My computer is not recognize driver
My disc drive will not read cd
  • 85 Answers
Try this, click "start" "run" then type in "regedit" then ok, in the left field, click on the "+" next to "Hkey_Local_Machine' + next to "system" + next to "CurrantControlSet" + next to "Control" + next to "Class" then click on {4D36E965-E325-11CE-BFC1-080032BE10318
} then in the right field, right click on "Upper Filters" then delete, right on "Lower Filters" then delete, restart pc. See if this helps.
Posted on Jun 25, 2009
  • 822 Answers
Clean first you disc drive with lens cleaner. there is a problem in your optical lens.
Cd/dvd drive will not recognize discs
check for new driver, or "updated driver" "firmware" for the drive that isnt working.
Jun 06, 2012 | Computers & Internet
Cd software disc will not load on to my computer. Isn't being recognized
If in case the cd was not recognized upon loading it to the computer you may do the following to check wether the cd is faulty or the cd drive.
  1. Verify that the correct disc (CD/DVD) is used when prompted to insert the disc.
  2. For programs on DVD, verify that the drive containing the DVD is a DVD drive and not a CD-ROM drive. Most DVD drives will have DVD printed on the front of the drive. For programs on DVD, consider the following:
  • DVD drives can read both DVD's and CD's.
  • CD-ROM drives can read only CD's.
  1. If multiple disc drives (e.g., CD-ROM and CD-RW, or DVD and DVD-RW, or CD-ROM and DVD-RW, etc.) exist on the computer that can read the disc (refer to the items under Step 2), insert the CD or DVD into the other drive and try the program again.
  2. If you are attempting to install a program and the installation does not begin after inserting the CD/DVD into the proper drive, refer to the program's instructions for the installation procedure.
  3. Clean the CD/DVD in the following manner:
  1. Place a small amount of nonabrasive liquid soap on the shiny side of the CD/DVD.
  2. Using your fingertips and warm water, gently rub the soap on the CD/DVD in a circular motion.
  3. Rinse the CD/DVD thoroughly and dry it using a clean, soft T-shirt or lint-free towel. (Do not use paper towels or tissue paper.)
  1. Try to use a different CD or DVD in the drive to see if that disc can be read.
  2. If possible, insert the problem CD or DVD into the DVD or CD drive of another computer to see if the issue persists.
Mar 16, 2011 | Logitech C500 Up to 1280 x 1024 pixels 30...
When I load a cd in my Stanton C324 it reads "No
Hello
Clean your CDs before and after playing them. Although the compact disc has a much longer lifespan than does something like a cassette tape, it can be more fragile. Scratches, dust or other damage to the data side of the CD will cause many CD players to fail to read the CD or cause the CD to skip.
Examine the type and format of the compact disc if your CD player fails to read it. Verify that your CD player can read the type of CD and the files contained on it. Just because you've burned a collection of songs to a CD, for example, doesn't mean that your CD player will be able to recognize that information. You must burn CDs in a specially formatted "Audio CD" mode to play them on a CD player, or your CD player must be able to recognize the MP3 file format. Some CD players have limitations on the type of CD they can read. Verify that your CD player can read CD-R, CD+R, CD-RW or CD+RW compact discs.
Update your CD player's driver, if your CD player is a drive connected to your computer. Click "Start" and select "Control Panel." Click on "Hardware and Sound" and select "Device Manager" under "Devices and Printers." Right-click the icon for your CD drive and select "Update driver software." This may solve any issues the drive was having with playing CDs.
THANK YOU FOR VISITING FIXYA
Mar 07, 2011 | Stanton C324 Mp3 Cd Player With Effects...
I put in a blank cd and I cannot burn it because in my computer it shows that there is no cd inserted
Here you go...I hope this works for you....
CD/DVD Is Not Recognized
spacer.gif spacer.gif spacer.gif spacer.gif Many times, after inserting a disc into the CD or DVD drive, the disc is not recognized by that drive. CD-read and DVD-read issues can be caused by many sources. Perform the procedures presented in this General Computer Advice article when troubleshooting CD-read and DVD-read issues.
Begin with the first procedure and continue through the list. Try using the CD or DVD after each procedure is completed. For any procedure that requires changing current system settings, record the original settings before completing the procedure.
  2. For programs on DVD, verify that the drive containing the DVD is a DVD drive and not a CD-ROM drive. Most DVD drives will haveDVD printed on the front of the drive. For programs on DVD, consider the following:
Apr 01, 2010 | LG GSA-H55N DVD-RAM Burner
I have a Dell. My Roxio prog doesn't recognize a discs
That means there is something wrong with your driver. If it cannot read any disc you inserted then the problem exist in your drive. You don't need to reinstall any driver as long as you can see your drive being recognized by your computer and you can see your drive in the My Computer with a letter indicated on it. Your drive is in need for a replacement. This problem indicates a hardware failure specifically the lens of the device.
Hope this helps..
Mar 29, 2010 | Acer (4432A-002) CD-RW Burner
Computer does not recognize it as a CD RW drive
When you try to write data to an optical disc, you may experience any of the following symptoms:
* You receive various disc write error messages.
* You experience issues with the drive and the built-in recording feature of Windows XP.
* You experience issues with third-party programs that you use to write data to the disc.
* You cannot read the disc in all versions of Windows.
* You cannot read the disc, or some files on the disk, by using an MP3 player.
* When you add files or folders to a disc that already contains data, some files are lost.
* Recording files to the disc is inconsistent.
* The disc recording operation is consistently unsuccessful.
TROUBLESHOOTING
Troubleshooting specific errors
If you experience one of the following errors, follow the appropriate steps to resolve the error.
* There is no disc in the drive. Please insert a writable CD into drive.
This error can occur if the CD-R drive or CD-RW drive is not recognized as a recordable device. This error can also occur if the device driver has been corrupted. To resolve this issue, see Method 3 in the "General troubleshooting" section and Method 1 in the "Advanced troubleshooting" section.
* Drive not accessible, incorrect function
This error message typically occurs when you try to write to a CD-R or a CD-RW, and the Windows XP built-in disc recording feature does not recognize the CD drive as a recordable drive. This error message may also occur if specific third-party programs are installed. For more information about how to troubleshoot this error,
when you access the CD-ROM drive, the DVD-ROM drive, or the CD-RW drive
* Error Deleting File or Folder.
Cannot delete file name. Files on this CD-ROM drive are read-only. You cannot copy or move files over to this CD-ROM drive.
This error message can occur because individual files cannot be deleted from the CD-RW. You cannot use the CD disc recording feature of Windows XP for random-access storage while you are writing to disc.
To set the service to Automatic, follow these steps:
1. Click Start, click Run, type services.msc /s, and then click OK.
2. Double-click IMAPI CD-Burning COM Service.
3. Under Service Status, click Start.
4. Try to write data to a CD.
Jan 28, 2010 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
I have a Toshiba Satellite Pro 4600. The DVD drive has stopped working, It works correctly with a lens cleaner disc. but when I try any other disc I get the following message '' windows cannot read from...
Load a CD in the drive then go to My Computer and right click on the drive letter. Now click on explore and see if it opens the folders on the CD. If it can not read the CD files then you may need to replace the drive. Check that the driver is properly loaded and windows recognized the drive properly. Control Panel-System-Hardware-Device Manager then select the CD Drive to see the status of the driver. If it has an error you may need to replace the driver. Another thing to do is go into the Bios setup when starting the computer and see if the Drive is recognized properly. While you are in the Device Manager look at the tab for "Region" which should be set for Region 1. If it is not set for 1 it would cause this problem. Good Luck
Dec 09, 2009 | Toshiba Satellite Pro 4600 Notebook
CD drive will not read my discs and does not recognize cd in drive.
Try to run a head cleaner on your laptop drive CD/DVD drive. After cleaning if it still does not read any discs, then it probably time to replace it.
May 30, 2009 | Dell Latitude D600 Notebook
My cd rom drive will not recognize any cds or dvds. When I put a disc into the drive it will tell me to insert a blank disc into the drive. I have tried over ten different discs (including the one that...
what do you mean not recognized? not detecting the drive or not reading? if not recognized by windows you can check the driver for drives in the windows if not reading it is the lens problem..if the lens problem, the solution only is to replace the lens or to replace the whole drive
Mar 07, 2009 | Computers & Internet
My pioneer cd/dvd/rw-dvr 111D will not recognize a cd in the drive, usually this happens with game cds. it does recognize some,but some it does not. i have put the same disc into another computers cd/dvd...
My cd drive does this as well not a good thing but I have found that if you put a disc you know it will read in then anydisc you want it to read it should read it. Mine only does it every now and then. I have also found that if just after the cd door closes if you give it a tap on the cd door it will read the disc try it it might work for you. I have taken mine to a repairer and the drive is operating fine and they could not figure out what was wrong for it to do that and yes it did do it for them to.
Jul 26, 2008 | Pioneer Computers & Internet
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
