Question about Garmin Forerunner 405 Handheld GPS Receiver
Updated firm ware on 405
I tried to load the firmware on the Garmin 405 and I get in a loop where it says that the watch is loading loader
Make sure you have the latest ANT version.
Remove the pending firmwire program that wants to be transfered to the forerunner. (right-click + select delete)
Reset the watch (hold both buttons for 6 seconds, lift upper button, hold lower botton for another 3 seconds)
Then start all over again.
This fixed the problem for me.
Posted on Jul 02, 2009
My fitness watch wont work after doing the firm ware which didnt quite finish
You just bricked you watch. Get another. Unless the company has a special reset, if the firmware is corrupt, the watch can't load the programs. Maybe you can talk to the watch company tech support. Return it, and have the replace the firmware...
Jan 30, 2018 | Watches
Why do you update the P2055dn firmware
ONLY PROFESSIONALS CAN DO THIS ACTIVITY.. NOT ADVISABLE FOR THE USERS..Firm ware for XP: http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=uk&prodTypeId=18972&prodSeriesId=3662052&prodNameId=3662058&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=lj-66014-9Win7,32bit:http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=uk&prodTypeId=18972&prodSeriesId=3662052&prodNameId=3662058&swEnvOID=4062&swLang=8&mode=2&taskId=135&swItem=lj-66014-9Down load the file,un zip & save it.. Read carefully read me file how to upload the firm ware through net work,usb & parallel connectivity.Ensure that no power failure or any other interruption during the up load. Take configuration page before & after firm ware up load verify the old version & latest version.. If you are not confident don't to do this activity pl...
Mar 30, 2012 | HP P2055DN LaserJet Monochrome Printer
Garmin 405 won't transfer courses
Try running the Garmin WebUpdater program to load or reload the latest software. This will usually fix any bugs or issues.
You may also want to contact Garmin Tech Support for assistance.
1-800-800-1020
Mar 26, 2012 | Garmin Forerunner 405 010-00658-20
My garmin freezes like a computer would
Hello there:
This sounds like you are suffering a soft ware issue here or the maops are not fully able to load due to the programming of the garmin
so what you can try to do is to first unplug it and remove the battery. locate the reset button and press and hold in on it for 3 minutes to allow the reset to do it's job then put in the battery and then plug in the unit again and try to run the garmin again and see what happnes if nothing than i would suggest getting the software updated and reloaded ok
Hope this is very helpful for you '
Best regards Michael
Jan 14, 2010 | Garmin nuvi 750 GPS Receiver
Unsuccesful installation firmware 2.30 to 2.50
I had a similar problem. After a few attempts I was able to update the firmware to version 2.50. This is what I did:
1. Close the ANT Agent application by right clicking on the icon next to the clock and selecting Exit.
2. Reset the Forerunner 405. Mine was frozen on the LOADER screen. I held both buttons for a few seconds and released them when the rebooting process started.
3. Open the ANT Agent application and then go to the GARMIN webpage to download the update. Make sure you have the latest ANT Agent version.
4. The update process started and ended in about 2 minutes. Then it started again and lasted anothe 9 minutes.
5. The watch reboots with the new firmware version but retains all data amd customs settings.
Good luck.
Jun 27, 2009 | Garmin Forerunner 405 Handheld GPS...
I can't update the firmware on my forerunner 405 . The watch gives a transfer unsuccesful message, have tried repeatedly.
There are two steps for the firmware update - two bad Garmin doesn't warn people upfront.
The first update is preparing for the ANT stick - it takes about two minutes.
The second step is the core of the firmware(software per Garmin) update which takes about 10 to 15 minutes depending on how busy the Garmin Connect site is.
Since you already got through and got the "unsuccessful" message, I assume you already know how to start the update properly.
To finish it - Make sure you do not interrupt the process, just let it run through the 2 steps mentioned above.  And be patient - the 2nd step follows the 1st step automatically.  Don't touch the bezel and change screen during the update, just leave it alone.  It took me a few times to get it done successfully because after the 1st step finished, I started to flipping screens to find out if it get updated to ver 2.50, before I found out there would be step 2 coming automatically.
If you see the process bar moving after the 2nd step and see "software loading" you are in for good.
Hope this may help.
Jun 07, 2009 | Garmin Forerunner 405 Handheld GPS...
Garmin Nuvi 265WT says loading loader
I left my GPS on and unplugged over night (I upgraded at 6pm) until the battery died. When I plugged it in to charge this morning it worked just fine with no problems.
Jun 06, 2009 | Garmin Nuvi 255 GPS Receiver
All of my ISO games suddenly couldn't be started. error 80020321
just press select botton to display the vsh menu and select umd iso mode and change the normal to sony np9660 that's all
Jun 06, 2008 | Sony PlayStation Portable (PSP) Console
Garmin Forerunner 405 Handheld GPS Receiver Logo
1,231 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
