I went into admin, however it just says terminals & set with an arrow.... thats itI went into admin, however it just says terminals & set with an arrow.... thats it
You can't post conmments that contain an email address.
If you know how to access admin programming. Yes, all the phones are probably set to "appear only"you need to go into line appearance for all the extensions and make them "appear and ring" If you find it, you can copy that programming from the phone that is already ringing.
Normally tech side programming If you do not know how to program, navigate or the password call a tech. otherwise go to Sets/Ext#/Line Access/Line Assignment, enter line # in question, press Change until you see the option you want ie.e appear only or not assigned.
Enter Feature **2663444
Search through General Options until you find Ringing options.
Type in the extension number of your personal office.
scroll to line 4 choose turn ringer to off, and rls! Let me know if you need clarification on how to find Ringers in General Options.
Sounds like extension has put the phone on transfer. You can try these steps on the Extension 241 phone and see if it will correct the issue.
1. Press the Feature button, then * 2 2. Push the button you want to program 3. Display will read "Intercom #:__" 4. Enter the extension number
Dial "F * 0" (Feature, star, zero), which is Button Inquiry, and press
an intercom button to see the extension number of the telephone.
If Set Relocation is set to "Yes", then the extension number &
mailbox will follow the phone when it is moved. Move only two
phones at a time, and wait until they completely "boot-up" before
moving additional phones.
Hope this helps.
It could be a simple as the phone has call forwarding to another extension set up on it or the direct line could also be programmed on the other set. Does the screen on the non- ringing m7208 display "forward to:xxx" or does it display the current day and time?
You will have to go into system programming, under sets, line appearances. You will need to set the lines on the phones to appear and ring, not just appear.
You have to go in to programming and set the phone in the shop to ring on line 3 only and the phones in the office to not ring on line 3.If you don't know how to go in to programming please inform me.
