Question about Maytag PYG2300A Gas Dryer
Whirlpool Seseon Gas Dryer - Drum Doesn't Spin.
I have a problem with Whirlpool Seseon Gas Dryer (Mod#GGW9868KQ1), It worked perfectly till last weekend, usual laundry day. I chose the cycle pressed Start, heard click, but drum tumbling didn't start, Stopped cycle, re-programmed for another one - the same result, click and the drum didn't spin. Here is the set of actions, which i performed so far:
1. Opened a toe panel and tested thermal fuse, thermistor and high limit thermostat for continuity Examined connectors, removed all the lint (wasn't a lot!).
2. Performed factory diagnostic tests (access code: more time - less time, more time - less time). No error codes, door switch looks good.
Is there anything i can do before taking dryer apart? Also, is there any educated way to access motor area without removing the drum or ripping a back part of cabinet?
Thank you fin advance for your assistance.
  • 300 Answers
SOURCE: Maytag MDG5500 - heat goes off after several minutes
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Posted on Mar 07, 2009
  • 3074 Answers
SOURCE: Motor won't spin, belt is good, drums turns by
if you thermal fuse is gone then the dryer will not start(you can bypass the fuse by taping the wires together and test it, then buy a new fuse as if left bypassed it will cause a fire), it is recommended to change both. Here is a picture hope it helps Tim:
http://www.applianceaid.com/pictools/thermalfuse&stat.JPG
Posted on Dec 24, 2010
  • 10 Answers
SOURCE: Dryer was working perfectly then
check the thermal switch it is located on the top of the heat chamber in the back of the mach. you lift the top of the dryer and it will be on top in the back right there will be to the thermal swith and the high limit thermostat they have to be replace as a set
Posted on Jan 07, 2011
ftw1952
  • 10319 Answers
SOURCE: my kenmore gas dryer doesn't
when motors go bad the smell is godly awlful is yours like that? if so have the motor replaced
Posted on Jun 05, 2011
oldTech2332
  • 2341 Answers
SOURCE: Maytag Performa dryer blows fuse
their are two possiblities causing that
1) while cleaning the lint from the motor a wire accidently got pulled of of the motor switch
2) to me the buzzing when start button is pushed and may or may not start,the motor is bad
When trying the trick to start the motor by hand the door switch also must be pressed in
Gene
Posted on Aug 05, 2011
Testimonial: "Thanks for the resonse Gene! "
Ld lg3788w gas dryer drum won't turn
not a good model number,most likely you have a broken belt as long as it starts,heats but the drum doesn't spin,if you get a buzzing sound and it doesn't start you could have something stuck in the blower wheel,the motor is jammed or the motor is bad,you can open the door,push the door switch in,spin the drum with your other hand and have someone push the start button,if it starts you have a bad motor.
Nov 27, 2011 | Dryers
We have a whirlpool duet dryer and it will not heat up. I've checked for blockages and there doesn't seem to be any. It does spin but no heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 29, 2011 | Whirlpool Dryers
My ge dryer DBXR453EVOWW , drum doesn't spin, does heat
heatman101
Jun 12, 2011 | GE Dryers
I have a Whirlpool dryer...Mod nu# WED5800SQ0,
Sounds like your capacitor has stopped functioning. Most dryers have capacitors ranging from 8 to 10 ohms which store energy and give the drum the initial energy boost to start it turning. Unplug the machine and take off the side that contains the motor. in there you will find a small cylindrical object with two connections, thats your capacitor, replace it
May 24, 2010 | Whirlpool Dryers
Whirlpool gas dryer, drum doesn't spin
You have a broken or loose drive belt.
You can order a new one online (repairclinic.com) have your make and model numbers handy.
There's also exploded views to help you.
You'll need to remove the front panel and drum front panel, the drum and route the new belt around the tensioner pulley below the drum...
It's a bit tricky but if you take your time you'll be able to do it..
Let us know if you need assistance with disassembly.
K
Oct 17, 2009 | Whirlpool Dryers
Dryer does not glow or lite up but it runs
I just diagnosed the same problem with my estate model by wirlpool. It is most likely the thermal fuse located in the back (behind the panel) It is a $12.00 part. My neighbor fixed his father's unit with same issue 2 weeks ago.
Mar 07, 2009 | Whirlpool LGV4634JQ Gas Dryer
My dryer doesnt heat.
hi there,
check the ignitor and the coils on the burner assy.
Sep 30, 2008 | Whirlpool LEQ8000JQ Electric Dryer
Ihave a Whirlpool LP Gas Dryer MOD LGR5636PQ0, Dryer will not relite after the drum has cooled down
I would suspect you need to replace the gas valve making sure you get one for LP.
May 30, 2008 | Whirlpool Dryers
Maytag PYG2300A Gas Dryer Logo
143 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
