Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Washer will not fill all the way. Even when set on super it only fills to small load setting.
  • stewby0331 Jun 25, 2009
    It does not have a reset, and I've turned it to all the settings. Only will fill to small level.
  • 10,865 Answers
Hi i can help you. to reset the fill level you have to move the dial all the way to reset, or as high as it will go and then back to what u want.
Posted on Jun 25, 2009
My Frigidaire GLWS1339CS1 fills but stops about 2 inches from the top? It has done this since I bought it and otherwise works fine. A tech came out and told me to fix it would cost more than buying a new...
The washer will not fill all the wayto the top.yourmachine is functioning properly.when you have an empty tub and put it on super load and fill it up there should be 12 to 14 inches of water in the tub. that is the normal operating settings for your washer.
Oct 03, 2011 | Frigidaire GLWS1349A Top Load Washer
IS A HOTOINT FRONT LOADING WASHER TYPE WF860G [SUPER SILENT] MODEL A HOT/COLD FILL OR COLD FILL ONLY.
This model like most new models are cold fill only.. It will heat to the temperature set by the variable thermostat setting..
Dec 17, 2009 | Hotpoint Ultima WF860 Front Load Washer
Load size, spin cycle, and other cycles do not work properly
error code f 06 keeps coming up and we cannnot afford to have it serviced at this time we were told it had something to do with the control panel
Mar 22, 2009 | GE Profile WPSR3100W
We just bought our Admiral Top load washer 1 week ago and now the water will not fill the machine to do one load. We have stop using the super capacity setting and are trying the medium capacity setting...
ck to see how far down in stand pipe drain hose is shouldn't be more than 6-8 in also be sure stand pipe is at least the height of washer edge above floor there also needs to be small gap between washer hose and standpipe ..if hose is too tight in stand pipe or too far down or not high enough from floor a problem with siphoning may occur
Aug 10, 2008 | Washing Machines
Water fill control
it overflows from the tub then:
This can either be a fault in the fill sense tube( small tube connected to the bottom on the outer tub from the sensor at or near the top of the washer housing ) becoming blocked or broken or a fault with the sensor itself. There is a mechanical adjustment for the level but it is a little fiddly to get the adjustment just right.
If it overfills from the drain hose:
then either the drain hose is too low and the water siphons out before it reaches the maximum or there is a tight seal at the drain hose to house drain port which will cause all the water to siphon out, this can also be caused by a drain hose being pushed too far down the house drain port.
Jul 28, 2008 | GE WDSR2080D Top Load Washer
you may have to adjust/replace the water level switch. it is located behind the control panel. the water level knob is attached to it. it does have a screw adjustment.
May 15, 2008 | Roper RAB2121KW Top Load Washer
Triple, sounds like you are siphoning. Pull the drain hose out from the drain hole. Make sure you have a air gap where the drain hose goes in. Try this first. Catriver..post back
Mar 12, 2007 | Roper RAS8244KQ Top Load Washer
Washer tub will only fill on the hot setting
Is the tap to te cold water turned on
I would check that
Jan 13, 2007 | Maytag MAV3905EWW 13 Cycle Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
87 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
