Question about Lanzar VIBE286 Car Audio Amplifier
I have a lanzar vibe 286 its a very good anp and kick hard but it gets very very hot so hot you can **** an eeg on it what shud i doi know i can install a fan on it but were the back or front i dont know the inside please e mail me back please iys jbear303@bellsouth.net thank you
  • rteemon
    rteemon May 11, 2010
    most amp do get hot but does it trip out when hot
  • Frank Fulton
    Frank Fulton May 11, 2010
    What type of amp installation kit was used and where is it mounted in the vehicle. What type of vehicle is it in? year/make/model. What type of headunit is in the vehicle? post a comment and I can help some more
The impedence of the speakers does not match the amp operating impedence. This amplifier is made to run a 2ohms stereo stable which means 2ohms per channel or 4ohms bridged.
Posted on Jun 26, 2009
Will a Lanzar Vibe 286 4000 watt amp push a power acoustik fubr 12 700 rms 1800 max ....
Yes it should do the job. You will need to wire the sub in series and make sure you have a 4ohm load on the amp. It should be right at around 700 watts RMS @ 12-13 volts.
May 18, 2012 | Lanzar VIBE266 Car Audio Amplifier
How do i reset my 4000 watt lanzar vibe 286 from being in protect mode
You can only reset it by disconnecting power to it. If it is in protect you may want to check your speakers and speaker wires for shorts and/or grounds. If they check out all right you may have internal problems in the amp.
Oct 28, 2011 | Lanzar VIBE286 Car Audio Amplifier
Looking for a service manual for a Lanzar Viberant 1200W Amp
www.lanzar.com/manuals/VIBE226-236-246-256-266-276-286-416-426-436.pdf
Mar 03, 2010 | Lanzar - Viberant: 2 Channel 1200W...
Lanzar vibe 256 battery wiring in my room, how?
try looking it up on you tube ive seen a introductory on how its done ..just type in how to hook up an amp in my living room i dont think you will need a battery..lol
Feb 23, 2010 | Lanzar VIBE256 Car Audio Amplifier
Lanzar vibe 286 speakers pop when it is on
Turn Down the Gain a little bit at Medium Vol. Till they don't Pop. Go to www.Crutchfield.com for a Wiring Diagram.
Jan 04, 2009 | Lanzar VIBE286 Car Audio Amplifier
Lanza vibe
you would want it on low not full or high bkz your system is not set up for full or high
Nov 07, 2008 | Lanzar VIBE241 Car Audio Amplifier
Lanzar vibe 1500 protect mode
sorry bath your problem is a proablem the soft
Aug 02, 2007 | Lanzar Vibe 1500D Car Audio Amplifier
Amp LED flashes on but right back off
This sounds like a problem with the power input to the amplifier; it's possible, but unlikely, that your CD player is causing it. Before you can do any real troubleshooting, you need a voltmeter. When your CD player is turned on, you should get a voltmeter reading of around 12 volts at the amplifier's remote terminal and B+ (power) terminal. If your main power wire doesn't show voltage, check for a loose or corroded connection at the battery or fuseholder, and try replacing the fuse (even if it looks okay). If there's no voltage on the remote wire, it may be pinched or shorted between the CD player and the amplifier, or the CD player may be faulty. If you get a good voltage reading on both wires, but the amp won't turn on, then you have a problem in the amplifier.
Mar 05, 2007 | Lanzar VIBE266 Car Audio Amplifier
My vibe 286 4000 watt lanzar amp wont stay on..
Check your speaker load. It probably should be 4 ohms per channel. Also, if you are bridging then you must double your ohms load. It may be that your old amp could tolerate a lower impedence (ohms load) than the new amp. Do this now so you don't fry your amp. Good luck.
Mar 03, 2007 | Lanzar VIBE266 Car Audio Amplifier
Lanzar VIBE286 Car Audio Amplifier Logo
141 people viewed this question
Top Lanzar Car Audio & Video Experts
Chris Ward
xxxxxx xxx
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
