Question about Rinnai Toyostove Direct Vent Heater: Laser 30 Toyostove Direct Vent Heater Shipping
Toyo L-30 Start up noise
My L-30 is the new replacement heater from the dealer since my first one became a problem, and now the second one has developed the same problem. There are no error codes, it puts out heat, but it would wake the dead in the same room with its startup noise that sounds like several blow torches at once, or a cat fight in the room with you. Both of these heaters started out perfectly, no noise, only felt heat, could barely hear the fan, even when it cleared the heat to shut down when it finished its cycle. Both heaters, after about four days and nights, began this growling, mad cat noise that wakes me from a deep sleep. My L-73 in the front part of our house works perfectly, no noise, just burner lights blinking and we feel the wonderful heat, just a faint purr from the fan, and it is fed from the same 300 gallon tank of K-1. A service man tried to convince me that, 'whisper quiet operation' did not mean that Toyo stoves were supposed to be quiet all the time. My question: If the L-30 worked fine the first few days, what could have happened to cause the noise? It is flame noise, and it reduces or sometime stops completely as soon as the main circulating fan kicks in. Nobody seems to have any idea about, or understands this complaint.
  • 625 Answers
Before the heater starts up, the combustion blower starts to purge the chamber of unburnt gases, then the solenoid pump, pumps fuel onto the burner mat, shortly thereafter the ignitor turns on and ignites the kerosene. what you are hearing is the combustion blower. its a small motor with a rather large vacuum impeller on it. it sounds like a jet engine when it first starts. there are two bearings on this motor shaft. yours evidently are dry - no lubrication. replace the motor or if you have the equipment purchase two sealed ball bearings and press them on the shaft.
Posted on Nov 10, 2007
    Novelist:
  • 126 Answers
Will,
Since you have had the same problem with two different heater I think you have a problem with the flue pipe system. A Laser 30 is a very reliable heater and should not be noisy. There is some problem with either the exhaust or the air. Make sure the hoses are connected correctly. Did you install the air damper in the air chamber when you installed the heater?
Good luck,
Tom Hawkins
hawkins111@gci.net
Posted on Jan 06, 2009
  • 3 Answers
How high is the tank that feeds both of the heaters? If the top of the tank is more than 8.5 feet higher than the floor that the Laser 30 is sitting on then you probably have to much fuel pressure. Does it make high yellow flames in the window, as it is making the howling noise? The high fuel pressure is forcing more fuel into the burner than it can handle when it is burning on low. When the circ fan kicks in on high, the air intake fan RPM also increases which may allow it to get enough combustion air to make this noise go away. If this is right, you will need to install a fuel pressure reduction valve inline between the tank and the Laser 30.
toyofreehelp@yahoo.com
Posted on Nov 21, 2007
My toyo laser55 will not reignite after power outage. Possible problems or solutions?
Are you getting an error message?
There are only a few things that could be wrong. More than likely, fuel is not getting to the burn pot because the pump has air in it. Is it making a chugging noise? If so, that is the pump trying to move fuel from the sump.
I have had to, on a different toyo model, take the pump out of the sump, take the plastic nozzle off of the pump, and manually free up the pump by shoving a pipe cleaner down the intake hole. Put it back together, hit the red reset button, and start it up. The chugging should go away after a few seconds. It might take a couple of ignition cycles to start again.
Jan 11, 2011 | Rinnai Toyostove Direct Vent Heater:...
Will a monitor exhaust fit on a toyostove?
No. The Monitor has a male fitting going into the stove and a Toyo has a female. The diameters are not the same either. You want a Toyo exhaust pipe for your Toyo. The exhaust is is larger as is the air side. Don't mess around, get the right stuff.
Tom
Dec 15, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
I have a toyo laser 56 stove. It is starting to make a moaning noise. what shoud i do?
Pilot,
You need to have a new mat put in the bottom of the burner. When this mat lifts, sometimes the flame will cause a moaning noise with a large yellow flame. A new mat and maybe a burner ring will fix ya.
Tom
Dec 16, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
I need to get replacement parts for my laser 73 stove and no one around seems to carry them? Any ideas?
Any dealer that sells new Toyo stoves should be able to help you.
I don't think the rules of this site will allow me to post the web address of the dealer I use; but typing "Toyotomi heater service" into Google pulled up quite a few dealers.
Hope this helps!
_Helping Hands Services_
- Fairbanks, Alaska -
Oct 27, 2009 | Rinnai Toyostove Direct Vent Heater:...
I have a 2008 highlander hybrid limited
Contact the Toyo company. toyota will not help you on this one. You need to check to see if there is unusual shredding or peeling or possibly chunks coming off the tires. That is what happened with mine at 14K miles and I am in the process of getting them replaced. Toyota service told me they thought it was normal wear. It was not. After I contacted Toyo, they told me to go to a toyo dealer and have them call the company back. They offered me 100% if I put the same A20 tire onthe vehicle and 70% (100% for unused spare) if I put the new Toyo HT. I chose the latter since it has a 60K mile warranty. What I also found out is the A20 tire is not the same one you can buy now. The new one is the A20A. The original A20 was made specifically for Toyota at their request as an OEM tire. Toyota should have some liability in this and I am fighting them for the 30% cost, but am not holding my breath they will help.
Then only manufacturer of the 245/55R19 is Bridgestone and Toyo at this time.
Jul 10, 2009 | 2008 Toyota Highlander
Toyo 19" A20 Tires wearing out quickly
Jul 07, 2009 | 2008 Toyota Highlander
Help plese
On a toyostove EE13 is the burner thermistor.
On the Toyo you may have to have the dealer help you, as it could be something easy like a very cold day or more complicated as a main circuit board.
Sorry but, that's the only solution.
Mar 25, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
The blower motor went bad.
toyotomiusa.com/
they have a dealer locator
Tom Hawkins
Jan 16, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Need a service manual for laser 30 toyo stove
Remove the flex hose from the back of the stove. If there is a small hole in the back of the stove, stick a pencil in there and spin the motor. Try to start the stove. If the motor won't spin at all or if it spins freely and the stove still shows an EE8 you need a new motor.
You or your local dealer can change the motor in 30 minutes.
Tom Hawkins
Bethel, Alaska
Jan 15, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
EE2 code for toyo laser 56
Hi sammysamual,
My business is Laser Heating Service in the North Pole/Fairbanks areas of Alaska. An EE2 error code is usually fuel related. What does your Toyo do before the EE2 code shows up? If you let me know the sequence of events, I can trouble shoot the problem for you. toyotech
Dec 13, 2007 | Rinnai Toyostove Direct Vent Heater: Laser...
Rinnai Toyostove Direct Vent Heater: Laser 30 Toyostove Direct Vent Heater Shipping Logo
597 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
