Question about Sigma 28-70mm f/2.8-4.0 DG for Sony A100K, A100
Auto-focus lens now only worka mNUlly
With Sigma 70-300 on Alpha-100, when the camera is turned on or off the lens makes a rapid clicking noise for about 5 seconds then silence. If the camera was turned on in an auto-focus mode after the noise it indicated it is in manual focus mode. The lens can be focused manually but does not go smoothly through the close-infinity range.
  • tewargin Jun 25, 2009
    Camera off, set to manual focus.
    Mount lens.
    Turn on camera.
    Noise for 5 seconds.
    Lens works in manual mode.
    Set camera to auto focus
    LCD still says manual focus and lens still works manually.
    Set camer back to MF
    Turn off camera may or may not get noise.
    If lens not at infinity and camera turned on - lens goes to infinity then makes noise.
    President:
  • 828 Answers
This is not going to get into manual, provide in it is check its angle line to see some if you use the lens connected correctly to your camera. this is happen when you are not inserted it properly. this time call an assistance to guide and fix your lens. this problem now does not belong to the manual. Its an accident that lens are defective or factory defect. Hope might this well help you. Good luck!
Posted on Jun 26, 2009
  • 315 Answers
Put your camera / lens is in MF mode then check if the issue persists...
Posted on Jun 25, 2009
IN AUTO FOCUS FOCUS RING STICKS MAKES NOISE LIKE
How new is the lens? In or out of warranty? If out or warranty most likely solution is to find a Sigma authorized repair shop because your description sounds like the auto-focus motor gear has failed. If in warranty, check out Sigmaphoto.com for repair sites and also download the SIGMA_SERVICE_REQUEST.PDF. I've only had to deal with Sigma once on warranty matter and they were very helpful, provided UPS authorization for shipping on their nickel.
Oct 15, 2010 | Sigma 70-300mm f/4-5.6 DG APO Macro Lens
The auto focus on my Sony A is not working. It
Usually the gears will strip the lens gears which tend to be plastics whereas Sony a cameras themselves have metal driven cogs....I once stripped a sigma zoom using an
A700 simply because the motor on that camera had no feedback on torque...put a different lens to check this out first...then check the faulty lens the cog is visible once you remove the rear mount.
Nov 11, 2017 | Sony Alpha DSLR-A100 Digital Camera
When the camera is turned on, the lens vibrates briefly for 4 sec.It doesnt matter if its in Auto or manual focus. It happens while turning off the camera as well. I have sent the camera to the Sony...
It is likely to be an issue with the auto focus in the lens. You will get the grinding noise even if you switch the camera on in manual focus, but not if you take pictures in manual focus.
Oct 02, 2009 | Sony Alpha DSLR-A200K Digital Camera
Front/Back Focus Problem at Sigma 30mm F1.4 Lens
Hello Abdul!
I recommend that you print this test chart: http://www.photo.net/learn/focustest/scale45.jpg
Just print it on an ordinary paper, then put it on a table, and take a picture at it from a 45 degree angle, using the center focusing point only, aimed at the thicker line in the middle. The numers are centimeters. Take the test picture at f/1.4. Make sure you have good light so you get a fast shutter time. If you have a tripod, mount the camera on the tripod prior to taking the test picture.
Then examine the picture in your computer, zoomed to 100%. Now it should be clear wheter you got back- or front focus, and how large the problem is.
Unfortunately, there is no way for you to adjust the camera and lens combination yourself, you will have to send/bring the camera to an autorized camera workshop. This is covered by the warranty.
Hope this helps!
Regards,
/Chris
Jan 05, 2009 | Sigma 30mm f/1.4 EX DC HSM for Sigma
28-80 mm sigma won't auto focus
The lens may not be a dynex type so it wont work on your 700
Nov 27, 2008 | Canon Sigma 28-80mm f/3.5-5.6 II AF Lens...
Sigma 28-300 3.5-6.3 won't focus
Did it ever work on this camera?
I have seen some Sigma lenses that are auto focus on canon film cameras but then when put on the digital they dont work right. If you have used it on this camera then make sure the lens is clean.sometimes dirt on the front wil make it try focusing on the dirt. Next try focusing in manual focus to make sure the focus is working. Then take the lens off and then put it back on and make sure it clicks into place.
Let me know if none of those things work. also make sure to try focus on something close and somthing far away.
let me know how it works,
Caleb
Jun 26, 2008 | Sigma 24-70mm F3.5-5.6 AF Zoom Lens
Not working with Sony Alpha 100
well after a week in the shop it came back working. the guy at the shop could only tell me that the repair people had fixed a problem in the auto focus (he had no other information). So the solution here is going to a place to repair your lens. if someone finds the cause of this problem it would be great
Feb 25, 2008 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Auto focus problem
My first suggestion is to send it back if it is under warranty.
The grease probably got so thick, from the cold, that it caused too much resistance for the auto-focusing mechanism. You probably have damaged the focusing mechanism in the lens. You cannot repair this, yourself. I don't know how cold is too cold but it really shouldn't have done that.... Tamron makes cheap lenses. Try and exchange it for at least a Sigma.
Dec 24, 2007 | Tamron 18-250mm F/3.5-6.3 AF Di-II LD...
Zoom lens
What camera are you using is the lens making a noise when it stops focusing  call sigma imaging uk 01707 329999
Oct 19, 2007 | Sigma AF 28-200 Lens
Sigma 28-70mm f/2.8-4.0 DG for Sony A100K, A100 Logo
65 people viewed this question
Top Sigma Cameras Experts
Steve
Doberman
Are you a Sigma Camera Expert? Answer questions, earn points and help others
