Question about JVC HD-52G886 52" Rear Projection HDTV
I replaced the satalite with cable and we have a great picture but no audio! The cable guys were there for 3 hours and the jvc call center of certified repair mand cannot explain how to fix it...any ideas?!!
    Problem Solver:
  • 16 Answers
Are you using HDMI. If you are see if HDMI audio is activated in the cable box using settings on cable box
Posted on Jun 26, 2009
Jvc av 20420 no sound
Check and replace damaged component/s at the audio output section circuit. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact any experienced service technician, or the nearest service center.
Mar 07, 2013 | JVC AV-20420 20" TV
I just want to hook up my JVC receiver to my Samsung to Tv so I can play the tv through the receiver and take advantage of my speaker system I have HDMI in both
Your Samsung TV does not have an HDMI out put. So unless you have a cable box or satalite box you will not be able to run the sound through your receiver via HDMI. If you do have a box, then run the HDMI cable from the Box to the Reciver input. And a cable from the reciever output to the TV input. This will feed the sound through the reciever and the picture will pass through to your TV. Hope this helps.
Apr 10, 2012 | Audio Players & Recorders
No sound but picture on an RCA L32HD31R
Check all ur tv inputs cables connections from the back of the tv,for like AV components and or HDMI cables for losed connections or damages cables wires.If u have cable boxes,satalite boxes or telicom compannies boxes and it plug in 24/7?Yes?Unplugs,replugs those boxes and the tv also back about an hour later.For those boxes to reboot and upgraded it softwares and the tv to do a resetting itself back to the tv factory settings.Than goes into the tv menu,go to the tv Audio Settings,to do a whole resetting to all the audio settings back to the tv factory Audio Settings.These steps,will help for ur tv to have and to get it audio sound back again.
Nov 29, 2011 | Televison & Video
The tv speakers are turned off, i just want to know how do i turn them back on-I get no sound at all
Tries cable or satalite boxes and tv unplug,replug it back like about an hour later.For the tv resetting itself back to the factory setting and those pay boxes to reboot and upgrade the their softwares.Go into the tv menu goto Audio Setting,go down do a resetting to the audio setting back to the factory setting.By doing these steps,tv audio have a great chances of returning.
Aug 11, 2011 | Mitsubishi LT-52153 LCD TV
I have an RCA L32HD31 32 in. Tv. I have a picture but no sound. It is less than 2 yrs old. Any solutions?
Tries tv and cables or satalites boxes unplug,replug it back like about an hour later by letting the tv resetting itself back to the factory setting those boxes upgrading it software.Now go into the tv Menu go to Audio Setting go down for a resetting back to the factory setting.By doing these steps,u have a great chances to get ur tv audio back.
Jun 07, 2011 | RCA L32HD31 32 in. LCD HDTV
All of a sudden the sound isn't working and yes I checked the mute button already and it is just a cable connection....sound was working fine one day and the next day it won't work at all.
Tries cables or satalites boxes and tv unplug,replug it back like about an hour later,for the tv to do resetting itself back to the factory setting and those pay boxes to updated it softwares.Go to tv Menu go to Audio Setting go down for a resetting to go back to factory setting.By doing these steps have a great chances getting ur tv audio back.
Mar 24, 2011 | Protron PLTV-32 Television
Tv screen is black everything is plugged in Guide will come up but no picture
This problems,it not the tv, it is the satalites boxes or the cables boxes are the problems.Tries unplug the satalites boxes or the cables boxes for about an hour.Replug those boxes back in now those boxes should be resetting itself and updating it software.U should have picture now,if not call ur cables or satalites providers,get a replacement boxes.
Nov 25, 2010 | Sony Televison & Video
The LED vizio comes on the front of the tv...........screen is blue with floating signal saying No Signal!.
Tries unplug the tv and the cable or satalite boxes too.Replug it all back like an hour later.The tv know will reset itself back to the factory setting.The cables or satalites boxes it upgrading it softwares.The tv should have incomming broadcasting signal and work now.Not,call the cables or satalites compannies to replaced those inputs boxes first,have the same problems with those new input cables or satalites boxes.Than the tv,the Tuner signal board have problems and the cause.That the board,where the incomming broadcasting signal cable plug into it.That the tv Tuner signal board.Tries websites Shopjimmy.com,Ebay.com to buy a whloe refurbish Tuner signal board for the replacement.
Nov 07, 2010 | Vizio VX32LHDTV10A 32 in. LCD HDTV
My JVC HD-56G786 will not work with HDMI cable. when I connect the HDMI cable I get a green screen. Any ideas would be great.
I had the same problem with my JVC projection tv. It would flash green, then go to regular picture then back to green flashes. Not sure if this is the solution you were looking for, but I was able to get a good crisp picture using composite cables instead of the HDMI cable.
Aug 26, 2009 | JVC HD-52G886 52" Rear Projection HDTV
JVC AV-36870- After watching for awhile, screen goes blue and sound squeals
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
Oct 14, 2017 | JVC AV-36890 36" TV
JVC HD-52G886 52" Rear Projection HDTV Logo
79 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
