Question about HP Photosmart C7180 All-In-One InkJet Printer
Cartridge Alignment Failure - HP Photosmart C7180 All-In-One InkJet Printer
    Genius:
  • 1,847 Answers
You might need to reseat the print head, or could be the sensor is damaged - so it couldn't read the alignment position properly.
I would take out all the cartridges, I think C7180 have a set of print heads separately from the cartridges. Remove the print head, clean it while at it, put it back, make sure securely seated. Put the cartridge back.
If the alignment still fails, did you see the light when it is trying to do the alignment? Is there any paper piece stuck there? Cleaning might help.
Thanks
Kevin
Posted on Jun 25, 2009
Scanner failure align the cartridge
To Align the new ink cartridge
The HP All-in-One prompts for an alignment of the cartridges every time a print cartridge is installed or replaced. Follow these steps to align the print cartridges from the control panel.
  1. Load unused, plain, white letter, A4, or legal paper into the input tray. note.png
    NOTE:If colored paper is loaded in the input tray when the print cartridges are aligned, the alignment will fail. Load unused, plain, white paper into the input tray, and then try the alignment again.
  2. Press Setup.
  3. Press 6 to select Tools.
  4. Press 2 to select Align Print Cartridge.
    The unit prints a print cartridge alignment sheet.
  5. Load the alignment sheet print-side down and top first in the center of the document feeder tray, and then press OK.
Dec 07, 2014 | HP Officejet 4355 All-In-One InkJet...
I don't know how to install the cartridgre on my new printer J 3680 Could you please tell me how? Thanks,
Follow the instructions below to install the print cartridges for the first time. Installing print cartridges Step one: Install the print cartridges Follow these steps to install the cartridges.
  1. Open the cartridge door. The carriage moves to the far right side of the product. Figure 1: Open the cartridge doorc01133347.jpg
  2. Remove the new cartridge from its packaging and, being careful to touch onlythe black plastic, gently remove the plastic tape by using the pink pull tab. Figure 2: Remove tape from cartridgec01107115.jpg 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the cartridge ink nozzles or copper contacts. Touching these parts will result in clogs, ink failure, and bad electrical connections.Do not remove the copper strips. They are required electrical contacts. Figure 3: Do not touch the ink nozzles or copper contacts.c01107116.jpg
  3. Slide each new cartridge forward into the empty slot. Then gently push theupper part of the cartridge forward until it clicks into place.
    • Insert the tri-color cartridge into the left slot.
    • Insert the black cartridge into the right slot.
    Figure 4: Insert the cartridgec01107117.jpg
  4. Close the cartridge door.
Step two: : Align the print cartridge The product prompts you to align cartridges every time you install a cartridge. You can also align the cartridges at any time from the control panel, or byusing the software you install with the product. Aligning the cartridgesensures high quality output.
  1. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
  2. Press OK. The product prints an alignment page.
  3. Place the alignment page print-side down on the scanner glass.
  4. Press OK to scan the alignment page. When the scan finishes, the alignment is complete.
NOTE: If you have colored paper loaded in the input tray when you align the cartridges, the alignment will fail. Load unused plain white paper into the inputtray, and then try the alignment again.
Sep 13, 2010 | Office Equipment & Supplies
I put in a new cartridge (56) and now my alingment
after replacing the cairtage printer needs alignment it gives a test page when we put it face down on scannes it starts the alignment...
on alignment process it doesn;t found the colour bands so it shows the alignment failure..........
pls install the new colour cairtge the it will give u the printout
thanks....
Jul 08, 2010 | HP PSC 2210 All-In-One InkJet Printer
I refilled my tri-color cartridge at Costco and my printer wouldn't print the alignment page. I bought a new cart and it worked fine. Then I re-installed the refilled cart to verify the fix, and it still...
a refilled cartridge IN NO WAY can lead to printer failure
the ink is the last thing on printer and has no effect to mechanical failures.
check here how you can refill your cartridge
http://www.youtube.com/watch?v=II9gpIXs_lE
Jul 02, 2010 | HP PSC 2210 All-In-One InkJet Printer
HP PSC 1610 cartridge alignment failure. now what?
after alignment process it asks to put the alignment sheet on the scanner glass .. are you putting it rite way ??? try putting it other way round.. it should be facing down also
Oct 20, 2009 | HP PSC 1610 All-In-One InkJet Printer
Printer Error
Go to control panel>printers & faxes. Open the printer, go to the top of the tool bar>printer>properties>align cartridge.
Jan 09, 2009 | HP Office Equipment & Supplies
My HP DeskJet g85 says "cartridge alignment has failed"
Here is the weblink which helps you in resolving cartridge alignment failure issue:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu00657&cc=us&lc=en&dlc=en&product=60399
Click on the link above and follow all the steps give in web document.
Thank you.
Dec 06, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Print Cartridge Alignment Failure
two option:-
1. cartridge is not proper. or
2. not proper installed.
Nov 29, 2008 | HP PSC 2355 All-In-One InkJet Printer
Message on fax reads "remove and check color cartridge"
i,ve replaced my set top box remote with a universal one but it does not operate it can you suggest anything !
durabrand cg5660-m set top box & the new remote is total control 4. can you help
Nov 04, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
Alignment failure
try to hit set up button then hit opions button to by pass error message
Oct 03, 2008 | HP PSC 2210 All-In-One InkJet Printer
HP Photosmart C7180 All-In-One InkJet Printer Logo
90 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
