Question about HP PSC 1350 All-In-One Thermal Printer
Scanner is broken, I think.
I have a HP PSC. The other day when I was cleaning the inside, the top of the printer--the part containing the scanner/copier--fell on the floor. The part that you see when you lift up the lid of the scanner/copier is now loose. If you have a picture of how it is supposed to look attached, I think I could re-attach it. I am just not sure what it looked like in the first place.
Thanks.
  • 10 more comments
  • catherine698 Jun 25, 2009
    It isn't broken, but where is it's "spot"?
    Are you still there? What I am looking at is a long kind of rectangular bar with a white strip that looks like it slides on a vertical plastic bar that has notches on it. Only it doesn't rest comfortably on the bar.
    Is it just supposed to sit loose in there?
    Ok, I've got it placed. The picture really helped! It says there is something wrong with my print cartridge, so I don't think I can scan. Is that correct?
    Still same message. Any other ideas? Would it have anything to do with the fact that my color cartridge is almost dry?
    On the lower left side near the scanner/copier, there is a flashing yellow "E" in the copies square and the light next to the check printer cartridges is flashing red.
    Do I just push the scanner button?
    I pushed the scanner button and nothing is happening. Nothing happens when I push any of the buttons. With regard to the "drop", only the scanner/copier fell on the floor.
    When I "cleaned it" I only took out the cartridges and cleaned the pad for the black cartridge. I did this because I was getting the printer cartridge error message. I even bought a new black cartridge this morning. Still no luck!
    Yea! IT'S WORKING!!!! Thanks so much!!!
    No, that's it! Thanks!
    The solution was very helpful. It allowed me to fix the printer in much less time than it would have taken me to figure it out myself!
    Thanks so much!
  • HP Master
  • 13,433 Answers
Are you talking about the lamp that moves inside when you scan?
if it is loose, you will need to open up the scanner/printer / all in one. and make sure the lamp is
that the lamp is straight and properly placed on its spot, if the part is broken you will have to replace it.
Posted on Jun 25, 2009
  • 8 more comments
  • Ekse Jun 25, 2009
    On the left side.place it there and test if it works.
  • Ekse Jun 25, 2009
    can you send me a picture? my email is nikoht@gmail.com
    if you look at this picture you can see it on the left side
    http://users.turkuai.fi/users/niohtone/S...
  • Ekse Jun 25, 2009
  • Ekse Jun 25, 2009
    print cartridge thats for printing, open up the front cover and take out the cartridges, let it be without cartridges see what it says to that, then turn it off and unplug, wait 1 minute, plug it back in and insert the cartridges back.
  • Ekse Jun 25, 2009
    whats the exact error message?
    might have been damaged on the drop.
  • Ekse Jun 25, 2009
    Oh, you should be able to scan if it lets you. the error is not related to the scanner.
  • Ekse Jun 25, 2009
    Have you connected everything properly? check the cartridge connections inside since you had it open, something might be loose.
  • Ekse Jun 25, 2009
    Open the front door to the cartridges, remove the black cartridge, close the door, does the flashing stop?
    if it doesn't stop then remove the other cartridge, close the door, does the flashing stop?
  • Ekse Jun 25, 2009
    No problem, anything else?
  • Ekse Jun 25, 2009
    Okay, go ahead and press on the accept solution button.
    Thanks!
My HP printer/copy/scaner makes a loud clunking noise when printing
Just unplug the power cord and remove the cartridge and clean it and also It require servicing open the cover and apply some lubricant oil on the steel rod inside in the printer on which print heads move ,that you can do with lubricant oil it will fix the problem otherwise show it service center.
Have a nice day and do not forget to rate please...!
May 14, 2012 | HP PSC 1610 All-in-One Printer, Scanner,...
How do i clean my hp psc printer 1315, dissemble?
I have the same question. I want to clean the inside of HP PSC 1315, I want to get beyond the scanner glass. I tried to use a screwdriver to unscrew the four screws on the four corners of the printer, but the screwdriver doesn't fit. Is there a special tool to use it. Were you be able to dissamble the printer ?
Please let me know. Thanks!
Jul 19, 2010 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 750 PRINTER WORKS GOOD. SCANNER FAILURE. SAYS TURN OFF AND ON.
Inside in the scanner section have a too much ash on the mirrors.You need to disassembly the scanner, then the scanner section and clean the ash from mirrors.Other way is replace the scanner section.
Oct 09, 2009 | HP PSC 750 All-In-One InkJet Printer
I don´t know where is located the scanner glass in my hp psc 2110 all in one
The Scanner glass is located on the top of the device under the grey cover (This cover will lift exposing the scanner glass)
May 27, 2009 | HP PSC 2210 All-In-One InkJet Printer
Hp laserjet 3380
The problem is not your scanner, is in the rollers, the rollers are smudged with ink or other mateial or your glass is smudge, remove the four star bolts on the top and clean the undersurface of the glas with a conventional glass cleaner wipe and re install the top cover.Be careful with the ribbon cables connected to the circuit board.
Oct 29, 2008 | HP PSC 1315 All-In-One InkJet Printer
Hp2110 psc
The scanner head is unable to find start position.
You may have to clean the black & white strip under the glass.
HP has a document of how to clean the scanner glass.
Go to http://h10025www1.hp.com
You will be at the can't find page.
Enter c00553775 into the search block.
At the search result page, click on Hp All in one how to clean scanner glass.
Oct 09, 2008 | HP PSC 2110 Color Printer
Hp scanner 1210
I need the HP1210 printer,scanner,copier download program to properly use my printer that I bought at a garage sale for $5.00 dollars. It works great after I cleaned it up and fixed the broken paper feeder. Please Help if you can Thank You !!!!!!!!!!!!!
My e-mail is kjrpugz@yahoo.com...
Jun 04, 2008 | HP PSC 1210 All-In-One InkJet Printer
Clean inside of printer glass
http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu01831&cc=ca&lc=en&dlc=en&product=79499
NOTE: The underneath side of the scanner glass cannot be cleaned on any product. This is unlikely to be necessary and should only be done by an authorized service provider.
This note is found on that website. For an authorized service provider near you: http://hp.infonow.net/bin/findNow?CLIENT_ID=HP_LOC_CAN_SRV (in Canada)
http://hp.infonow.net/bin/findNow?ONE=1&CLIENT_ID=HP_LOC_USA_SRV&PAGE=Search.html&LANGUAGE=USA_ENGLISH
(in USA)
May 23, 2008 | HP PSC 2210 All-In-One InkJet Printer
HP PSC 1350 All-In-One Thermal Printer Logo
90 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
