Question about Garden
Does scott mower #S1642 have a magnito? if so how do I access it?
  • 10,865 Answers
No there is no magnito. what is the problem you are having, i can help you.
Posted on Jun 25, 2009
Riding mower starts but wont stay running
Could be a dirty carb or a short in the magnito pull the wire off that is below it that's the kill wire if it stay running you know the magnito has a short. Check for lack of glass. Check the fuel filter .
Jun 21, 2013 | Garden
Why does my scott lawn tractor s1642 stop running after about 5 minutes?
Check your fuel cap. If it has a vent that isn't working, the fuel tank will build up pressure because no air can get into the tank and will then prevent fuel from getting out to the engine. You may need to replace the fuel cap. If so, you can get one at PartsBuggy.com.
Dec 01, 2012 | Garden
Install drive belt for scotts s1642 rider lawn mower
check size of belt make sure its correct make sure routing is correct andput belt on tension pully last you may have to pull on it to get it around it
Aug 30, 2012 | Garden
OUr murray lawn mower will not make spark at spark plugs. Help
check all your kill wires first to see if they are touching ground somewhere.
then check magnito/coil for power to it
disconnect kill wire at magnito if there is power to it.
see if you have spark
if not .... you need a new magnito
May 21, 2010 | Briggs & Stratton Garden
I need to see a belt routing diagram for a Scotts Mower
This is for a Scotts 1642. Picture yourself sitting on the mower looking down at the deck. Starting at the tractor pulley, the belt runs from the right side of this pulley to the left side of the tension arm pulley, around this pulley to the left side of the right hand side mower blade pulley, around this pulley, across the deck to the smaller left hand side idler pulley, then up to the left hand side mower blade pulley, around this pulley to the second (larger) idler pulley, around this pulley and back to the left side of the tractor pulley. If you make a small sketch of the deck pulley arrangement it will be easier. Keep in mind some of the pulleys are for the "V" side of the belt and some (The tension arm pulley & larger idler pulley) are for the flat side of the belt. Be sure the belt is not twisted and lays in a continuous circle with the "V" side of the belt on the inside before you start.
from http://www.ssbtractor.com/wwwboard/view_all.cgi?bd=lawn&msg=135
Please vote !!
May 12, 2010 | Garden
Start and immediately stops
spark plug gap would be .030 and magnito gap would be .010. I would clean carberaor. Sounds like the main jet is plugged. Hope this helps you.
May 07, 2010 | Mtd 22" Yard Machine Push Mower
Lawn mower will not start. I changed spark plug, gas is in the mower and oil, mower still does not run
If your mower will start when you prime it, and then it dies right away, you have a carberator pluged. If after primeing the mower and it will not even start for a few seconds, you have lost spark. If you have no spark, this can be cause by two things. First, the magnito could have gone back, but this dosen't happen to often, but it can happen. First, check to see that the cable from the brake handle has not stretched. This controls engine brake and its also the kill switch, which kills the spark. Get acess to your engine brake, and you will find a wire connected to a tab. Remove this wire and try to start the mower. If it starts, replace the control cable. If it dosen't start, hook the wire back up and replace the magnito. I hope this is of some help
May 05, 2010 | Garden
I need a digram of replaceing a drive belt on s1642 scott lawn tractor.
You can download the owners mqnuqal here:
http://dl.owneriq.net/2/2141e15a-36a6-9594-0166-6f10fba50f44.pdf
It has full instructions as well as diagrams
Sep 23, 2009 | Garden
Garden Logo
350 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
