Question about RIM BlackBerry Bold 9000 Smartphone
THE A BUTTON,TRACKBALL SEND AND END BUTTON DONT WORK.. WHEN I PRESS A IOU SHOW OR WHEN I TRY TO DOWNLOAD ANY APP TO MY BB BOLD IT TAKES ME BACK TO MY HOME PAGE.
Got the sameeee pleaseeee help its driving me crazy :(
Posted on Oct 13, 2009
I have exactly the same problem. Did you fix it?
My BB Bold 9700 Does not respond with the soft reset
There are three ways you can reset the black berry phone.
1) Soft Reset - simply press the ALT+RIGHT SHIFT(CAP)+DELETE keys.
This reset stops all applications that are running on the Blackberry and will help if you are having problems connecting the device to computer. This reset will not erase any information from your device.
2) Double Soft Reset - this reset is almost equivalent to a full hard reset. First perform a Soft Reset as outlined in Step 1.
As soon as the screen is no longer black - repeat the steps once again exactly as before.
This takes you to another screen showing an hour glass. Allow the device to reset. This helps if the device has suffered a more serious error. Be aware you may loose some information from your device. A backup is advised prior to proceeding if at all possible.
3) Hard Reset - this is the full blown reset and will fully reset the device to help resolve critical errors with software or hardware. Again back up important information before proceeding if possible.
Note: For RIM models 850, 857, 950, or 957, you must insert the end of a paperclip or similar blunt object into a small recessed hole on the back of the unit and depress the switch inside. The device will reboot and be hard reset.
Other Models: With the device turned on - remove the battery for 30 seconds or more. Now replace the battery. The device will reboot and be hard reset.
Blackberry Pearl: To reset to factory defaults enter 'Options' from the main menu. Scroll to Security Options and press the trackball. Choose 'General Settings'.
Press the left soft key, then scroll to "Wipe Handheld" with the trackball and press the trackball. To initiate the factory reset, your phones security code may be required in order for the process to complete. Your phone will now be restored to its original settings on leaving the factory.
A hard reset can be achieved with the Pearl in the same way as outlined at Step 3 by removing the battery.
Be aware that resets such as these may erase data, such as contacts, ring tones, pictures, text messages and stored Internet files and emails. Make sure to back up important information beforehand if at all possible. You can obtain software to back up the device to your computer directly from Blackberry right here.
Nov 23, 2010 | RIM BlackBerry Bold 9700 Smartphone
I am unable to receive pictures, music from other mobile phone to my BB Bold 9700 through Bluetooth. Both devices are pairing but BB is not receiving sending is not a problem.
you should select the option "receive via bluetooth". in the media menu, press the menu button (the bb symbol) then select receive via bluetooth, then send the file. you will then be able to receive files from other phones.
hope this helps. also please rate. thanks!
Jul 24, 2010 | RIM BlackBerry Bold 9700 Smartphone
The trackball for my blackberry dont move to up !! :( is there somthimg that i can do ?
This is a common problem with the bold 9000 , try taking it to a dealer shop they can change the ball for a very small amount of money. Or else if its under warranty send it back to RIM.
Next time go for the New bold , they got rid of the bal l completely and they have a new track pad
Jan 31, 2010 | RIM BlackBerry Bold 9000 Smartphone
Keyboard not working :@
are u change the writing language into ABC mode from DICTIONARY mode(in message setting).If answer is NO then first change it & see the results.
And if it is already in ABC mode then i suggest u to show it in wellknown mob. shopee for repairing.
Dont take a risk,give it in safe hands.
Aug 13, 2009 | RIM BlackBerry Bold 9000 Smartphone
BB Messenger wont go through
GET THE PHONE THAT YOUR CHICK/GIRLFRIEND HAS
Aug 07, 2009 | RIM BlackBerry Pearl 8100
I have a trackball that is sticking on a blackberry bold 9000 how do you go about changing one out and is it the same size trackball as a curve
1. It is the same trackball as the curve.
2. Unlike the curve, where you can just pop the silver ring out from the front and the entire trackball comes out, on the Bold, you have to take the unit apart.
3. To take the bold apart follow these instructions:
http://www.youtube.com/watch?v=Yvs4VM5d_rk
4. Make sure that the contact underneath the trackball is not dirty. Take a QTip and some rubbing alcohol and clean the contact on the mainboard which makes contact with the trackball.
5. You can then replace the trackball from the curve into the bold, although, if you dont have a spare trackball, you can also clean the trackball with rubbing alcohol. To do this, I would put a solution of 50% rubbing alcohol and 50% distilled water (regular water is ok, but I prefer distilled). Shake it around (or better yet, use a sonic jewelry cleaner)and make sure to roll the ball around to loosen any dirt in the unit. Underneath the rollerball there is a little tab (that is called the spoon). Do not bend the spoon, rather make sure that the area between the spoon and the ball is cleaned out.
6. let everything dry and reassemble.
If you dont have a spare rollerball and want to buy one, There are many for sale on Ebay at around $5.
Aug 05, 2009 | RIM BlackBerry Bold Smartphone
Amazon.com/bb app won't download to BlackBerry Bold 9000
I had the same problems, it turns out my browser options were set to identify my bb browser as internet explore, you can also set it as firefox, once i changed it back to blackberry it worked fine, just go to browser menu options and change it.
Apr 16, 2009 | RIM BlackBerry Bold 9000 Smartphone
Trackball not working
dear gridlok
Turn the BB off. Press and hold the trackball and roll it in all directions. that should dislodge any dirt and/or lint that is covering the contacts.
Next, dip a Q-tip in alcohol and rub it all around and over the trackball. That will clean it.
Turn the BB back on and it should work as it should.
Don't carry it in your pocket or purse without the case. or) YOu need to clean your trackball.
1: Take a deep breath and blow on the trackball area, rotate and do it again. This may blow any particles block the sensors.
2: This requires a Q-tip and some alcohol. Turn off your sidekick, wet the end of the q-tip, and gently clean the trackball while rotating. Be careful not to get the alcohol on anything but the trackball. Let dry for a minute and try it out. If this doesn’t work then try again.
http://www.sidekickskin.net/archives/92 thank you
Sep 30, 2008 | Computers & Internet
When i am pressing my track ball its not responding
Get a sheet of paper or a pad of paper, put your cell upside down so the rollerball is touching the paper... Rub the phone on the paper quite vigerously. This has been a problem for me with many pearls - there is some dust / dirt lodged under the ball which stops it behaving the way it should. You may need to do this in all directions.
Mar 28, 2008 | RIM BlackBerry Pearl 8100
RIM BlackBerry Bold 9000 Smartphone Logo
214 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
ismael castillo
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
