Question about Oki Electric Industry OKI B410dn Digital Monochrome Laser Printer
Oki B410 and high capcity toners
Oki B410 and B430 are the same printers, but with second one you can use high capacity toner (7000 pages). When you install it on B410 it shows "No toner". It will work after removing the chip, but it shows that capacity is only1500 pages..........
Is any way to reset counters?
Just change the toner chip is ok
Posted on Nov 04, 2010
Emty error with new toner. Oki B410
What a usless "solution"...Do you have something that can accually work?
There is a procedure that will solve this issue. I have a new toner inserted and it keeps crying that the toner is empty...I have taken in out and put it back in, Now how do I reset the **** thing?
Mar 06, 2010 | Oki Electric Industry B410D Laser 30PPM...
Call service 7000:0165540 FS 2000D
Are you using manufactures toner, my guess are it is after market toner or not seated correctly, or the toner cartridge has a busted gear, either way.. try a different toner cartridge. 7000 error indicates the toner motor cant turn. the 0165540 is the page counter;
Toner motor lock error
A motor over-current signal is detected
continuously for 5 seconds since the
toner motor is activated
;) hope this helps
cheers
Nov 03, 2009 | Kyocera FS-2000D Laser Printer
I have a new OKI B410d printer which is givng error message "Install Toner 613 Toner Missing" yet toner cartride intalled adn plenty of toner in drum
It is more than likely that you have an incompatible toner fitted to the drum unit. Either a generic cartridge or b430 or b440 cartridge which is not compatible with b410's. Beyond that it may be a faulty drum unit. Hope this helps.
Sep 08, 2009 | Oki Electric Industry B410D Laser 30PPM...
What is the difference between a toner and a drum on a BB4400 OKI printer?
The toner is the black powder which the printer uses to turn type and pictures into a printed piece. The drum is the device that actually fuses the image to the paper. Toner cartridges and drums have a service life. Toner cartridges will have say a 3000 sheet capacity. When it is empty you replace it. The drum will have a 10-20,000 sheet capacity. Typically the drum is three to four times more expensive to replace. Many companies will give you a credit for turning them in vs ending up in a landfill.
Good luck.
Aug 04, 2009 | Office Equipment & Supplies
OKI B6300 DRUM/TONER
try this:
1.Press Menu = printer displays "Paper Menu"
2.Press Next 4x = printer displays "System Menu"
3.Press Select 1x = printer displays "Factory Defaults"
4.Press Next 7x = printer displays "Reset Toner Life"
5.Press Select 1x = printer displays "Resetting Toner Page Count"
6.Press Ready
Jul 28, 2009 | OKI B6300 Laser Printer
Magenta (yellow) unit is PAST end of life... (I have changed cartridges I still have this message. I tried to read instruction, and I got following message: Install P/N 108R00649 following the instalation)
Hi armaskopljak:
You have replaced the toner cartridge but you still have to replace the imaging unit which is the drom that the toner cartridge attaches to.
Toner Cartridge OK, Low, Empty When 15,000
(high-capacity cartridge) or
7,500 (standard-capacity
cartridge) pages are
printed (5% print density).
Imaging Units At/Near end-of-life When 30,000 pages are
printed out or when the
pixel counts are
exceeded.
A fuse in the new
imaging unit will blow
upon installation,
resetting the counter.
Verify color calibration. Clean lenses.
Xerox Part Numbers
Toner Cartridges:
Standard Capacity Yellow 016-1975-00
Standard Capacity Magenta 016-1974-00
‘ Standard Capacity Cyan 016-1973-00
Standard Capacity Black 016-1976-00
High Capacity Yellow 016-1979-00
High Capacity Magenta 016-1978-00
High Capacity Cyan 016-1977-00
High Capacity Black 016-1980-00
Imaging Units
Cyan 016-1993-00
Magenta 016-1994-00
Yellow 016-1995-00
Black 016-1996-00
Hope this helps
Jul 10, 2009 | Xerox Phaser 7300DN Laser Printer
Is there a override function to keep printing when toner alerts are on?Wondering since black still shows 30%.
These printers will still print when any or all of the toners are LOW, but if any one of them is EMPTY (according to the chip on the toner cartridge) printing stops.
Standard capacity toners ere 2000 page for the colours, and 3000 page for the black, so they can soon be used up.
Much cheaper per page printed, if you use the high capacity cartridges (6000 page for the colours, and 8000 page black).
There are high quality remanufactured cartridges available now, as good as OEM, and typically you'll get a Hi Capacity Remanufactured cartridge for the same sort of price as a Std Capacity OEM cartridge.
As a short term solution at a lower cost than replacement cartridges, you could just replace the cartridge CHIP. The printer would then think the toner was full (there'll likely to still be some toner in it), so you'll be able to print. Don't run the printer like this for ever though, as the toner has some lubricant properties, and with a TRULY EMPTY cartridge, you'll eventually do some damage to the cartridge, and then possibly the transfer belt (and you don't want to be changing that until it's rated 100,000 page life is up.
May 01, 2009 | Xerox Phaserâ„¢ 6180DN Laser Printer
Toner Capacity
This does not need to be done. there is a chip/fuse built into the toner that basically tells the printer how many paes that toner has printed in its life time. no adjustment is needed it is all automatic
May 31, 2008 | Epson AcuLaser C900 Printer
Oki Electric Industry OKI B410dn Digital Monochrome Laser Printer Logo
3,226 people viewed this question
Top Oki Electric Industry Office Equipment & Supplies Experts
Fix It Fast...
Fix It Fast...
Don  Farrell
Don Farrell
Victorman
Victorman
Are you an Oki Electric Industry Office Equipment and Supply Expert? Answer questions, earn points and help others
