.
Martin
martinkwashere at hotmail dot com
Feb 26, 2008 | HP Pavilion dv6000z Notebook
Help
sounds like you have an intermittent problem with your AC adaptor or dc input jack. Does the light on the AC adaptor light up when you plug it in? If it does then your dc input jack may be faulty. If the light on the ac adaptor does not light then replace the ac adaptor. Good Luck!
Sep 16, 2007 | Toshiba Satellite M30-S350 Notebook
Acer Travelmate 270 - battery problem?
IT sounds like your laptop or powersupply/charger is at fault. Try to use a different charger, and if possible use your battery in a different computer. That way you can narrow down where the problem is. It might ba a faulty connection where the charger is connected to your computer. To check this out, try running the computer on AC without the battery installed. If it suddenly shuts off it's a problem with your powersupply or possibly the connection plug in the cimputer.
Apr 24, 2007 | Acer TravelMate 270XV Notebook
Acer Aspire 5500 5570-2609 Laptop Logo
55 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
