Question about Toshiba Satellite A10-S100 Notebook
There is a blue screen then it shuts down - Toshiba Satellite A10-S100 Notebook
  • 822 Answers
I have this problem before, actually there are many causing blue screen. it might be the memory, hardisk, and the corruption of windows files etc. for you check first your hardisk if detected in your bios setup. if hardisk detected run safemode. then repair your windows.
Posted on Jun 25, 2009
Panasonic toughbook cf-74 blue error screen loop
Which OS do you have? Have you tried booting to safe mode?. Restart the computer. Immediately after the BIOS post ends, start tapping the F8 key repeatedly. when Windows Advanced Options menu appears, select safe mode and see whether it boots completely without blue screen(BSOD)
Apr 22, 2014 | Tablets & eReaders
Tip
Laptop keeps shutting down with a Blue Screen
That seems for no reason, you computer shut download displaying a Blue Screen frequently. Learning "what is Blue Screen" and "why it happen" is essential. laptop keeps shutting down with a Blue Screen due to various kind of reasons. However, we can pay attention to the most common causes. With basic learning, you can troubleshoot computer crash problem yourself.
There is a misunderstanding that Blue Screen is a virus. In fact, BSOD is is known as a colloquialism used for the error screen displayed by some operating systems. The cause could be hardware and software relate. Computer experts provide us a result that shows the average causes of Blue Screen.
50% are the results of software incompatible or corrupt.
30% caused by virus. In this case, your laptop always gets freezing.
Other causes should be system bug and hardware failure.
It is difficult to repair the hardware. You have no choice but replace it. Here, we only talk about the system bug and software problem. The diversity of the cause makes us confused. However, fixing registry error is the easiest way to solve the problem. Registry is the database of Windows. It was designed to manager computer setting. Everything happened on your laptop is relate to the registry. Fox example, virus programs install on your computer and modify the registry key making your PC very slow.
Laptop keeps shutting down with a Blue Screen? It is recommended to use a registry cleaner. The program will diagnose errors accurately and clean up them in seconds.
on Sep 15, 2010 | Computers & Internet
Blue screen of death
Blue screen error is basically related to hardware or driver issues in Windows . This error blocks users from logging onto their Windows operating system. Windows can shut down or restart unexpectedly......fix blue screen error
If you need any kind of technical assistance, you can contact support cell at http://www.vtechsquad.com
Sep 11, 2012 | Sony Computers & Internet
Set comes on with a blue screen with retrace lines,then shuts down. Turned down screen control on flyback, set stays on cannot control brill
The set is shutting down because the picture tube is been over driven, it is most likely the picture tube has a short in the blue gun, turning down the screen control drops the voltage to a safer level. The only other possibility is a short video driver and open feed resistor usually located on the video board on the back of the picture tube.
Feb 23, 2011 | Sony KV-32S40 32" TV
TV screen Flashes blue and then shuts off.
When it flashes blue, are the flashes bright blue lines going across the screen with the picture in the background, if so, It sounds like the Blue tube or blue driver circuit is breaking down after a short period of time. If this is the case, the uPC that controls the set is detecting a large current drain on and is shutting the set off for protection, An engineers expert eye is required I`m afraid. Ian.
Jul 24, 2009 | Sony KP-65WS500 65" Rear Projection...
Message is a blue screen and it says that recent installation of hardward/software has caused windows to shut down, go to advanced start up and go to safe mosde. the safe mode takes mw back to the same...
check the program installed in your system.. there are a lot of cause of blue screen.. 1. a lot of virus,2. not properly installed ethier hardware or software. programs.. or setting.. then the system will be shut down automaticaly. or autorestart...
Jun 19, 2009 | Dell Dimension 3000 PC Desktop
Blue screen appers and shut down by itself
your boot files are corrupted please repair your operating system backup your data and plan to reinstall a fresh version of operating system. endeavor to scan your system for virus affections.
Jun 16, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Blue screen
Simply change your Ram with new one.
Apr 08, 2009 | Computers & Internet
Blue crt assmbly maybe?
its very possible that the blue CRT is horting the set out. Heres how you can test it. Remove the speaker grille and access panel behind the grille and you will see the crts. remove the blue crt circuit board from the end of the blue crt and make sure it isnt touching anything then try powering up the set if it doesnt shut down then you have found the problem and you will need a new crt. or you can switch the blue circuit with the green and try it iwth the blue on green and the green on the blue then if the screen turns green before shutting down you will know that its a problem in the blue drive circuit and not the crt. lety me know if you need further assistance.
Apr 01, 2008 | Toshiba 46H84 46" Rear Projection...
Open Questions:
Toshiba Satellite A10-S100 Notebook Logo
167 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
