Question about Casio fx-300ES Calculator
I've tried again and again to reset my calculator so that it will answer problems like 7.4 x 2 as a decimal and not 74/5. It got in the way of first my college algebra work and now it's slowing down my chemistry homework. Please help, - Frustrated
  • Casio Master
  • 8,073 Answers
When you calculate the product 7.4 x2, the calculator gives you a fraction reduced to it simplest terms, 74/5 . The result is correct, but it happens that you want it expressed as a decimal rather than a fraction. To fix that all you have to do is to press the button [S<->D] above the red [DEL] key. It allows you to toggle the display format between fraction and decimal.
74/5 [S<->D] changes display to 14.8 and if you press the key again you go back to fraction
14.8 [S<->D] 74/5
Similarly, if you enter square root of 2 and it displays as a radical, you convert it to a decimal by pressing the key [S<->D].
The fraction and radical formats allow you to do exact claculations. But if you do not want to hear about that you can just press [SHIFT][MODE][2:LineIO] : Your calculator will do things the old way, but you will lose some important functionalities.
My suggestion is to set the default mode [MathIO] by pressing [SHIFT][MODE][MathIO] and to press the [S<->D] key to convert to decimal.
Hope it helps.
Posted on Oct 17, 2009
I have a canon F-502G and my number 9, pi, decimal sign and X(OCT) don't work. Please help! I've tried everything and I don't know what to do. Also there is OCT on my screen.
Your problem is that the calculator is in Base N calculator mode (Octal, base 8). only the keys 0 to 7 are active. Change the mode to Decimal (base 10) or reset it completely, and your calculator will come back to life.
Jan 04, 2016 | Canon Office Equipment & Supplies
What is the meaning of octal
The octal numeral system, or oct for short, is the base-8 number system, and uses the digits 0 to 7. Octal numerals can be made from binary numerals by grouping consecutive binary digits into groups of three (starting from the right). For example, the binary representation for decimal 74 is 1001010, which can be grouped into (00)1 001 010 - so the octal representation is 112.
In the decimal system each decimal place is a power of ten. For example:
bcd885da3009955a0aaca3e7bb004380.png In the octal system each place is a power of eight. For example:
4219c7fffd93294e3d48bba6f898bd79.png By performing the calculation above in the familiar decimal system we see why 112 in octal is equal to 64+8+2 = 74 in decimal.
Hope this helps
Jul 15, 2014 | Necchi Sewing Machines
BA II plus gives approximate answer for FV calculations
The 107,186.37 is what the future value would be if the interest per month is 0.58%, which is 6.96% per year. Try the following:
2nd [CLR TVM] 1 2 N 7 I/YR 1 0 0 0 0 0 PV CPT FV
As for rounding, you can change the calculator display to any number of digits (up to a limit, of course) by pressing 2nd [FORMAT] and then a number specifying the number of desired digits after the decimal point or 9 for floating decimal.
Mar 14, 2012 | Texas Instruments BA-II Plus Calculator
How do I get the calculator to show a DECIMAL answer? you know when I divide 100/7 I should get 14.28- NOT 11/7
To convert a single result to decimal, press S--D. to have all results come out in decimal, press SHIFT MODE 2 to switch to the LineIO mode.
Nov 23, 2010 | Casio FX-115ES Scientific Calculator
My calculator is returning an answer with a 7 for division
You need to set the number of decimal places to 1 or more.
• Press [2nd] [MODE] and scroll to FLOAT.
• Press the right arrow key until the number of decimal places needed is highlighted.
• Press the [ENTER] key.
For 2 decimal places, 2 should be highlighted. All answers will then be rounded to 2 decimal places.
• Press [2nd] [QUIT] to return to the home screen.
May 03, 2010 | Texas Instruments TI-30X-IISTK Scientific...
Reset calcuator
try this, press shift mode, then line 10. It will make it permanent. the answer will always be in decimals. if you are using a casio with ES models.
Jun 14, 2009 | Office Equipment & Supplies
I want to increase the number of decimal places
I found this solution on the HP website. Turn it on, and do what it says. Then turn it off and back on again, and the extra decimal places should show.
http://h10025.www1.hp.com/ewfrf/wc/document?dlc=en&lc=en&cc=us&docname=bpia5183 Introduction This document describes how to set the desired number of decimal places on the HP 12C Calculator in standard format and in scientific notation. Instructions for standard format
  1. Press and release the gold PREFIX key (f).
  2. Press the number key for the desired number of decimal places (0 through 9).
The display will show the specified number of decimal places. The answer will be rounded to the number of digits selected.
Mar 25, 2009 | HP 12c Calculator
Multiplication error(?) with repeating decimal place fractions.
You may have guessed right. The presence of the parentheses makes the content of the parentheses evaluated first. So there is a loss of precision.
On the Ti92 I do 7*(-1/7)+1 and find 0.
But with Floating mode set at 12 decimal digits I get
1/7.=.142857142857.
Then .142857142857.*(-7) + 1 gives 2E-14.
Try to calculate pi*(-1/pi) +1 or e*(1/e)+1.
Hope it answers your question.
Sep 29, 2008 | Texas Instruments TI-86 Calculator
Reset to factory settings
remove battery and return it back this make reset-decimal places can be adjust with decimal switch.
Dec 21, 2007 | Sharp EL-240SB Calculator
Casio fx-300ES Calculator Logo
329 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
