Question about HP Photosmart C7180 All-In-One InkJet Printer
Won't print properly. Have cleaned the head and run the alighment program. Keep getting a Print Cartridge Alignment Failed message. No black at all even thought I put a new cartridge in.
  • spindrift462 Jun 26, 2009
    Opened it up and found the deep blue ink feed over the print had failed and spilt everywhere ....have just gone out to buy
    a new printer
  • 72 Answers
Printing HP Photosmart C7180 All-in-One Printer
GO TO THE FOLLOWING LINK:
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?rule=21160&lc=en&dlc=en&cc=us&product=1153754&lang=en
Have a good day,
Posted on Jun 25, 2009
Black ink will not print
Have you tried setting the color to black cartridge only. You may be printing the black with a combination of colored inks. I occasionally have a similar problem. Sometimes I can get the black to work by taking a paper towel dampened with distilled water and holding it against the cartridge print head until I see black ink coming out. Replace the cartridge and try printing again. If this doesn't work try a new cartridge and run through your Printer Settings, making sure they are all set properly.
Mar 17, 2014 | Hewlett Packard Printing & Imaging HP...
Black lines on print, new printer
Go to the settings on your computer hit properties and do an alignment, sometimes if you take out the ink cartridge and put it back in it will say do you want to do an alighment, then after the page prints you have to scan it, then pick which one looks the best
Jan 28, 2014 | Canon PIXMA PRO-10 Professional Photo...
Alignment failed when run
If Printer heads health condition is not good, alignment wont completes..
Four individual cartridges & Two print heads, each print head prints two colors.. Black& Yellow, Cyan & Magenta.. Verify which color is not printing properly(Color missing Or white bands)..
Perform 2 or 3 times print head cleaning through printer menu..Try for alignment.. If success end.. if no, replace the print head which is not printing properly.. Before replacing the printer head ensure that cartridge ink should be above 30%...
Oct 07, 2012 | HP Officejet Pro L7680 All-In-One Printer
My HP officejet pro L7580 has stopped printing black. The cartridge has been replaced ( HP original) . Other colours are fine. Printheads are fine. Error message on display: Alignment failed - Refer to...
On this HP the print head is not part of the cartridge. How do you know the print head is fine? Did you just try to do a test page without an alignment?
I know that HP (they suck) will not help you because you are past warranty - Google your question since I am sure that you are not the only person to have experienced this issue.
I think you have a bad print head.
Sep 18, 2017 | HP Officejet Pro L7580 All-In-One InkJet...
Printer doesn't print black
if the cartridge is not flowing...I would NOT soak it in water as that can flow back into the cartridge...remove it and use a q-tip with rubbing alcohol to clean...then you can use toilet paper to rub across it to make sure its flowing...you should get a solid black line...be sure not to touch where the electronics connect to it...if you do, clean it with the alcohol also
Aug 28, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Hi anyone there
Clean the encoder strip with alcohol free glass cleaner and a couple of qtips. The encoder strip is the clear strip of plastic that runs behind the print head assy the width of the printer it tells the print head where it is in relation to the page. If it is dirty you will have a hard time with alignment
Jul 17, 2009 | Canon PIXMA MP780 All-In-One InkJet...
C6180 failed alignment test, will not print color properly
All colors need to be present to pass alignment. Usually what I see is the yellow is empty. You can blot the print cartridge on a damp paper towel to verify the inks are working and this also cleans the head.
Jun 29, 2009 | HP Photosmart C6180 All-In-One InkJet...
Printer keeps showing : Press enter to align cartridges. After doing this it then prints out an alignment page and shows: Alignment failed please: Press enter Alignment failed. This goes on and on. I have...
I have found that if I put in an old aligned page the printer reads it as and the alignment is accepted. As for the cancelled message being in the window, I have had this problem too. I've ignored it and selected the copy button and it took the command. The only problem with hitting cancel is that you cannot turn off your printer. Every time you do you have to repeat the aligning and cancellation process.
May 02, 2009 | HP Officejet 5610 All-In-One InkJet...
Ink cartridge alignment problem
well, what i did, and it seemed to work, in the short run anyway. i took and threw my hp in the back of a waste management truck,  then i called amazon.com and i ordered a new epson printer,
Oct 26, 2007 | HP PhotoSmart C4180 All-in-One Color...
HP Photosmart C7180 All-In-One InkJet Printer Logo
444 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
