Question about Dell 5100cn Laser Printer
Yellow line every page printed has a yellow thick line printing on the left side of page.  how can i resolve this
This sounds like there is a scratch in the yellow fuser roller... replace the imaging drum.
Posted on Feb 01, 2008
1/ Turn the power off
2/ Hold the up arrow and the down arrow at the same time and Power on
2/ Continue to hold till you see: Customer Mode
3/ Press the down arrow till you find: Test Print and then Enter (Enter= press the center button of the main button)
4/ Press the down arrow till you find: Gradation and then Enter
5/ Enter again to print a gradation page
6/ Enter again 8 more time (total 9 print)
7/ Power off the printer during 10 seconds.
8/ Turn it on.
and voila.
Posted on Dec 28, 2007
I was having a similar issue with Magenta lines and spray coming out on all my prints. I changed the toner and vaccumed out/wiped down everything I could. This has solved the problem for now. Hope this helps.
Posted on Nov 08, 2007
Why am I getting vertical Yellow lines on my printing?
It sounds like the laser drum is damaged and not collecting toner correctly. First try cleaning the paper path with laser cleaning paper. If that doesn't sort the problem replace the drums.
Aug 09, 2014 | Ricoh Aficio SP C811DN-DL Printer
Savin 9935DPE is printing one thick vertical balck line down the copy or print pages. About 2 of every 3 pages printed. What's wrong?
are you printing from Doc feeder or glas?? if from feeder then try to make a copy from the glass, does it still do it? yes problem is with drum.
No? problem is with the small scanning glass to the left, look carefully see if any spots or lines on the 1inch glas --- clean it
Sep 05, 2012 | Savin 9945dpe 9935dpe 2035dpe 2045dpe...
CP2025N printing out with a thick yellow line down the left hand side of the page - any ideas why?
I had this problem, I believe from overuse/heat.
I removed the toner, gave the roll a clean, then set a clean through the printer and it should disappoint.
Feb 15, 2011 | HP Laserjet Cp2025n Printer
When I print a color page, there is a multi colored line about a 1/2 inch thick along the left side of the paper. The print quality is good for everything on the page, just this line of swirled colors. ...
Run the Print Quality test. Sounds like one of the color cartridges is bad.
Also run the Disable Cartridge test. That will let you test each cartridge by itself.
Before you do that, open the front door halfway. Now you can see each of the color drums in each cartridge. One of them may have a 1/2" stripe on the drum on the left side.
Nov 29, 2010 | HP Color LaserJet 3500 Printer
On left hand side of page horizontal line
You might have touched the main charger cleaner a green part above the waste toner container. just push it inside and try to copy and print
May 11, 2010 | Copystar Office Equipment & Supplies
Kyocera Mita Ecosys PS 1010 all prints have thick and thin line down left hand side A little while back the printer started printing completely black sheets. Fixed by turning off and then on again. Since...
Try cleaning the charge wire. Move the lime green plastic handle from one side of the image unit to the other in the groove. If this doesn't work you'll need a new image unit.$$$$$. note: Make sure green handle is moved completely to the right when finished or black line will occur.
Feb 09, 2010 | Office Equipment & Supplies
Thick black lines (of toner down each side of printed page
There are problem in your toner, in toner there is a drum which are scratched, you have to replace this drum.
Problem will be resolve.
Feb 02, 2010 | Samsung SCX-4100 All-In-One Laser Printer
Vertical line down left side of page aprox 2" from left side con
when I opened the front door to the cartridge compartement there was a green line of toner on the feed belt, I wiped it off. then I slightly closed the door to open the toner cartridges and found the one creating the mark and cleaned it.
no more line
Dec 27, 2008 | HP Color LaserJet 2600n Printer
Pages printing blank
Resolving white, light lines or streaks (eliminate light stripes)
From the printer, print the Troubleshooting Print Quality Pages.
With Troubleshooting highlighted, press the OK button.
Scroll to Print Quality Problems by pressing the Up or Down Arrow button. Press OK.
Scroll to Troubleshooting Print Quality Page. Press OK.
Evaluate the Light Stripes Test page for missing printhead jets (missing cyan, magenta, yellow or black color bars).
Clean the maintenance unit's wiper blade and empty the waste tray. A dirty maintenance drawer wiper blade can cause white lines and weak or missing printhead jets. Using a clean lint-free cloth or a paper coffee filter, gently clean the blade with a wiping motion across the entire length of the wiper blade.
Dec 20, 2008 | Xerox Phaser 8400 Laser Printer
Dell 5100cn Laser Printer Logo
283 people viewed this question
Top Dell Office Equipment & Supplies Experts
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
