Question about Dell Inspiron 6400 Notebook
I Have a Dell Inspiron 6400 with Vista and It seems I am getting a memory or motherboard issue as the Caps and scroll lock LED's flash when I switch on and hold the FN key. Basically the laptop is not getting past Post. I have tried switching the Dimms out and trying them solo in each slot but to no avail. I bought a 1GB Dimm to see if that worked but that does not help. Is the way forward to get the motherboard fixed or is there something else I can do? Fixing the motherboard seems to be pricey. Thanks.
  • Rob Kean Jun 26, 2009
    Thanks for the suggestion.
    So are you saying that there is nothing else I can try ? It is a motherboard problem??
    Sorry but nothing from my orginial question has really been addressed.
  • Rob Kean Jun 28, 2009
    OK. Thanks. My worst worries look right then.
    I've contacted a local company to see what they charge but will likely go down the route of getting a new one and selling what I can off the old one.
    Cheers.
  • Dell Master
  • 32,281 Answers
Getting the motherboard fixed may not be a cost effective solution.
You can salvage some of the components to use eg. the RAM and the hard disk.
Put the hard disk into an USB hard drive adapter case and use it as an external USB hard drive for backups etc.
Posted on Jun 26, 2009
  • Chris Hingee
    Chris Hingee Jun 26, 2009
    The motherboard is faulty, it can't be fixed easily, they are usually replaced and the cost may not be worth it.
  • Chris Hingee
    Chris Hingee Jun 28, 2009
    You can use the hard drive from the laptop. Put it into an USB hard drive adapter case and use it as an external USB hard drive for backup etc.
In dell inspiron 1525 laptop, all light blinking but display not coming
If you mean that your Num lock , Caps lock, and Scroll lock LED's are all flashing then this indicates there is a problem with your motherboard.
Jun 22, 2011 | Dell Inspiron 1525 Notebook
Dell inspiron 1501 caps-lock and scroll-lock flashing
Hi
You probably have a mother board issue. Most likely the video chip. Take this to a reputable repair person or check my website www.micromendllc.com.
May 13, 2010 | Computers & Internet
I have a Dell Inspiron e1505 laptop that just won't come on.
hi, your laptop led`s are also there for diagnostic purposes, if the caps lock and scroll lock (the one on right of caps) are flashing before going off, it means your system is not detecting the RAM so either your ram has failed or the motherboard is faulty
Jan 14, 2010 | Dell Inspiron E1505 Notebook
Switch on and the caps lock and scroll lock lights flash, but nothing else happens
Your memory chips are loose. remove and reinsert them. That flashing is an error code, indicating no memory. unless someone stole your chips from you, they are merely loose.
Oct 26, 2009 | Dell Inspiron 6400 Notebook
Inspiron 6400 doesn't start.
On Flash Flash indicates that no RAM memory is being detected. So remove both RAM modules, insert 1 at a 30 deg angle till the gold contacts cannot be seen, then lock it in place, and see if the RAM is detected. Test both modules in both slots, see if system will boot with at least one. If no change, try a new RAM module, if still no change, replace the motherboard
Jul 04, 2009 | Dell Inspiron 6400 Notebook
Dell Inspiro 6400 not starting up
If the Num lock is lit constant, and the Caps Lock and Scroll Lock keys are flashing, the system is reporting a memory error. Power off the system, remove the battery, and follow the user manual from support.dell.com to reseat the memory module(s). If the error persists, you may need to replace the memory and/or the system board of the portable.
Mar 12, 2009 | Dell Latitude D600 Notebook
Computer wont start
Turn off the laptop completely. Unhook the battery and ac adaptor. Go ahead and reseat the memory just to make sure its seated properly. Then go ahead and only hook up the ac adaptor and turn it on to see what happens. If that doesn't work then turn everything of and put the memory in the other slot and then turn the laptop on to see if you get video then, if not then your motherboard is bad.
Feb 09, 2009 | Dell Inspiron 6400 Notebook
Dell Lattitude C840 Laptop
The 3 LED's (Num Lock, Caps Lock, Scroll Lock) are used by Dell to diagnose no-post issues such as yours. The only error code close to yours is [Num Lock ON, Caps Lock FLASHING, Scroll Lock ON]. This indicates a a memory error. Try reseating the memory modules. If you have 2 memory modules, insert one at a time to determine the faulty module.
Sep 21, 2008 | Dell Inspiron 8200 Latitude C840 Laptop...
Dell Inspiron 600 Laptop, stop working.
This is generally a problem with the battery or a memory chip. Start by removing the battery and starting up on the power supply only. Dell batteries are notorious for causeing a no start. Then try removing the memory and try one chip at a time in both slots. If neither of these work, then I'm afraid you have a failed system board component, ans you will probably want to take it in for a professional diagnostics. Also, you can find a diagnostics light codes list for your machine at Dell's support site.
Aug 06, 2008 | Dell Inspiron 6400 Notebook
Dell Inspiron 6400 Notebook Logo
140 people viewed this question
Alun Cox
