Question about DFI 661FX-MLV Motherboard
I need RAID and sound drivers for my 661FX-MLV
I am re-installing XP from nothing and now I have lost 2 drivers and cannot find them on the web. Any help????
    Novelist:
    Champion:
  • 256 Answers
If you acquired a windows XP SP2 installation disk, you would have had the drivers on the disk and not worry about trivia. CONSTANTIN (arzconst)
Posted on Jun 26, 2009
How do I make RAID 1 HDD's appear on Bootable USB WinXP Install?
a waste of time and effort installing win xp on anything as it is no longer supported by Microsoft and had real problems with drivers for just about everything
install win 10 and it will work
Feb 28, 2018 | Dell POWEREDGE 1950 Server
Driver sound card
Hello. You can download the sound card driver for your EliteGroup 661FX-M7 Motherboard by accesing this website: http://driverscollection.com/?file_cid=42171620436b85b5f3172dd905e
The driver above is available for the following operating systems:
Windows XP
Windows XP 64-bit
Windows 2000
Windows ME
Windows 98
Enter the code shown then download the driver to your computer. Run the program and install it properly!
If you have any other questions, please leave a reply!
Thank you for using FixYa.
May 28, 2011 | EliteGroup 661FX-M7 (661FXM7V11)...
How to install windows 7 on Satellite A205-S5880
To install Windows 7 no need for RAID driver. If you face issues in installing Windows 7 disable RAID in BIOS, install Windows 7 and then install RAID driver.
How To Manually Upgrade from Vista to Windows 7 - Satellite A200/205:
http://cdgenp01.csd.toshiba.com/content/support/downloads/PSAF3U-PSAF6U-Win7UpgradeInstructions.pdf
Windows 7 Drivers page:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2060003&rpn=PSAE3U&modelFilter=A205-S5880&selCategory=3&selFamily=1073768663
Dec 31, 2009 | Toshiba Satellite A205-S5880 Notebook
Can't create RAID
It sounds like you have created an install disk. It also sounds like you pressed F6 to install additional drivers. Your install disk probably has 2 drivers on it. You must install them separately. So--you will have to tell the install program twice to install each driver in turn. Once you do that, it should work.
Jun 03, 2009 | Intel Motherboard
Problem with DFI 661FX-MLV
Hi!
I can solve your problem:)
Go ti this site, its the support site for that motherboard, you will find drivers, manual and everything else ther is about that motherboard:
http://www.dfi.com.tw/portal/CM/cmproduct/XX_cmproddetail/XX_WbProdsWindow?action=e&downloadType=&windowstate=normal&mode=view&downloadFlag=false&itemId=270
Good luck
Nic
DONT forget to RATE me
Mar 28, 2009 | DFI 661FX-MLVE Motherboard
Manualm and drive forDFI 661FX-MLV (e)
You can find the manual and drivers for download on DFI's site. The best place to go for this kind of stuff is always the manufacturer's Web site. In cases, where you can't find what you need on the suspected manufacturer Web site then you look somewhere else to download the data at no cost.
I'm positive that you will be happy with this solution. You will find a color image of the board along with its specs, drivers, manual, along with technical documentation...all in one place.
http://us.dfi.com.tw/portal/CM/cmproduct/XX_cmproddetail/XX_WbProdsWindow?action=e&downloadType=&windowstate=normal&mode=view&downloadFlag=false&itemId=286
Please share your experience by rating this solution.
Thanks for using Fixya.
Driver
MSI 661FM3 V
Link Download :
SiS® 650/650GL/651/661FX/740/761GX/67x VGA Drivers
XP :
Vista :
SiS® 650/650GL/651/661FX/740/761GX/67x System Drivers
XP :
Vista :
Realtek ALC Series AC97 Audio Driver
XP :
XP64bit :
SiS IDE Drivers
XP :
MSI 661FM3 V (PCB V2.0)
SiS SATA Driver (For floppy driver)
XP/vista :
XP :
Vista :
XP :
Vista :
XP :
XP64bit :
SiS IDE Drivers
XP :
Sep 17, 2008 | MSI 661FM3-V Motherboard
Can not install windows xp
hubag, you need to check your bios. At boot up, press the delete key every 2 seconds & your bios will load. Make sure your SATA drive, (s) are listed example: {if your SATA drive is a Seagate the bios will show it as: ST3250823AS}. You should unplug any IDE hard drives connected to the system while installing Win XP. The Southbridge integrates a Serial ATA host controller that is SATA v1.0 compliant, supporting Ultra DMA 150 (SiS964 only). If you do not have your manual you can download it here at:
http://www.ecsusa.com/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=392&DetailName=Manual&DetailDesc=&CategoryID=1&MenuID=6&LanID=9
661FX-M(V1.0B)
Once the bios is set & see's your SATA drive so will windows.
If you can not set your bios to list your SATA drive windows will never install on your SATA drive. You can also use the above link & down load drivers, including a RAID driver.
Feb 21, 2008 | EliteGroup 661FX-M Motherboard
Sound device problem
hi abdi,
the problem is that your sound driver is not installed. You might have got a driver cd when you purchased your PC. Installed the required sound driver and you are done. if you dont know what driver you need you can try sound max or realtek ac97 or conexant audio driver...
hope it helps
regards
bozy
Jan 20, 2008 | Logitech X-530 Computer Speakers
Install xp-sp2
First you must know is that RAID has nothing to do in a laptop... that function has nothing to do if you use just one HD, I doubt your laptop supports that RAID thing, but if it does you should disable by entering your bios first. It could be SATA problem, that many times the silly companies call RAID or something else...
I would need precise information to help, information about what you do exactly and what exact messages you get.
normally if your hardware is OK and its just a laptop and there is no other thing connected to it, windows should install perfectly... so either you are doing something else or you have hardware problems. Stay in touch with more info please.
Oct 27, 2007 | Toshiba Portege S100-S1133 Notebook
DFI 661FX-MLV Motherboard Logo
621 people viewed this question
Top DFI Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
jason
RajDeep Gautam
RajDeep Gautam
Are you a DFI Computer and Internet Expert? Answer questions, earn points and help others
