Not getting clothes clean anymore
I have an old (circa 1990) Kenmore washing machine. I've noticed over the last year or so that my clothes are no longer coming out clean. The washer seems fine--no noises, vibration, etc. I've tried different detergents and water temperatures. Is it just getting old or could something else be wrong?
  • baker_eliz Dec 01, 2007
    Nope. We've lived in the same place for the last 10 years. Thanks.
  • texasnitehun Sep 15, 2008
    clothes are not always coming clean. like it's not putting enough water in to completely wash the clothes.
    Problem Solver:
  • 5 Answers
Have you moved or has where your water treatment facility changed? Changes in the hardness of the water can cause detergents not to react well. A hard water test is easily picked up at the hardware store. I had a similar problem changing from well water to public system.
Posted on Nov 28, 2007
We have a Kenmore Elite washing machine (about 14 years old) and just recently I noticed that clothing that's been washed has multiple snags throughout the garment (all types of fabrics).
Look for something like a screw either stuck in the little holes or one of the screws next to the lint filter in the front. Most likely you’ve got something stuck in one little holes in it snag saying says it tumbles would be my thought. A way to check is take a rag put a glove on your hands so you won’t get cut and rub around inside to see if you feel the rag snag. Hope this helps
Dec 20, 2017 | Cars & Trucks
Maytag washer circa 1990, model LA3910. Cold water
It is possible that the cold water feed hose has started to deteriorate, this can cause restriction inside the hose. The only other things which can cause a weak feed are low pressure at the tap, which you would notice at your other cold taps as well, or a faulty solenoid valve, which you've already replaced. I'd suggest replacing the hoses and seeing if that makes a difference. (Maytag also recommends replacing the hoses every 5 years). I hope this helps.J Knol
Dec 16, 2011 | Washing Machines
I have a 4 year old Kemore HE2 that isn't spinning the water out of the clothes. I encountered this issue about a month ago and found a fix for cleaning out the hidden pump trap. After removing a large...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
Sep 07, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore top loading washing machine does not clean clothes well.
I would seriously consider getting a newer machine. A brown stain could be rust, or an oil leak. Either way it probably is not worth putting any money into. If this helps, please rate my answer. Thank you.
Jan 07, 2010 | Kenmore Washing Machines
My front load kenmore leaves faint dark streaks in
look carefully inside the tub, gasket, lid. There may be some debris of some sort stuck somewhere causing this problem.
Then run the machine adding only two cups of vinegar. this will clean it.
Aug 20, 2009 | Washing Machines
Kenmore elite washer top loading 6 years old clothes still wet after spin cylce
Click on 'washing machines', then brand name (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line. Possible your filter is clogged after these years.
And dont forget to rate me on this great site.
Jan 21, 2008 | Washing Machines
Front loader washing machine = black streaks on clothing
I am a recently retired engineer of 20 years once you have ruled out anything getting inside the machine by accident etc, like something in pockets or greasy overalls, then its likely to be the drum bearings, has the machine started to get noisy on the spin the drum bearings are covered by a rubber seal, this seal gets damaged or worn and water leaks into the bearings themselves washing out the grease back into the drum where the washing is, you could also notice slight water marks on the floor underneath the machine on the floor, take the back off and look for water marks coming from the drum outer casing behind the pulley, these marks will be brown and will originate from a small drain hole, if any of the above change the bearings before any real damage is done, either to the clothes or the machine, as repair can be expensive? sorry, hope i have helped you as to where to look at least,
Sep 18, 2007 | Kenmore 46462 Front Load Washer
Wasing machine leaves rust spots on clothes.
check the basket of the machine for rust spots on the basket if thats the case the basket should have a 10 year warranty depending on the age marks are either caused from that or the dryer. if its frigidaire the dryer then the front seals probably need to be changed make sure to find out exactly which machine its coming from
Mar 18, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
130 people viewed this question
Top Washing Machines Experts
