Question about Troy Bilt 5.5hp Self Propelled Mower
Troy bilt mower will not self propel
I have changed the belt , checked all the gears. If you hold it up the whells will turn. Put it down it just jerks and vibrates a lil. Cant figure it out please help!
  • 202 Answers
Most of the time the engagement lever on the transmission cracks (at the bottom close to the pivot point where it goes into the case, look carefully cause it wont show without pressure on it)and the transmission simply will not engage. i fixed mine with a metal arm i made and no more problems all works a should. if they are going to make these under the troy bilt name they should at least make a decent lever for them.
Posted on Jul 06, 2009
I had the exact problem on a troy bilt mower. The wheels would spin when in the air but on the ground they would slip. On these mowers there is a plastic lever that the cable housing hooks to that engages the transmission when you pull the handle to make it go. The problem with mine was there was a bracket that stops this lever from traveling too far. In my case it was causing the lever not to travel far enough. I removed about 1/8 of an inch of metal from the bracket to allow the lever to travel all the way. Now the transmission engages and does not slip. Works great.... Hope this helps
Posted on Sep 05, 2009
  • 218 Answers
I would suspect the cable to engage the self propel has either streached..or the outer caseing of the cable has slipped and needs to be adjusted properly..i hope this helps..Keith
Posted on Jun 30, 2009
Remove self propel gears and axle from Troy bilt push
Most of the self propelled mowers have a pin in them. you need to use a pin punch and a hammer to knock it through. The gears will come off then. Post a picture if need more info.
Sep 02, 2014 | Troy Bilt 5.5hp Self Propelled Mower
Troy bilt xp self propelled not switching gears
Check transmission fluid. Ensure belt is good or replace. Check belt tensioner if installed.
Apr 21, 2013 | Troy Bilt 5.5hp Self Propelled Mower
Variable speed doesn't work troy bilt self propelled lawnmower
Cable could be stretched belt could be worn or old, if it has a gear box maybe it slipped a gear or lost some teeth. Do some investigation, Good Luck
Jul 26, 2010 | Troy Bilt 5.5hp Self Propelled Mower
How do you remove the gears on a front wheel self propelled troy bilt push mower?
Take the front tires off, pull gears and take out pins, put tires back on and you have a "non-self propell" mower.
Apr 13, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Front wheels lock up when pull mower backwards
Typically self-propelled mowers are propelled using the front wheels, which only turn forward. Pulling the mower back while the front wheels are turning will damage the drive gears. It's best to raise the front wheels slightly off the ground before pulling back.
Mar 24, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt 190cc Z-Start Model 12A-446A011 21"Inch Deck
You need to remove a pulley to put the new belt on.
Jim
Jun 05, 2009 | Troy Bilt 5.5hp Self Propelled Mower
How do i replace a drive belt on a troy bilt self propelled lawn
You turn the mower over, remove the blade with a 9/16 or 5/8 socket. There is a bolt holding shroud on, 3/8 or 7/16, there are two screws by the rear wheels, 7/16 that need to be removed. Once the shroud is removed, belt can be removed and new one put on.
May 16, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt 5.5hp Self Propelled Mower Logo
1,931 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
