Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Filling the cleaner
I have never used this before and want to know where to put the cleaner in and the water
tonia
  • 39 Answers
Cleaner goes in little tank on side. Hot water only no soap goes in the big tank in middle
Posted on Jun 29, 2009
I need to know how much water to put in it.
press the helpful button
Fill the provided measurement cup to the maximum fill line with water. In areas with a high mineral concentration in the tap water, we recommend using distilled or demineralized water to prolong the life of the steam cleaner. Using the funnel, pour the contents of the cup into the reservoir.
Top Innovations, Inc.
400 NW Platte Valley Drive
Riverside, Missouri 64150
www.mitcoproducts.com
1-800-711-6617
http://steamerstore.com/steamfast/manuals/SF-250_Manual.doc
Jan 28, 2016 | Steam Fast SF-250 Mouse Vacuum
Do you put water in the big compartment under the solution compartment when wet washing your floor
You put water and Hoover Cleaning Solution into the top tank. Push down on the release button at the top of the tank just below and in front of the handle. The cap is also your measuring cup. Fill it with the Hoover Cleaner Concentrate. Pour that into the tank and fill it to the fill line with warm water.
The dirty water will be extracted into the bottom tank.
May 20, 2010 | Hoover H3030 FloorMate SpinScrub 500...
SteamVac Carpet/Upholstery Deep Cleaner Vacuum: how do i add the solution to the steam vac? how mu...
You didn't give a model number so I'll tell you both methods. The F5xxx and F6xxx models have a cap at the top of the clean water tank that doubles as a measuring cup. The cap is about 3 inches in diameter. Fill the cap to the fill line with shampoo and dump it in the tank. Then fill the tank with hot (Not Boiling) water.
The F7xxx series has a 2 section tank. The large section is for hot (Not Boiling) water. The smaller section is for shampoo. Fill the smaller section with shampoo and the Steam Vac will mix the water and shampoo for you in the proper proportion.
May 16, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
My floormate upper tank has a screw on filler cap nad the tank tank does not obviously come off the machine. The filer cap is under a hood and also cannot be used with iut removing the tank.I must not have...
Please let me know the model number from the data plate.
It is likely started with the letter "H", followed by at least for numbers.
It will allow me to post the User Manual to you.
Mar 12, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
I need instructions on how to use my machine. Can you please help!
if its a bissell,go to bissel .com and request a manual sent to you.there should b a cartridge that you push a button to unlock so u can fill it with water or carpet shampoo.I fill mine half water half carpet shampoo. then u put it back on ,make sure it either clicks or snaps on.plug in and turn on,they usually have a button that turns that say wash or rinse.it depends on your machine.
Jan 19, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
I have a billell Pro Heat 2X without a manual. How do I fill it and what ratio water to cleaner?
The cleaner goes into the small bottom at the very rear of the machine. It is uses full strenght (don't add any water to it). You add clean water into the bottom clear plastic section on the front of the machine. The clean water bladder is soft plastic and it is filled from the top. When you start using the machine, the dirty water will get suctioned into the section surrounding this bladder. The machine will stop working when either the bladder is empty or the dirty water section is full. Remove the entire plastic section to dump out the dirty water.
Sep 19, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Where do you put the soap cleaner, does this go
The cleaning solution goes in the top tank. Fill top tank with hot water first, then add the cleaning solution. That way it doesn't foam up. The tank lid is also a cup to measure how much solution you put in. Usually fill to top line. Make sure when you put tank on machine it snaps in place. if you have a manual, refer to it for instructions if you need to.
Hope this helps.
Sep 14, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Don't know how much water to use in Scunci Steam Cleaner
The little cup that comes with it to fill it has a line on it and says "220ml MAX". I would not recommend putting anything but water into it!
Aug 08, 2009 | Scunci 52067 Handheld Steam Vacuum
Bissel 1697 Series Is putting out water/solution for only a seco
make sure you are filling the right tank my mother in law was just putting cleaner in it and no hot water in big tank lmao i went over and found this out and deep down i lmao and was thinking i am married to this womans daughter lol
May 15, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
53 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
