Question about Health & Beauty
When key is turned on ,the green light and battery condition indicator do not light up. The headlight and rearlights DO work,but nothing else will operate! The batteries are not very old,and voltage coming out of the motor controllor is 25.8 volts. I have checked the fuses and they all seem to be working.Please can you help,I need my scooter!! Thankyou,regards Rod...
  • 1 more comment
  • rod3301 Jun 25, 2009
    I am not convinced that the expert is knowledgable on my TGA Supersport mobility scooter.
    The details i posted describe exactly the fault that has occured!!!.
    is the system voltage regulator the printed circuit contained in the grey plastic box to the right of the motor controller?
  • rod3301 Jun 27, 2009
    Thanks for the help,ive not received any answer that is of much help.
    Regards,Rod...
    President:
  • 2,187 Answers
You may want to check the terminals, it may need cleaning. If it checks out OK, you may want to check the wiring if they are connected properly. The lights as far as I know would have a different route. Should there be issues with the wiring to the starter and ignition system, it may not affect the rest.
Posted on Jun 26, 2009
    Top Expert:
  • Health & Beauty Master
  • 80,407 Answers
REPLACE THE SYSTEM VOLTAGE REGULATOR
Posted on Jun 25, 2009
    Brigadier General:
  • 3,917 Answers
Okie there are a couple tests you need to do before we conclude to get the battery checked.
  • Check the power transmission system. If the motor runs when the throttle is applied but the rear wheel does not spin that points towards a worn out rear wheel freewheel mechanism, or a missing drive belt, chain, or sprocket.
  • Test the battery or battery pack. Test the Voltage level of the battery pack, it should be above its rated Voltage level, even if it has been fully discharged or in storage. If a battery packs Voltage level does not bounce back to above its rated Voltage level within a few minutes after the scooter has been driven that points towards a defective or worn out battery or battery pack. When a battery or battery pack has been charged overnight and its Voltage level is below its rated Voltage level that also points towards a defective or worn out battery pack. Good scooter battery packs will bounce back to above their rated Voltage level within a few minutes after being discharged.
    • Test the battery charger. Test the battery chargers output Voltage. Its Voltage level should be above the battery packs rated Voltage. If the chargers output Voltage level is zero or not above the battery packs rated Voltage that points towards a bad charger.
    • Test the charger port. The charger port should have the same Voltage level as the battery pack. If the charger port has zero Voltage level that points toward defective wiring or connectors between the charger port and the battery or battery pack.
    • Test the fuse or circuit breaker. If the fuse looks blown out or does not have continuity that points towards a blown out fuse. If the circuit breaker does not have continuity when reset or will not reset that points towards a defective circuit breaker.
    • Test the brake lever switch. The brake lever switch informs the speed controller to turn off when the brakes are applied. When this switch wears out it usually locks on which turns the speed controller off. An easy way to test this switch is to disconnect it from the speed controller and try to run the scooter. If the brake lever switch is the problem the scooter will run only when it is disconnected
    • Test the motor. Remove the chain or belt from the motor. Disconnect the motor wires from the speed controller and connect them to a good 12 Volt battery. If the motor spins freely then it is good. If the motor does not spin that points towards a bad motor.
    • Test the throttle. Testing a hall-effect throttle requires a 4.3 Volt DC power source and a Voltmeter. Apply 4.3 Volts DC positive to the throttles red wire and 4.3 Volts DC ground to the throttles black wire. Attach a Voltmeter between the black wire and the green or blue wire and twist or push the throttle. The Voltmeter should vary between zero and 3+ Volts. If the throttle has zero or low output Voltage that points towards a bad throttle.
    • Test the power/key switch, wiring harness, and connectors. Test the power switch or key switch for proper operation and continuity. Test the wiring harness and connectors to make sure they are good.
    Speed controllers problems can be difficult to diagnose. Testing the other components of the electrical system first is the easiest way to see if the speed controller is working or not.
    • Test the speed controller. Speed controllers are too complex to easily test. Using the process of elimination is the best way to see if a speed controller is working or not. If all of the other components of the electrical system test good but the scooter does not operate that points towards a defective speed controller.
  • Thanks for contacting Fixya
    When i put the key in ignition it has power but when i go to start it nothing happens, not even a click.
    Sounds like either the battery has insufficient power to turn the engine over, or solenoid is stuck the starter motor. A quick check for the battery condition is to turn the headlights on for 10 seconds. If they dim very quickly or do not come on at all, then the battery will need a trickle charge. Check the battery indicator if one fitted or remove the tops from the chambers. Please be careful when removing these as battery contain acid and can be very corrosive, depending on battery condition. If headlights stay on for more than 10 seconds suspect solenoid being stuck.
    Good luck. S
    Jan 12, 2016 | 2001 Mitsubishi Montero Sport 4WD
    TURN KEY NOTHING
    CHECK FOR 12 VOLTS AT THE BATTERY WITH A VOLT METER. TURN ON HEADLIGHTS AND HONK THE HORN TO CHECK BATTERY CHARGE . CHECK FOR LOOSE OR CORRODED CONNECTIONS AT THE BATTERY. BE SURE YOU ARE IN PARK. THE NEUTRAL SAFETY SWITCH CAN CAUSE THIS CONDITION.
    Apr 09, 2015 | Cars & Trucks
    I have a 1996 BMW 750 IL The battery is at full charge but when I turn the key to start there is nothing – lights are on seatbelt indicator on but no power to the starter can you help me with this
    Turn on your headlights and try to start the car. If the headlights go from bright to dim or off , then the battery or it's connections are bad, or loose or corroded.
    If the headlights stay bright, then the problem is likely the starter or it's connections.
    Hope this helps.
    Mar 29, 2015 | BMW 750 Cars & Trucks
    How do I fix HI beam headlights?
    your switch is not good try to double check your switch.
    Mar 09, 2015 | Kia Spectra Cars & Trucks
    How to find an electrical disturbance in 1998 ford expedition
    Normally this condition is the result of a poor body ground connection. Testing for this can be deceiving. At the static(nothing on) condition, testing can show a good ground. However when a circuit is excited, it has a determined resistance and a set current flow. If the ground connection to this or a branch circuit is loose, corroded, or broken wire. This will allow just enough connection to show as being good, but not good enough to complete the circuit with the required amount of connection when energized.
    Nov 30, 2014 | 1998 Ford Expedition
    Saab troubleshooting
    Points to poor earth contact on left rearlight
    Apr 16, 2014 | 1997 Saab 900
    Cannot start 2000 Dodge Grand Caravan
    No preferences as to charger, as long as it has trickle charge option (slower, but better for battery). Would like to see battery load test done by parts store to see battery condition, but a simple charge may be it. Let me know how it goes, hopefully you will have it up and running soon.
    Jan 15, 2009 | 2000 Dodge Grand Caravan
    1989 toyota corrola hatch, headlights not working
    The headlights just might be a fuse/relay problem, switch or wiring. It would be needed to check for the presence of +12VDC from the fuse, headlight switch, relay, 3 terminal connector. Of course the bulbs themselves must be checked.
    Taillight gone on braking indicates loose ground on the rearlight assembly. A temporary workaround is to provide another grounding screwed to the body of the car.
    Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
    Good luck and kind regards.
    Thank you for using FixYa.
    Jul 24, 2008 | 1989 Toyota Corolla 2 Door
    Health & Beauty Logo
    74 people viewed this question
    Top Health & Beauty Experts
    Robin Hill
    Robin Hill
    wcdoc1953
    wcdoc1953
    Are you a Health and Beauty Expert? Answer questions, earn points and help others
