Question about Intel Motherboard
Ms 6787 ver 2
For Windows 7
To get my acount on zorpia not conected with twoo
The question makes no sense? Re-enter your question with more details please.
Mar 24, 2018 | Computers & Internet
Tip
You cannot print or print preview Web pages in Internet Explorer on Windows
<b>Symptom:</b><br /> <p>When you try to print a Web page in Internet Explorer 7 or in Internet Explorer 8 on a computer that is running Windows Vista or Windows 7, the Print</b> dialog box disappears, and nothing is printed. <br /><br />Additionally, if you print preview a Web page, the Print Preview page may be blank except for the page number in the header and a file path and date in the footer. The file path resembles the following: <br /> <p>File://C:\Users\&lt;username&gt;\AppData\Local\Temp\Low\RU4GX5A5.htm <br /> <b>Cause:</b><br /> This issue can occur if the "C:\Users\&lt;username&gt;\AppData\Local\Temp\Low" folder has been deleted. Some applications, such as disk cleanup utilities, can delete this folder during their cleanup process. <br /><br /><b>Note: </b>&lt;username&gt; refers to the currently logged on user who is experiencing the issue.<br /> <b>Resolution:</b><br /> To resolve this issue, follow the methods that are listed in this section starting with Method 1. <br /> <p><b>Method 1: Restart Internet Explorer</b><br /> loadTOCNode(2, 'resolution'); <ol> <li>Close all instances of Internet Explorer. <li>Restart Internet Explorer. <li>Print or print preview a Web page in Internet Explorer. </li></ol> If this method does not resolve the issue, go to the next method. <br /> <p><b>Method 2: Re-create the missing folder</b><br /> loadTOCNode(2, 'resolution'); <ol> <li>Close all instances of Internet Explorer. <li> Click Start</b>, type <span>%Temp%</span> in the Start Search</b> box, and then click the Temp</b> folder in the list. <br /> <li>If you are running Windows Vista, click New Folder</b> on the Organize</b> menu.<br /><br />If you are running Windows 7, click New Folder</b> on the main menu. <li>Type <span>Low</span> for the folder name, and then press ENTER. <li>Close the Windows Explorer window, start Internet Explorer, and then print or print preview a Web page. </li></ol> If this method does not resolve the issue, go to the next method. <br /> <p><b>Method 3: Reset low integrity level on the Low folder </b><br /> loadTOCNode(2, 'resolution'); <ol> <li> Click Start</b>, click All Programs</b>, and then click Accessories</b>. <br /> <li>Right-click Command Prompt</b>, and then click Run as administrator</b>. <li> At the command prompt, type the following command and then press ENTER: <br /> <p><span>ICACLS "%userprofile%\AppData\Local\Temp\Low" /setintegritylevel (OI)(CI)low</span><br /> <li>Restart the computer. <li>Print or print preview a Web page in Internet Explorer. </li></ol> <b>The information in this article applies to:</b><br /> <ul> <li> Windows Internet Explorer 7, when used with: <br /> <ul> <li>Windows 7 Enterprise <li>Windows 7 Enterprise E <li>Windows 7 Home Basic <li>Windows 7 Home Premium <li>Windows 7 Home Premium E <li>Windows 7 Professional <li>Windows 7 Professional E <li>Windows 7 Starter <li>Windows 7 Starter E <li>Windows 7 Ultimate <li>Windows 7 Ultimate E <li>Windows Vista Business <li>Windows Vista Business 64-bit Edition <li>Windows Vista Enterprise <li>Windows Vista Home Basic <li>Windows Vista Home Basic Beta <li>Windows Vista Home Premium <li>Windows Vista Starter <li>Windows Vista Ultimate </li></ul> <li> Windows Internet Explorer 8, when used with: <br /> <ul> <li>Windows 7 Enterprise <li>Windows 7 Enterprise E <li>Windows 7 Home Basic <li>Windows 7 Home Premium <li>Windows 7 Home Premium E <li>Windows 7 Professional <li>Windows 7 Professional E <li>Windows 7 Starter <li>Windows 7 Starter E <li>Windows 7 Ultimate <li>Windows 7 Ultimate E <li>Windows Vista Business <li>Windows Vista Business 64-bit Edition <li>Windows Vista Enterprise <li>Windows Vista Home Basic <li>Windows Vista Home Premium <li>Windows Vista Starter <li>Windows Vista Ultimate </li></ul></li></ul>
on Jan 17, 2011 | Computers & Internet
Tip
How to Change or Remove Windows 7 Password?
Windows 7 allows you to create a strong Windows 7 password to protect your data on computer. Meanwhile it also provides you solution to change or remove Windows 7 password. So you are able to change Windows 7 password if you forgot Windows 7 password or intend to reset Windows 7 password for other reasons. Here are guides on how to remove or change Windows 7 password.
Solution 1: Change or remove Windows 7 password through Windows 7 control panel
If you can log on your computer with Windows 7 password, you can remove or change Windows 7 password easily through Windows 7 control panel.
To change Windows 7 password, please follow the steps:
Step 1: Click on Start > Control Panel > User Accounts and Family Safety > User Accounts.
Step 2: Click Change your password.
Step 3: In the screen comes up, type your current password, the new password you would like to start using and a password hint. (password hint is optional)
Step 4: Click Change password button to confirm your Windows 7 password change.
Now your Windows 7 password has been changed, and you must use your new password to log on to Windows 7 from this point forward.
To remove Windows 7 password, it is also very simple. Just follow the below steps:
Step 1: Click Start > Control Panel > User Accounts and Family Safety > User Accounts.
Step 2: Click Remove your password.
Step 3: Type your current Windows 7 password in the text box on the following screen.
Step 4: Click Remove Password button to confirm that you'd like to remove your Windows 7 password.
Now your Windows 7 account password is removed. And you will no longer need to log on your computer with Windows 7 password.
Solution 2: Remove Windows 7 password with Windows Login Recovery
If you are locked out of computer as you forgot all Windows 7 passwords, what should you do to remove or change Windows 7 password then? At that time, you need the help of Windows password recovery software to remove your lost or forgotten Windows 7 password. Windows password recovery software allows you to remove lost or forgotten Windows administrator password, standard user password on all popular Windows OS, including Windows 7. By burning a bootable CD/DVD or USB flash drive, you can easily regain to computer again.
Here are the steps to remove Windows 7 password with Windows Login Recovery Professional:
Step 1: Download Windows Login Recovery Professional and install it in any computer.
Step 2: Run the program and burn an ISO image file into the blank CD/DVD or USB flash drive.
Step 3: Start your locked computer from the bootable CD/DVD or USB flash drive.
Step 4: Remove Windows 7 password by following the instructions.
And now you can access to your computer without password. And you can easily remove or change Windows 7 password according to the steps in solution 1.
Of course, you can also change Windows 7 password if you have a password reset disk in advance. If you don't know how to create one, You could follow the guide of Microsoft's official website.
on Oct 14, 2010 | Computers & Internet
Printer prints a faint offset ghost image
HP Print Diagnostic Utility was created to help users troubleshoot and correct many common problems on Windows-based computers that can prevent printing.Follow the on-screen instructions to run the utility.
Details and specifications
File name:s.gifHPPDU.exe [1/1, 1.54M]System requirements:s.gifNo additional prerequisitesReleased:s.gif2010-08-13Version:s.gif3.0.0.013Compatibility:s.gifMicrosoft Windows Vista, Microsoft Windows Vista Home Premium (32-bit), Microsoft Windows Vista Home Basic (32-bit), Microsoft Windows Vista Business (32-bit), Microsoft Windows Vista Ultimate (32-bit), Microsoft Windows 7 (32-bit), Microsoft Windows 7 Home Basic (32-bit), Microsoft Windows 7 Home Premium (32-bit), Microsoft Windows 7 Professional (32-bit), Microsoft Windows 7 Enterprise (32-bit), Microsoft Windows 7 Ultimate (32-bit), Microsoft Windows 7 Home Basic (64-bit), Microsoft Windows 7 Home Premium (64-bit), Microsoft Windows 7 Professional (64-bit), Microsoft Windows 7 Enterprise (64-bit), Microsoft Windows 7 Ultimate (64-bit), Microsoft Windows 7 (64-bit), Microsoft Windows Vista (64-bit), Microsoft Windows Vista Home Basic (64-bit), Microsoft Windows Vista Home Premium (64-bit), Microsoft Windows Vista Business (64-bit), Microsoft Windows Vista Enterprise (64-bit), Microsoft Windows Vista Enterprise (32-bit), Microsoft Windows XPFix/Enhancement:s.gifThis version of the HP Print Diagnostic Utility provides an improved user interface in multiple languages, improved diagnostic and problem resolution capability, and support for usb and network connected devices.
Oct 28, 2010 | HP LaserJet 5200 Printer
LJ 3050 printer is printing very slow.
TRY HP Print Diagnostic Utility was created to help users troubleshoot and correct many common problems on Windows-based computers that can prevent printing.Follow the on-screen instructions to run the utility. Details and specifications File name: s.gif HPPDU.exe [1/1, 1.54M] System requirements: s.gif No additional prerequisites Released: s.gif 2010-08-13 Version: s.gif 3.0.0.013 Compatibility: s.gif Microsoft Windows Vista, Microsoft Windows Vista Home Premium (32-bit), Microsoft Windows Vista Home Basic (32-bit), Microsoft Windows Vista Business (32-bit), Microsoft Windows Vista Ultimate (32-bit), Microsoft Windows 7 (32-bit), Microsoft Windows 7 Home Basic (32-bit), Microsoft Windows 7 Home Premium (32-bit), Microsoft Windows 7 Professional (32-bit), Microsoft Windows 7 Enterprise (32-bit), Microsoft Windows 7 Ultimate (32-bit), Microsoft Windows 7 Home Basic (64-bit), Microsoft Windows 7 Home Premium (64-bit), Microsoft Windows 7 Professional (64-bit), Microsoft Windows 7 Enterprise (64-bit), Microsoft Windows 7 Ultimate (64-bit), Microsoft Windows 7 (64-bit), Microsoft Windows Vista (64-bit), Microsoft Windows Vista Home Basic (64-bit), Microsoft Windows Vista Home Premium (64-bit), Microsoft Windows Vista Business (64-bit), Microsoft Windows Vista Enterprise (64-bit), Microsoft Windows Vista Enterprise (32-bit), Microsoft Windows XP Fix/Enhancement: s.gif This version of the HP Print Diagnostic Utility provides an improved user interface in multiple languages, improved diagnostic and problem resolution capability, and support for usb and network connected devices.
Oct 27, 2010 | HP LaserJet 3050 Printer
Hi, i have an HP printer D5160 and the desplay shows the err 03 31 if f4 dd6 and i can't print anything Thank you Aris T.
Oct 27, 2010 | Office Equipment & Supplies
My printer will not print black ink i just changed 3 cartridges
Oct 27, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
My D7160 cuts the bottom part off of every photo. How do I fix this?
Oct 27, 2010 | HP Photosmart D7160 InkJet Printer
Will not print. Have to power off and then power back on for printer to start.
Oct 27, 2010 | HP LaserJet P2015dn Printer
Drivers
I will recommend that you download and run the free Windows 7 Upgrade Advisor. It helps find issues with your computer’s hardware, devices that might affect installing Windows 7. Go to the Windows 7 Compatibility Center find direct links to drivers, updates, and downloads.
Apr 04, 2010 | Toshiba Satellite A300-ST6511 Notebook
Intel Motherboard Logo
106 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Joe Negus
Joe Negus
Thomas F. Schneider
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
