Question about Dell Dimension 4550 PC Desktop
Dell Dimension 4550 will not power on but standby light on.
Hello - A friend has asked me to look at her Dell Dimension 4550 PC Desktop. It will not power up. When I opened it up I notice the power standby light comes on. I am concerned that the problem is somewhere in the J9H2 power on switch. I have tried to rule other things out. If the standby power light comes on does that tend to indicate that the power supply is okay? I know it could be many things including the hard drive and perhaps the motherboard itself. I tend to think it is in the power on switch since this is the area that would have taken the most wear and tear from being pushed on and off. Any suggestions are welcome.
  • 61 Answers
Hey! Normally, I would have said exactly what the previous poster said. It is almost always the power supply. However, I am typing this message from a Dell 4550 that has a bad power SWITCH. I came home from a week's vacation and the PC would not power up - nothing, nada. I saw the green light on the mobo, so I figured it had power. Took the case apart, which is a huge pain. Decided to channel my inner MacGyver and put a screwdriver across the terminals for the power switch. She booted right up and has been running ever since.
The power button on this computer, and most these days, just closes long enough to discharge a capacitor on the mobo, which fires up the power supply. So, jumping it with a screwdriver lets that happen, yet it doesn't go off when you remove said screwdriver. Good luck!
BTW, if anyone knows how I can get another switch (it's installed on a little mini circuit board), that would be great.
Posted on Jul 24, 2009
    President:
  • Dell Master
  • 1,314 Answers
In all my years of fixing computers, 98% of the time it is the power supply, 2% the motherboard and 0% the switch. Just because the standby light is on does not indicate that the power supply is functioning correctly. The power supply puts out many different voltages....5v, 12v, 1.3v, and 3.3v. If the 3.3 is working then the standby light will come on but if any of the others are not working correctly then the computer won't turn on at all. You can check the switch by checking the resistance of the two wires that the switch are attached to using a multimeter. When the button is depressed, it should go to 0 and when it is not depressed it should be at 1. I would suggest swapping out with a known working power supply to verify the issue.
Posted on Jun 25, 2009
SATA on dell dimension 4550 with Debian
look in the devicemanager what does it say.
update thrue the deviemanager or search the internet
May 26, 2013 | Dell Dimension 4550 PC Desktop
Dell 4550 keyboard failure
Hello, Sounds like you have either bad connection or keyboard, try powering down the computer and reseating the keyboard.If that doesn't work , replace.
Oct 27, 2011 | Dell Dimension 4550 PC Desktop
Where can I buy a clock battery for a dell dimension 4550?
hello
Real Time Clock batteries (aka RTC battery) are found at most computer shops. They are common for most other makers of desktop computers.
depending on your geographic area, seek out computer stores, like Office Depot (Staples), Circuit City, Best Buy, or call Dell and get them to quote you (i am certain they are higher costs than others).
hope this helped you
Nov 08, 2010 | Dell Dimension 4550 PC Desktop
Dell dimension 4550 ethernet driver please
Dell dimension 4550 Ethernet Driver Installation Guide
1. Go here to download and install the Chipset - Intel driver.
2. Restart the computer.
3. Then go here to download and install the Ethernet driver.
4. Restart again.
Aug 20, 2010 | Dell Dimension 4550 PC Desktop
Dell Dimension 4550 Ethernet Hardware not working, cannot reload drivers.
Have you tried restoring your operating system? If not, please do so. There is a problem with operating system and the driver of your ethernet hardware. There might be a conflict on it.
Jul 12, 2010 | Dell Dimension 4550 PC Desktop
Standby power LED (CR4G1) comes on but that's it, will not start up. Replaced power supply and entire switch assembly with known good parts. Any possible explanation other than bad motherboard?
I have repaired this Model 4550. Unplug power cord FIRST. Is the Replacement Power Supply NEW? Did you plug the Power Supply in BEFORE you purchased it? Always do that BEFORE you buy it.
Oct 21, 2009 | Dell Dimension 4550 PC Desktop
Standby mode
see if there is aproblem with your power supply
Apr 17, 2009 | Dell Dimension 4550 PC Desktop
Download audio drivers for my dell dimension 4550
From link included select your version from (3) and sound card driver, download and install as instructed. I also recommend check out Dell support for 4550 PC at this link. Please rate me mysleuth
http://search.dell.com/results.aspx?spf=Dimension&ssysid=DIM_PNT_P4_4550&ssysn=4550&s=gen&c=us&l=en&cs=&ec=&ira=False&cat=sup&subcat=dyd%2F3&rf=all&evl=&nk=f&k=dell+dimension+4550&p=1&nf=&rpp=12&sort=K&~srd=False&ipsys=False&advsrch=False&p=1
Mar 19, 2009 | Dell Dimension 4550 PC Desktop
Dell dimensio 4550
you need to replace your motherboard. contact vendor
Dec 15, 2008 | Dell Dimension 4550 PC Desktop
Dell Dimension 4550 PC Desktop Logo
1,345 people viewed this question
Alun Cox
