Question about Dell E551 15" CRT Monitor
I just Re-formatted my Dell Computer but the
I just Re-formatted my Dell Computer and the screen setting is at 640 by 480 pixels but the resolution is not clear. I cannot change the resolution from the settings. What can I do?
    Scholar:
  • 78 Answers
You need to reload the drivers for your video adaptor, or the video hardware of your motherboard.The OS is defaulting back to VGA mode because it can't optimize your display settings without the right driver. It's not the monitor that is the problem, but the signal being fed to it. Not all video cards are recognized and loaded by reinstalling Windows.
Posted on Jun 25, 2009
    President:
  • 2,777 Answers
You need to install the correct video drive. If you go to support.dell.com they will ask you for the tag number from the top or back of the computer case. This will take you to a page that has all the drivers you need for your particular computer. Download and install them and you will be good to go!
Screen resolution cannot go up from 1024 * 728
go into control panel,click on display.press open,you should see a window that says DISPLAY PROPERTIES.click on settings.to your lift it will say screen resolution.move cure on the scale to the right until you get the resolution you want.after selecting the pixels to the level you want press OK.and exit out of control panel.now try to see if it is enough,if not do the same above steps again.(GOOD LUCK0
Sep 10, 2012 | Dell Computers & Internet
How do i widen my computer screen to fit the whole screen
There are two causes of an unfilled screen her;
1) Either, you don't have drivers installed that the resolution is set to low pixels or pixels that don't match your screen type (Computer does it automatically if the drivers are installed)
OR
2) You need to set or widen the length and height of your desktop screen using the buttons on it - usually on the front. Let me know how it went so i give you plan B...
Dec 05, 2010 | Dell Dimension 2400 PC Desktop
I have a cracked screet with my my dell inspirion 1501 when i try to set it up with a dell flat screen monitor it flickers but does not recognize it and does not work.
go to your computer control panel & chec your resolutions pixels, or your hardware and sound to ajust your mobility setting.
Jun 29, 2010 | Dell Inspiron 1501 Notebook
Screen resolution driver
Download your drivers from DELL here;
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&os=WW1&osl=en&catid=&impid&SystemID=PLX_PNT_P4_GX260
Please vote 4 thumbs up for me!!!!
James
Apr 27, 2010 | Dell OptiPlex GX260 PC Desktop
Out of rangemy dell pc to tv vga connection out of range no signal
Most of the televisions use NTSC standard to receive video signals wherein the screen resolution is VGA - which is 640 x 480 pixels. If your computer screen resolution is set to a setting which is more than this, the resulting video signal will not be within the scan range of the TV; hence this error.
The simple fix is to reduce your screen resolution back to 640 x 480. To do this, right-click on an empty area on your desktop, select 'Properties'. On the resulting 'Display properties' screen, click on 'Settings' tab & reduce the slider to the setting described above.
Mar 17, 2010 | Dell Inspiron Mini 10 Notebook
The images are way to big on my computer screen
right click on the desktop > select > properties > in the display properties > click the settings tab > move the resolution selector to a lower resolution > click apply.
if it is better click the yes to keep the setting
Oct 14, 2009 | Dell Latitude D505 Notebook
I have a Dell Monitor S2209W and it does not auto adjust when I change the resolution. It is connected to is a Dell PC running Windows XP. If I do not set the resolution to 1920 x 1080 the whole screen...
The S2209W is designed to be run at the optimal resolution of 1920 x 1080 http://support.dell.com/support/edocs/monitors/S2209W/en/ug/optimal.htm
selecting a lower resolution will result in generally unsatisfactory appearance. This is due to the hard wiring of the pixels in LCD screens.
What you can do to abate the text being too small is adjust the DPI setting from the default of 96 to 120, or even 144 if you need real large text
Oct 04, 2009 | Computers & Internet
I have a dell with windows vista. the monitor is 20 or 21 inches wide screen. I recently had a friend try to install windows xp but at the last attempt he tried to reformat my computer & install it xp...
You can adjust the screen resolution to increase the size of the image to fill the screen.
Go to the Control Panel - Display - Settings and adjust the screen resolution to 1280 X 1200 pixels. If this still doesn't fill the screen then increase it further say 1600 X 1200 pixels even higher if necessary.
Aug 19, 2009 | Dell Computers & Internet
Screen resolution
you will need to reinstall your video/display drivers and make sure you download the correct ones for the site. (toshiba's site).
Jun 19, 2008 | Toshiba Equium 6200M (PV1026U-01A) PC...
C840 resolution difficulties...
The type of screen you have is a UXGA screen. the optimal resolution for that is 1600 x 1200. changing the resolution for that will distort the screen causing black borders. If a computer has a 15.0+" SXGA+ screen with an optimized resolution of 1400x1050 and the screen's current resolution is set to 1280x1024 pixels, the display will shrink resulting in a black border surrounding the edges of the screen. Also, all other lower resolutions may be stretched to fit the screen. No border will be visible, but fonts may appear slightly fuzzy.
Oct 03, 2007 | Dell Inspiron 8200 Latitude C840 Laptop...
Dell E551 15" CRT Monitor Logo
200 people viewed this question
Alun Cox
