Question about Logitech Webcam
Jacqueline i can't installer the quick web-cam i have windows vista,i'm try but the computer say no found the cam.
  • 8,637 Answers
Normal 0 Did you install the software with the camera connected to the computer? Disconnect the camera from the USB port and reinstall the software. When the program asks you to connect the camera, do so, and it should work. Hope this is of some help. Bud
Below is info for setting up Audio & Video to chat on line after you install , either Skype or a messenger program.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: You audio and video shoud work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Posted on Jan 14, 2009
Web cam does not work after a company put windows xp on when it came with windows vista the web cam program is Quick Play
Hello visit your pc`s homepage, to download the webcam driver.
The quick play software should also be available there.
ALL drivers are lost when a new install is made, and the vista driver does not work with windows xp.
Good luck
Jan 10, 2013 | Computers & Internet
I have problems with my hp web camara it freeze it a lot on messanger any help
If your web camera freezes check your Windows Device Manager and see if the hardware is recognized and installed properly. It might be that the hardware is recognized as a camera, but the right drivers are not installed. The yellow explanation mark will indicate a problem. If the device is not recognized in Windows XP, it will be listed under Other Devices
In either case you can try to update the drivers. Right-click the device, and in the pop up menu select Update Driver Software. Then follow the instructions on screen, but make sure you allow Windows to search the web for updated drivers. In case no driver for the web cam can be found, you can try a third party driver finding program that scans your PC for installed hardware and allows you to install missing drivers.
If this fails, the next step would be to un install the software that came with your web cam. Use the Add or Remove Programs feature in the Control Panel. If that does not work you can use a third party un installer. After un installing the software, restart your PC and then reinstall the web cam software. In most cases this will solve the problems. Depending on the software, you might need to unplug your web cam during the software installation.
If the drivers and web cam software are correctly installed, and you still it freezes, there can be a problem with the program settings. Most chat and meeting software have a configuration option to select the video source for the web cam feature. If you have multiple devices that qualify for video, you might need to select your web cam device as the source for the web cam feature in that program. Some web cams and programs require additional software, although that should be installed with the web cam if things are right. But is does not harm to check if your Java, Flash and Quick time software are installed and up to date. But certainly check your DirectX software, since all video applications, including web cams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c – Windows Vista: DirectX 10).
Thank you !!
May 30, 2010 | HP EW192AA Webcam
I dont know how to set up my web cam
To set up web cam you need driver cd. Place it in dvd/cd drive. Now connect web cam to working usb port. Then computer will notice you that it found new device and searches driver of it .install it from cd drive now you can run web cam in your computer.
Nov 03, 2009 | Microsoft Windows Vista Ultimate Edition
I have installed window vista yesterday and i found that i don't have web cam driver
If you have purchased a web cam unit, look for any CD that matches to your camera. However, most camera, CDs goes with it. Install CD and click folder which you wanted to install it in your computer.
Jun 22, 2009 | Computers & Internet
No web cam found
It may not be detected by windows or the device manager till the correct driver is installed and can initialize the device (Power it Up)
Try Searching Acers website for a Vista version of your driver , and be sure to make sure you pick the correct bit (ie; 32bit drivers will only work with 32bit vista, and 64 with 64)
May 24, 2009 | Acer Aspire 5610-4648 Notebook
I have a new Vista computer and can't install my
Logitech has the Vista drivers on their website.
If you are looking for the QuickCam Express:,en?osid=13
Mar 08, 2009 | Logitech QuickCam Express Web Camera
Quick cam 8.13
get the updated driver for vista at the manufacturers website
Feb 08, 2009 | Logitech QuickCam Express Web Camera
Problem with the webcam
use recovery cd to install web cam to your computer, if not the web cam gone bad.
Nov 19, 2008 | Acer Aspire 9300 Notebook
Problems with hp2601tx
Your computer came with a restore cd I am sure, so you can get vista back later if you need.
Here is a tutorial made just for you. You will need to own an XP CD. pre-installed-windows-vista-computer/">
You can buy laptop coolers almost anywhere for $20 to $30. They will get hot. I try to keep my laptop on a flat open surface to allow maximum air flow. Setting it on you lap insulates it and it gets warm. Nothing out of the ordinary.
You may be able to download an updated driver from HP that will fix your web cam problem. There may also be another program running that is trying to manage the web cam also. Take a look at your running programs and close any that are related to the web cam and see if you error still occurs.
Apr 04, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Please tell me how to install Gigaware PC Cam on my Vista Computer?
This might help, then again it might not. It seems that your comments are well founded regarding this particular cam. Suggestion is either take it back for refund or give the driver below a try. No guarantees provided.
Jan 18, 2008 | Radio Shack VGA PC Camera Webcam
Logitech Webcam Logo
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
