Question about RCA HD52W58 52" TV
I replaced the fl231 fuse in my rca HD52W58 and it went back out
After replies, I replaced the fl231 flyback fuse in my rca HD52W58. Thank- you. It worked fine for about 30 minutes it then went right back the way it was. Can anyone tell me what to do or what to buy?
    Habit-Forming:
  • 4 Answers
Had the same problem , you have to resolder the flyback before replacing the fuse.
Posted on Aug 28, 2009
Testimonial: "this was exactly the problem. Thank you! Your awesome. You saved me at least three hundred dollars."
Convergency has gone out of sync, went to try to realign but the convergeny setting was not listed in the tools menu.
Thats usually caused by a blown FL231 Fuse and a blown DL231 diode that blow when the flyback transformer develops solder cracks around the pins. The repair is to first resolder the flyback then replace the FL231 fuse and DL231 diode. You can get the RCA / GE convergence option missing repair kit which has the parts and repair instructions from www.tvrepairworld.com
Jul 09, 2011 | RCA HD61W66 61" Projection HDTV
Replaced the fl231 fuse tv worked for day now blown again and tv keeps shutting off what do i check now
Resolder the flyback pins as thats what causes the FL231 fuse to blow. Soldering the flyback should solve the issue you may need to replace the fl231 again
Apr 28, 2011 | RCA R52WM24 52" HDTV Projection Television
Wont turn on after replacing FL231 fuse on a RCA HD52W59
If you replaced the fuse alone without installing the other components that are rquired to repair that issue the new fuse can allow voltages to flow trough the diode in both directions which can prevent the set from firing up. You need to replace the FL231, DL231 and CL230 as a set then reflow the solder on the flyback and vertical IC.
Dec 04, 2009 | RCA HD52W59 HDTV Projection Television
My convergence keep going out, I replaced the convergence twice. I have a rca hd52w59 modle
When you say replaced the convergence twice, are you refering to the convergence boards or the FL231 fuse? If its the FL231 fuse unless you replaced the DL231 and CL230 plus reflowed the solder on the flyback it will continue to keep blowing untill the 3 parts are replaced together and the flyback gets resoldered. If you replaced the convergence boards then try resoldering the flyback.
Nov 27, 2009 | RCA HD52W59 HDTV Projection Television
R56WH78 RCA TV FlyBack
Resolder all the pinns on the FBT chances are FBT is Bad they go out alot Call UED for Parts 1-800-648-6657
Oct 19, 2009 | RCA R56WH76 Projection Television
RCA R52WH77 ITC222A chassis convergence problem - FL231 changed!
did you hear an arch before it went if so , one of your crts is arching
and sorry they are not avail anymore
Sep 20, 2009 | RCA Televison & Video
My picture looks like its in 3D
The convergence circuit is not working. It is way too difficult to fix by yourself but any-one who works on RCA TV's can fix this easily.
Mar 30, 2009 | RCA HD52W58 52" TV
Auto convergence
this is an indication of a special fusable link fl231 has blown it is a small brown rectangular fuse that blows due to poor lead free solder connections on what is known as a flyback.. if you can solder and can get the part i find this repair to be a simple one... Caution. televs\isions can hold leathal voltages even when unpluged... EXTREME caution should be taken
May 26, 2008 | RCA HD52W58 52" TV
Auto convergence issues
this is an indication of fl231 fusable link has blown.. a brown recatangular special fuse that blows due to poor solder connections on flyback. IF you can get the fuse and can solder this is not a difficult repair... EXtreme caution should be taken with televisions. this set can hold 380 volts even when unpluged.. rember resolder flyback
May 25, 2008 | RCA HD52W58 52" TV
RCA 52w59 projection fuse fl231
Instead of taking the board out, I just soldered two wires to the old fl231 fuse on the underside. Installed a fuse holder with a half amp fuse. And I re-soldered all of the flyback points. My tv is working like new. thanks for everyone's help.
Dec 28, 2007 | RCA HD52W59 HDTV Projection Television
RCA HD52W58 52" TV Logo
172 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
