Question about Plumbing
I am reaching you from the Mt. chalet lodge where 95% of our pumps are Taco. most of the pumps are series 1600, they have round flanges. There are a few 1600 with the oval diamond shaped flange. On the pump housing the groove for the flange gasketis at least twice as wide as other ones that I have seen(about 3/8th''. My supplier said that there was only one size flange (a type that we have on hand. My question is there available another size,wider gasket? Do I have a mismatched pump and housing so that I should be asking for some other series pump than 1600 that has a housing with another size gasket but fits with a series 1600? Thank You, Bill Keaveny
    President:
  • 1,378 Answers
It sounds more likely that you have a knock off version or some other brand mixed together as I too have only seen one version of the 1600 as long as we have been dealing with Taco.
In case you are not dealing direct with Taco, be sure to talk to:
McCoy Sales Corporation
7941 Shaffer Parkway
Littleton, CO 80127
Phone: 303-762-8012
As the listed Taco rep in your area, nearest I can tell.
Posted on Jun 26, 2009
How do i replace fuel pump 95 taurus 3.0 6v ohc
You must remove the fuel tank to replace the fuel pump.
  1. Remove fuel tank.
  2. Remove any dirt that has accumulated around fuel pump module retaining flange.
  3. Turn fuel pump module locking retainer ring (#1)counterclockwise using Fuel Tank Sender Wrench 310-D006 and remove fuel pump module locking retainer ring.
  4. Pull fuel pump module sender plate up out of fuel tank until locking tabs(#3) for fuel pump module are accessible. Reach through fuel pump module opening, squeeze both locking tabs together and remove fuel pump module from fuel tank.
Jan 10, 2017 | Cars & Trucks
WHYAT IS "SKIERS SPOT"
Possible answers include:
CHALET
LODGE
SLOPE
(Please click 'HELPFUL' if so, thanks!)
Jul 11, 2014 | Games
Taco circulator
Is this for a hot water system? If it is, u might have air in the system.
Mar 04, 2014 | Taco 007-F5-5 Cartridge Circulator Pump,...
Need to replace a taco zone valve head
Should be able to swap them., or get a qualified tech. to do it.
Mar 04, 2014 | Taco 3/4" Gold Series Zone Valve 571
Not pumping
Check to see if the motor is working first and u have power to it. If it's running u might need an impellar or u have air in system. Make sure all valves are open in line.
Feb 17, 2014 | Taco 009-F5 Cartridge Circulator Pump, 1/8...
I've had two 0014 pumps fail with in a month with the Crown BWC090 boiler
May be over heating. Should be installed on the return line near the boiler. Also, check for proper voltage.
Dec 10, 2013 | Taco 0014-F1 Single Phase Circulating Pump...
Taco 1600 series in line pump makes an occasional "chirping" noise that transmits through all three stories of the facility through the plumbing, could this be a sing of a failing bearing, pump is 10 years...
Pumps can have noises from bearings, bushings, cavitation and excess wear on the impellor and the wear rings. It is time to take it out of service and inspect it.
Dec 09, 2013 | Taco 1600C3E80121151 1600 Series Cast Iron...
Diagram for a Taco 572
We were able to find some instruction sheets, including wiring diagrams for the Taco 555-573 series zone valves on the Taco website: http://www.taco-hvac.com/uploads/FileLibrary/100-3.2a.pdf
Hope this helps,
ComfortGurus.com
www.comfortgurus.com
866-519-2461
Oct 19, 2010 | Heating & Cooling
I bought a new house and the water heater has a circulating pump with a Taco 265 timer. No instruction manual so I can't figure out how to set the timer. You wouldn't happen to have a little instruction...
Maim website:
Main website Search for Taco 265-1 gives link to manuals:
http://www.taco-hvac.com/search.html?gsearch=Taco-265-1&action=results&cb_products=YES&cb_filelibrary=YES&cb_news=YES&search_type=all_terms
Direct link to pdf manual:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://www.taco-hvac.com/uploads/FileLibrary/102-067.pdf
Instructions show series of actions to set digital program
Press h key ...
Press m key...
Press Day key...
Press Prog. key to enter...
Sep 10, 2010 | Taco 265-1 / 563-2 Combination Analog 24...
Taco timers and Surge Protectors
Do they run at the same time? The two items consume
a lot of power. Check the voltage when they are turned on. If the voltage is below 90 Volts. The power surge at your Taco is great. Then, the surge protector could not
handle the current inrush that's why it's blown off. You
must install a surge protector that can handle the Taco
current inrush.
Sep 06, 2009 | Plumbing
Plumbing Logo
60 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
