Question about Maytag MAH6700AWW Neptune Front-Load Washer
The belt will not stay on and it appears that a
The belt will not stay on my maytag neptune 4000 AWW front loading washer and it appears that a part that holds the barell in front is broken or missing. When aligning the belt on the rear of the drum, the belt keeps slipping off....
No Solution yet....need free advice thanks....
Posted on Jun 29, 2009
No solutionyet....need free advice.......
Posted on Jun 28, 2009
I have a Maytag Neptune MAH 6700 AWW. It is shutting off and giving error code tE. Customer service does not recognize the error code. Can you help?
This is a problem with the signal from the water heating element "Thermistor" a Thermistor is a solid state sensor that senses temperature, in this case water temp. The Thermistor is part of the washers water heating assembly and not sold separately from it. There is a factory repair bulletin associated with the problem and the new part has improved reliability. I can't understand what the Maytag folks you called would tell you it is not listed, it is a common fault in the Neptune. Please rate my help. Thanks
Jan 23, 2012 | Maytag Neptune MAH5500B Front Load Washer
Washer wont spin. BUT, DOOR IS LOCKED. MAH 4000
Does sound like it's not balanced properly, or maybe it's set on drip dry instead of spin , basic solution i know but often the best lol ,
Nov 26, 2007 | Maytag Neptune MAH5500B Front Load Washer
Belt slipping off of pully on maytag neptune mah5500bww
I loosed the moter and the belt is staying on. However, my belt is cutting the tub when the belt is moving off the pully.
Apr 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
Sometimes there is water that fills in my washer after I use it. It does not happen right away but by the next day. I don't know the model but I do know this is an old washer....gold....I have had it for...
Q - My washer seems to keep filling  with water, the water keeps coming in the washer and going out the drain without the washermotor running.
A - This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.
  1. Boot change helps
  2. Consumer Display Code Table on the Electronic Display Maytag Neptune Front load washer
  3. Free on-line repair manual for the Neptune washer MAH3000, MAH4000, MAH5500, MAH7500  ( Acrobat reader required )
  4. How to access the console on the mechanical timer models
  5. How to access the workings of the washer
  6. My washer door is locked and it will not open up...HELP
  7. My washer will start when I push the start button, but a few seconds later, it will shut off
  8. My washer will not pump out + pump noise problems
  9. My washer will not spin
  10. Odor complaints from the front load Neptune washer - mildew complaints + a new "freshen up" procedure
  11. Parts breakdowns/exploded of the Maytag Neptune front load washer ( mechanical timer models )
  12. Problem chart for MAH3000 & 4000 Neptune washers
  13. Readers repair tips
  14. Trouble shooting tips from the Neptune manual for MAH3000 and MAH4000 models
  15. Tips from our friendly engineer on changing the boot and re-installing that clamp and spring
  16. Tips on changing the washer belt  ( acrobat reader required ) Belt parts link
  17. Tips that show what components need to be checked/replaced if a certain resistor on machine control board is bad. It is as follows: Burnt resistors in Maytag Neptune washer models MAH4000 and MLE/MLG2000
  18. Washing one item in a front load washer
Apr 01, 2009 | Maytag Washing Machines
We have a Maytag front load washer Model MAH 4000 AWW
tHE PROBLEM IS YOU NEED TO CLEAN YOUR SOAP, SOFTENER AND BLEACH DISPENSER, REMOVE THE BLEACH AND SOFTENER DISPENSER TRAY, AND YOU WILL FIND THAT IF YOU HAVE BEEN USING LIQUID SOFTENER, THAT IT HAS GUMMED UP AND CLOG THAT AREA AND IS CAUSING SPILL OVER. WHEN THE WATER IS POURED INTO THE TRAYS TO DISPENSE THE BLEACH AND OR SOFTENER.
Mar 18, 2009 | Maytag Neptune MAH7500A Front Load Washer
We have a Maytag Neptune washer Model # MAH4000 AWW it is leaking from the front at the bottom of door. Water pours out like a water fall when it wants to rinse. Any ideas?
TO ELLIESHIRK, I SEE YOU POSTED YOUR PROBLEM ON MAR. 19, 2009. I HAVE A MATAG NEPTUNE FRONT LOADER WASH MACHINE MODEL #MAH55FLBWW. I AM HAVING THE SAME PROBLEM WITH MY MACHINE LEAKING WATER OUT THE FRONT DOOR. MY WASH MACHINE SEAL LOOKS FINE. IF YOU HAVE FOUND A SOLUTION TO YOUR WASH MACHINE LEAK PROBLEM, PLEASE LET ME KNOW, OK. YOU MAY EMAIL ME AT: CJA931@FRONTIERNET.NET , MY WASH MACINE IS NOT VERY OLD EITHER 4-5 YEARS IM GUESSING, IT WAS LEFT WITH THE HOUSE I PURCHASED. THANK-YOU FOR YOUR HELP AND TIME. CONNIE
Maytag 5500 AWW Turns off randomly shortly after starting
Check out the motor control board near the floor on the right side. These have a high failure rate on the Neptunes. Maytag redesigned both the motor and motor control board to be more reliable. While inspecting this board, you are looking for a blown 10 amp fuse and /or burnt electronic components. If you have either... then you will need the the new motor conversion kit which includes the new motor, new motor control board and the wire harness. What you describe are signs the motor control board is nearing its end of life...
The kit takes about an hour to install. See www.neptunewaxmotor.com for disassembly photos so you can inspect the motor control board.
Sep 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
My Maytag Neptune 7500 front load washer will not turn on when the AC or heat is running
Check voltages at the outlet. My guess is that you are on the HVAC circuit, and the Neptune is more sensitive than your hvac equipment. Also check that the neutral is about the same potential as the ground.
Jan 02, 2007 | Maytag Neptune MAH7500WH Front Load Washer
Maytag MAH6700AWW Neptune Front-Load Washer Logo
206 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
