Question about Seagate Barracuda 7200.10 500 GB SATA Hard Drive
Sata hard disk not detected - Seagate Barracuda 7200.10 500 GB SATA Hard Drive
Try to detached your sata cable and try to check the connector using multitester if the output is 12 volts . if you dont have multitester, replace your sata cable.
Raul D. Sinangote
Posted on Jun 26, 2009
At first check data and power cable if it is OK then use disk manager software if it is not work then try for low label formatting.
Posted on Jul 01, 2009
3 Suggested Answers
burns-o
  • 114 Answers
SOURCE: Seagate 20GB SATA hard disk not detected
Ok, look at the hard disks circuit board, look for rust or something suspicious.
Posted on Jun 19, 2008
  • 29 Answers
SOURCE: hard disk not detected in bios
yes get another pc that has a hardisk. then make your disk slave and install it on that pc. you'll recover your data
Posted on Jul 18, 2009
How to install windows it's showing there is no hard disk in the system pls help me
If the BIOS does not detect the hard disk, then reseat the hard disk and then check the BIOS again.
The hard disk maybe faulty, if so you need a replacement.
If the BIOS detects the hard disk and you are installing Windows XP then -
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Jul 23, 2012 | Toshiba Computers & Internet
HARD DRIVE NOT EXIST ERROR!!!
If you installed Linux successfully on your hard disk then the hard disk is OK.
If you are installing Windows Xp and it does not detect the hard disk but the BIOS detects the hard disk then -
May 01, 2012 | HP Computers & Internet
XP installation problem - HP Cpmpaq 6720s Laptop [HDD detection error]
The hard disk is not detected because this model notebook has a SATA hard drive installed and the XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX.
Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Aug 12, 2011 | HP Compaq 6720s Notebook
I am installing window xp professional but there is no hard disk to detected to install.. and there are 2 hard disks attached
If your hard disks are SATA hard drives then the XP Pro installation cannot detect these SATA hard drives because the installation CD does not include SATA drivers.
To install Windows on SATA hard drives, please click on this link and follow my instructions :-
http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
May 15, 2011 | Computers & Internet
Acer Aspire 4315 when i formatted the it is shown hard disk drivers not detected quit or restated the system.
If you are formatting this model Acer usinf the Windows XP installation CD then Windows cannot detect the hard disk because this Acer uses a SATA hard disk and Windows XP cannot detect a SATA hard disk. The Windows XP installation CD does not include a SATA driver in this CD.
To format and install Windows XP on your Acer, please click on this link and follow my instructions :-
May 01, 2011 | Computers & Internet
MY BIOS IS NOT DETECTING SATA hard disk, i system is not detecting SATA hard disk
When the system is booting go into the bios settings. The option for sata drive detection may need to be turned on there, once verifying that option is on save & reboot the pc and it should detect the sata drive.
Mar 14, 2011 | ASUS K8V-MX Motherboard
Any sata hdd can't dected by the mother board but any sata dvd dected by the mother board. what kind of procedure i followed now?
Your motherboard CAN detect a SATA device.
Your motherboard DOES detect your SATA optical device.
Your motherboard does NOT detect your SATA disk-drive.
This suggests that your disk-drive is "dead".
Exercise the WARRANTY on it, to get it repaired/replaced.
Or, if the warranty has EXPIRED, purchase a new SATA disk-drive.
Feb 03, 2011 | Seagate Barracuda 7200.7 ST380011A 80 GB...
I am not able to detect sata hard disk in msi mother board
Your model K8MM-V motherboard does not have a SATA controller only IDE disk controllers and therefore it cannot detect a SATA hard drive.
To install a SATA hard drive on this motherboard you need to purchase a PCI SATA disk controller and install it on the PCI expansion slot and then attach the SATA hard disk to this SATA controller.
Aug 21, 2010 | MSI K8MM-V Motherboard
SATA Hard disk 500GB and Sata CDROM
Could be a problem with SATA drivers. Just try to disable sata support by entering bios setup if applicable.
OR
Find the drivers for sata device and install
Feb 20, 2009 | Mercury KVM800M Motherboard
Jun 19, 2008 | Seagate Barracuda 7200.7 40 GB Hard Drive
Open Questions:
bricked hard drive? Would folling this lead to a full hard drive format or just unbricking a drive like people sat it does?? Also any other ways that might help would be great to know, heres what i'm talking about! "Fixing The Drive NOTE: Commands for you to type are in red boldface. Pay attention to upper & lower case - it is important. Turn on power to the RS232-to-TTL adapter and the hard drive. After a few seconds, Press CTRL+z. You should then see a prompt like this: F3 T> If not, swap TX & RX wires. Access Level 2 (type /2): F3 T>/2 (enter) F3 2> Then spin down the (disconnected) motor: F3 2>Z (enter) Spin Down Complete Elapsed Time 0.147 msecs F3 2> Very carefully, remove the cardstock that you placed between the PCB and the drive head contacts. Carefully replace and tighten the 3 loose screws. I suggest using a small piece of masking tape to help you hold the screws while you put them back in place. Then start the motor: F3 2>U (enter) Spin Up Complete Elapsed Time 7.093 secs F3 2> Next go to Level 1 (type /1): F3 2>/1 (enter) And do a S.M.A.R.T. erase (create S.M.A.R.T. sector): F3 1>N1 (enter) Cycle power to the drive, then do partition regeneration: F3 T>m0,2,2,0,0,0,0,22 (enter) After 15-30 seconds, you should see something like: Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 14, Max Certify Rewrite Retries = 00C8 User Partition Format 10% complete, Zone 00, Pass 00, LBA 00004339, ErrCode 00000080, Elapsed Time 0 mins 05 secs User Partition Format Successful - Elapsed Time 0 mins 05 secs Do not turn off drive until you see this message. Once seen, drive can be turned off. Power down everything, place drive back into your computer, and confirm that it's working." Thanks.
Apr 12, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Seagate Barracuda 7200.10 500 GB SATA Hard Drive Logo
488 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
