Question about GE Cafe CGS980S Kitchen Range
When oven is turned on, display immediately indicates that the oven has reached set tempurature and fan turns on. Fan remains running for about twenty minutes after oven is turned off. Note oven has not heated. Thanks!
  • 126 Answers
Bad oven sensor or control board.oven sensor should read ~1100 ohms when cold if not replace sensor .if sensor reads good you have a bad control board.some sensors can be tested from inside oven other have to go thru back. Hope this helps please rate my solution :)
Posted on Jun 26, 2009
We bought a deDietrich oven UMP412 (Ser No 02-24-06004) on 31/08/2002. Recently the heater behind the in-oven fan blew and was replaced together with the lower heater (which was found failed) and main...
Hi Maurice.
Circulating is Fan Assisted mode. In this mode the fan kicks in when temperature is reached and runs all the time.
Here an extract from manual.
There is no preheat unless you set temperature. That is why you get the fan from start.
Oct 20, 2011 | De Dietrich Ovens
I have just replaced a fan oven element on my Tecnik TKC1285 range cooker. However, the fan now turns off when the oven reaches temperature, and the element continues to operate
Sounds to me like it is wired incorrectly, the fan should continue to run even thnough the element turns off at the correct temperature setting.
You could try reversing the connections to fan and element, this in theory should solve the problem.
Dec 31, 2010 | Ovens
I have a Fujitsu Lifebook LBS6120 notebook
Turn on as you did before and leave on for 10 minutes. Then, try turning OFF the computer by keeoing the POWER button pressed for 7 secons. If the computer goes off, then your screen is fried and the computer is actually booting up normally... you just can't see it ;)
Mar 17, 2010 | Fujitsu LifeBook E8010 Notebook
6200.5 fan works but no heat and light remains off
I suspect that from the symptons you describe that the fan oven element is faulty, the other possibility is that the thermostat is faulty, even if the element is faulty, the thermostat indicator light should come on.
Please rtate my solution.
Thanks.
Nov 08, 2009 | Kuppersbusch EEB62001 Electric Single Oven
Cooling fan won't come on unless you turn the a/c on, then i turn the a/c off the cooling fan cycles normaly but will not cycle back on.
the fan turn on point on this model comes on at a very high temp gauge reading..not far from red or about 3/4 ways up...the engine will run quite a while before reaching this level. It should never go into the red which indicates problems but the design of the system gets it uncomfortably close. I've seen these needing to idle for 10 mins or so before the engine temp reaches the fan turn on point.One good thing about this design is when the fan does come on ,one should see immediate and noticeable drop below half in just a minute or two which indicates a good operating cooling system.
Jul 08, 2009 | 1994 Saturn Sl
Lost my manual for chef condor integra oven - need to check auto functions and how to set them
For TOuch Control oven:
1. Press Finish Time touch pad
2.press ^ touch pad until clock displays the required am or pm finish time.
3. Press Cook Period touch pad.
4. Adjust the cooking time as in step 2, using up and down arrow touch pads. (hours and minutes needed to cook food)
5. Press Automatic touch pad.
Press Fan touch pad to select fan speed. Red indicating light shows normal speed.
7. Turn oven thermostat to desired setting.
8. Press Keep Warm touch pad if keep warm function is required at end of cooking. 9. At end of cooking time a buzzer will sound for 1 minute and the KEEP WARM cycle will now operate until the meal is ready to be served.
10. To cancel the Automatic cycle, press Manual touch pad and turn oven thermostat off.
For Multifunction oven:
1. Set time of day.
2. Turn Function switch to Finish. 0.00 will be displayed.
3. Turn display switch + to give the required am or pm finish time. (an illuminated bar in the bottom left corner indicates when the clock display is pm).
4. Turn Function switch to Cook then turn Display switch to + till desired cooking period is displayed (hours and minutes needed to cook food)
5. Turn Function switch to Auto. The automatic programme is now ready to use.
Turn upper oven thermostat to desired setting.
If keep warm function is required, turn function switch to Cook (optional)
Happy cooking!
Jun 14, 2009 | Ovens
My oven turns off on me after only a minute never heating up fully
Could be caused by either of following;
1. Faulty thermostat.
2. Faulty thermal cut out switch. (controls power to cooling fan).
3. Faulty cooling fan (not fan inside oven).
Test thermostat by setting thermostat to low temperature like 60 oC. If oven gets much hotter then its a faulty thermostat.
To test cooling fan and thermal switch take oven out and remove top or rear panels to expose components.
When oven gets hot the cooling fan should turn on. If it doesn't then check to see if there is a mains voltage present.
If mains current exist but fan is not turning then replace fan. If mains voltage is not present then its the thermal switch.
Jun 19, 2008 | AEG B1180-4 Electric Single Oven
Exterior surface of oven gets hot when turned off
What do you mean by very hot? Is it too hot to touch? Hot enough to sizzle when a drop of water is put on it?
Oct 06, 2007 | Dacor MCS130 Millennia Electric Single...
GE Cafe CGS980S Kitchen Range Logo
145 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
