Question about Sony 4GB Memory Stick PRO Duo Memory Card
Problem in formatting corrupt memory stick
I have a 4gb memory stick pro duo, and now when i try to use it in my computer with a memory card reader it says "insert a disk" so now how can i fix or format my memory stick. i need it because ther are some important photos. can i please get a solution to format it, and it does not even format through the PSP. can i PLEASE get a solution for the problem in formating the memory stick, PLEASE.
  • 3 Answers
Sorry to hear that but I reckon it ceased for good, at times their not 100% reliable but you can try using an adaptor with it via your PC to see if you can retrieve all your data’s but the chance is slim from experience, you might be looking to get a new one, if you did buy new one try backup it up from time to time via your PC or alternative storage so you can retrieve your data’s when your memory card come to a halt
Posted on Jun 25, 2009
Computer doesn't recognise memory stick pro duo 4gb
Hello Guys,
The computer sometimes doesn't recognize the memory stick device due to corruption, there are numerous causes for memory stick corruption for example virus attack, improper removal, wrong usage of the memory stick device and many more. After such corruption scenario data are lost from these devices, but luckily you can recover memory stick files by using an efficient recovery application like Yodot Photo Recovery. Apart from memory stick the tool also recovers files from all other devices like memory stick, hard disk, iPods, music players etc. Try using this tool to recover your data from memory stick
Aug 20, 2012 | Sony 4GB Memory Stick PRO Duo Memory Card
My 4gb memory stick pro duo didnt work on sony vaio vpcw21eag card reader magicgate hg duo.. pls help me... my operation system win 7 ultimate.. help me...
if your 4gb memory stick are not working,i suggest format your 4gb memory stick and use. step for format it , Right click on my computer and click on manage after open manage window click on Disk management tab after few second your 4gb memory stick are display it, right click on 4gb memory stick and format, select quick format , ok after few second complete format message are display , click ok and use your 4gb memory stick.
Jun 22, 2011 | Computers & Internet
My 4gb mem. sick pro duo wont work in any of my sony devices anymore, whenever i put it in it says something like no disk is inserted and idk how to fix it
The memory stick is probably dead. The most common cause for this is ESD (Electro Static Discharge) to test, use a USB card reader to look at it on your computer. if the computer sees it, try formatting the card.
Mar 11, 2011 | Sony 4GB Memory Stick PRO Duo Memory Card
My acer computer cannot read the stick duo pro memory card (4gb).
Not all card readers can cope with Memory Sticks of that large a capacity. I suggest that you buy a cheap external card reader which specifically states that it can handle Memory Stick Pro Duo of at least 4GB capacity.
Sep 30, 2010 | Cameras
"file error" in my mémory stick pro duo
first try to format it in your camera. if that doesnt work, try another camera or on your PC. If that doesnt work try formatting on a different card reader (maybe on another PC)
if that doesnt work, it might be really defective. Have it replaced
Jul 28, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
Sony memory stick PRO duo 4gb card says memory full when empty
I would suggest formating the memory card through the options on your camera. If you reformat the memory card and you still get the same error then you have a bad card. Just like anything else the cards will break down internally over time.
Mar 07, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
Memory stick pro duo
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format stick pro duo
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jan 28, 2010 | Sony 1GB Memory Stick PRO Duo Memory Card
Memory stick pro duo sony won't read
Files on a flash drive and memory cards in a card reader can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the memory card and flash drive you may need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
www.CardRecovery.com
Nov 19, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
I inserted a PRO Duo card in a PRO reader (no DUO) and now the camera won't recognize it
It's possible the memory card just needs to be formatted again. Formatting will clear off all data on the card however.
In order to format the card you will need the proper adapter to connect it to a pc. Once it is detected by the pc you can go to the drive in "My Computer" in XP (or "Computer" in Vista), right-click, and select "Format". This is all assuming that you have it connected to a Windows pc.
Jul 10, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
I have a memory Stick PRO Duo 4GB
YEAH, YOU MAY NEED A MEMORY CARD READER to read your memory stick. because some compters have not all type of card slots. the card reader will solve your problem.
Feb 10, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
Sony 4GB Memory Stick PRO Duo Memory Card Logo
637 people viewed this question
Top Sony Electronics - Others Experts
Sandy Moore
Sandy Moore
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
